GLS Class (X167) Produced 2020 to present
Mirror Tapping a Dashcam/Radar Detector
Old Feb 14, 2023 | 12:14 AM
interlaced's Avatar
2022 GLS 450, 2021 Sprinter Crew
Exclamation Mirror Tapping a Dashcam/Radar Detector
Has anyone been able to mirror tap a dash cam or radar detector? I saw a post on a GLE being done as someone tapped into it here. It's very hard to find any one doing these things on this specific car, last resort to going to a specialized car/audio installer to do this for me.
Old Feb 22, 2023 | 11:36 AM
trevttu76's Avatar
GLS 450
What I read so far, no one has identified the correct wire. Also hearing wires that provide a true 12V is tough to find without running a wire all the way to the rear. We have a 12V cigarette socket up front, so that seems like a guaranteed closer source if someone can find where the wire bundle location runs.
The Fitcamx dashcam uses a Y adapter cable to power their unit so it must be possible. Report back if you find a solution.
Old Jun 21, 2025 | 12:09 PM
LeadfootCJ7's Avatar
2021 GLS 450 & 23 GLS 450. Have a Holden Commodore, Jeep, truck, and more
I am looking at this as well as it seems most all of the usual suspect circuits that shut down when the ignition is off are staying awake for at least several minutes after the vehicle is off. I could run wires all the way from the rear fuse box, but I would prefer to avoid this is I can.
Old Jun 21, 2025 | 08:06 PM
DC-BENZ's Avatar
GL350 Bluetec and GLS580
I was only able to find a 12v that "stayed awake" for my detector but had to abandon it because my acoustic windshield blocked radar frequencies when positioned in the top left corner.
Old Jun 22, 2025 | 01:52 PM
mikapen's Avatar
Yes, acoustic glass blocks radar, but there are two areas for radar detector, and also a dash cam.
Lower center of the windshield just above the dash, and to the upper right of the rear view mirror.
Take a look at your onboard owner's manual for locations.
Old Jun 22, 2025 | 03:16 PM
DC-BENZ's Avatar
Yes, I know, that's why I abandoned my original location. I left the tap in place but am just using the basic lighter plug now as the detector sits in the lower center of the windshield. I still don't believe it's picking up KA bands at the same range compared to my GL. I'm highly disappointed because the same option in my GL gives 3 locations - top left(where my detector used to be - tapped into the mirror), center low, and top right.
Old Jun 22, 2025 | 04:44 PM
Does the acoustic glass block dash cams as well?
Old Jul 3, 2025 | 10:14 AM
eggyacid's Avatar
ML-350, Audi Q7, Ford Taurus
Do you know if under the rear view mirror mount will have any effect on the radar? I have acoustic glass and just purchased an MirrorTap and Belmount (under the rear view mirror).
Old Jul 3, 2025 | 12:35 PM
mikapen's Avatar
It does. Your onboard owner's manual shows the radar openings.
