Any update on all-season tires for 22" rims?
I have searched within 200 miles of my address and there is only one 2023 GLS450 in the lot that meets my requirements. However, the car comes with 22 inch wheels that normally take 285/45R22 in front and 325/40R22 in rear. I live in SoCal so it is normally summer tires all year around, but I also take 2-3 trips to mountains for skiing each year, and that does not justify the cost and hassle of getting winter tires just for those few trips. Has anyone found an easy and practical solution to get all-season tires for the 22" rear wheels?
https://mbworld.org/forums/gle-class...t-costs-2.html
https://www.tirerack.com/tires/tires...TXXL&tab=Sizes
See the difference in tire sizes here: https://tiresize.com/calculator/
EDIT: Change of plans, see post here: https://mbworld.org/forums/gls-class...ml#post8870549
Thank you for your input.
Here's the 275-50-22 as mentioned above:
https://www.tirerack.com/tires/tires...DLTX&tab=Sizes
The GLS designers chose the 22" wheel size to be "XL" load rated, so this must be the version of the GLS with the highest payload rating and highest tow rating. All other wheel sizes are "SL" standard loading.
Within the "XL" category there are a range of load index numbers, starting somewhere around 110 and going up (110 is also available in SL rating, so be aware of the overlap in specs). Mercedes specified a 114 load rating to achieve the gross vehicle weight rating for the 22" wheel size.
The Pirelli Scorpion Zero All-Seasons in 285/40R22 and 325/35R22 have a load index of 110 for the front and 114 for the rear. Therefore, Discount Tire was unwilling to sell the front tires to me because the load rating won't achieve the OEM GVWR spec.
- I'll never tow a heavy trailer and thus don't need the high load index, but I understand them not willing to take on the legal liability.
- The larger 23" wheels can be fitted with Pirellis with a front tire load index of 107, but they won't sell 22" wheels with a stronger 110 load index simply because it's not the 114 that came on the factory 22s. Ugh.
The Michelin Defender LTX M/S All-Seasons in 275/50R22 and 305/45R22 have a load index of 111 for the front and 118 for the rear. Again, Discount Tire won't sell me the front tires because of the load rating.
- Tire Rack would sell them to me, but with an 8 week wait time, arriving around DEC-28 which is too late in the season to be running summer tires, risking a crash. Plus, whatever installer I choose could still reject the install for the same liability reasons and then I'd have to hassle with returning the tires. Any installer lax enough to ignore the specs is likely also lax enough to damage the wheels or the leather interior, as I know from experience.
The Michelin Defender LTX M/S2(note the generation 2) in 275/50R22 have a load index of 115, so DT will sell these front tires to me. However:
- Michelin does not yet offer the Defender2 in a size that would fit our rear wheels, so you'd have to mount gen2 on the fronts and gen1 on the rears. The tread shoulder on the gen2 looks very different from the gen1, so they would be mis-matched aesthetically. Potentially the grip levels would be different.
- Also, the tread shoulder of the gen2 looks like it's designed for an off-road vehicle and not fitting for a GLS in my taste
Gen2 Michelin Defender:
FWIW, I was quoted $2,735.60 after install and tax by the closest MB dealership for Pirelli Scorpion Winter in OEM size 285/45R22 and 325/40R22.
2023-11-20 UPDATE: I found an independent mechanic who specializes in Mercedes who will sell and install the Defender LTX M/S All-Seasons in 275/50R22 and 305/45R22. Appointment is next week.
Back in the days I was looking for my next car, I figured out it would be safest to stay with 21" wheels to get A/S so that's what I ended up getting. Good luck!
https://www.mbusatirecenter.com/
For example for winter 22" Pirellis, the price range is from $2400 to $2900 for the 4 dealers around me.
I first used Tire Rack’s website to pick out the sizes and model of tires I wanted, then asked Schwartz to order these exact tires and they agreed. I can look up later today what all-season would work best for 23” wheels.
Front: 285/35R23, currently $1,121.26 per tire!
https://www.tirerack.com/tires/tires...LNCS&tab=Sizes
Rear: 325/30R23, currently $1,199.85 per tire!
https://www.tirerack.com/tires/tires...ASXL&tab=Sizes
Size calculations:
23" General G-MAX AS07 All-Season available in 305/40R23, but no other 23" sizes. Okay for rear wheel fitment, but not recommended for the OEM front wheels that are 9.5" wide because a 305mm tire's recommended minimum wheel width is 10.0".
Front: 285/35R23
Rear: 325/30R23
Really want to see what bronze would look like but can't seem to find any that work for the 2021 GLS 580.
Note that the Porsche 911 4S OEM rear setup is 11.5" with 305/30R21 tires, so much shorter sidewalls. The GTS and GT3 use 12" rear with 305. Then again, it probably requires special mounting equipment to get those to fit. TireRack says 305 is okay to use up to 11.5" wheel.
If I could do this over, I would NOT install Michelin Defender all-seasons on 22" AMG wheels.
$2,300 for the independent shop to purchase and install them, higher than originally quoted because they apparently spent several additional hours to get the rear tire beads to seat. Therefore, if I want to remount the stock Continental summer tires in the spring time, it will cost a lot to remount these Michelins in the fall, so I should probably just leave these Michelins on until they wear out.
The front tires rub the fender liner when steering at full-lock. The tire calculator said they are only 0.36" taller sidewall, but of course how a tire mounts up and measures never matches the simple calculator theory.
I'm asking the shop to quote removing the Michelins and installing the Pirelli winter tires.
https://mbworld.org/forums/gls-class...eel-setup.html
I don’t have pics of the mounted Michelins because I haven’t taken delivery of the vehicle, it is still at the shop.
