Power Inverter Recommendation
My 2018 GLS had a 110v household type outlet. The 2024 doesn't have one, at least I can't find one in my GLS 450. Looks like I will have to buy a power inverter to power two MacBook Pros for occasional use on long trips. Anyone have a suggestion for particular brands?
At least you can stop looking for the outlet in your new car...
wyatt88 (12-14-2023)
wyatt88 (12-15-2023)
UGREEN 130W USB C Car Charger, PD 100W +PD 30W Type C Car Charger Adapter, Fast Charging Car Charger Compatible with iPhone 15/15 Plus/15 Pro/15 Pro Max, iPad, MacBook, and More https://a.co/d/gp4SAIv
I've used UGREEN products in past and found them to be reliable.
Yes like this:
The 2024 GLS has at least 2 100W Usb-C ports, so, no need for all of that. Should be able to use those directly for power to those machines that take it. Probably one of the reasons the 120V plug was removed...
mikapen (12-22-2023)
Even better! OP just needs to locate these and should be all set.
Appreciate everyone's comments, suggestions, thanks!
