Omeyhomey runs nicely moded C5 Z06 in his W210 e55
Sure thing! Looks like all four of us weigh 198lbs,and goes to the Gym to lift weights! I'm 5'11 like Improv.Take in alot of protein(myoplex 53g protein)3x's per + add creatine,and have to eat 3 other reg meals a day as well.
W211 E55 documented hp is 463 or 469 hp correct? SL55 has 493 documented hp correct? When you dyno them both they put out the same RWHP correct!!!!! Such is the case with my car and the CLK55's from 2000 to 2003.
Plus my car is lighter than a W209 CLK55. Read what Improviz says about power to weight ratio again Charlie! However,not worried about limited slip Charlie. With the right tires in a straight line I'm sure I'll get a good launch as seen by SleeperX and Enzom whom both don't have LSD! Again I said it should run 12's but I won't proclaim anything until or unless I do it. I just know on a roll I was saying where is the C6?
I posted you some runs with the CLK55 vs your beloved C6 and this is all you have to say?
Screw the pullies. Even our friend Mario will tell you that he did not notice a diference when he had them on his car N/A. He was trying to sell them prior to placing on the HPS kit.Here's a car without pullies and LSD:
https://mbworld.org/forums/c32-amg-c55-amg-w203/191821-one-fast-c55.html
I think you like to debate and argue for the sake of it! Seems like your em-mo!
Quite the opposite, just find your future bench racing mods/time slips
....Ohh you meant M.O. Modus Operhandi
You can water down your statements all you like but you still generalize way to much, just like saying you were going to be running in the 11's like benzmac, since you had the same mods minus "Light head work, and SC"
READ GENIUS:https://mbworld.org/forums/showthrea...hlight=benzmac
510 rwhp 484RWtQ Same set up as mine with light head wrk and a Kleemann Charger!
Thericker READ AGAIN SPARTACUS
:Let's go over Benzmacs list to get you into his league...
(1) Twin Screw Kleemann blower (which has been discontinued)
(2) Custom Porting (could be blower as well as head porting?)
(3) Custom cold air intake
(4) Obviously full custom exhaust ie X-pipe etc..(not just headers)
(5) Custom boost kit
(6) Custom tuning work
(7) Twin Turbo throttle body
(8) Obvious Quaife Differential, probably custom more aggressive gears
(9) Probably custom intercooler, heat exchanger
What was that about him having "Same set up as yours? with LIGHT Head work & blower, over what you have currently?"
Not even close you are thousands upon thousands away from this coming to fruition, not to mention quite possibly impossible on finding a used Kleemann Twin Screw (there discontinued) or Custom ECU tuning? anyhow point taken it is possible to get C5 Z06 1/4 times, but you aren't anywhere close to putting these past results back together....W/out all the extras here's a Kleeman dyno..Note there results will be slightly higher since stock power 2004 is higher than the older 5.4
And the CLK55 from Dragtimes w/#'s
http://www.dragtimes.com/Mercedes-Be...slip-8808.html
I have been in love w/working out since I was a teenagerDude have you tried Muscle Milk? Cookies N' Cream flavor? Da' Bomb!! just add milk! I'm addicted
P.S. I've seen you generalize about your C6 all over MBworld getting into arguments with everybody.
And stop misquoting me, I was giving you an ex: of a W202 C55 that ran 11's. "You said impossible". Sure if I put on the same mods, I was saying that Benzmac's cars shows the potential that my car has if I S/C it..
Don't woory as soon as I get the tires for my 17's I will post my 1/4 mile times. That C6 still had a hard time catching me upstairs on a roll which was my original point.
wish you knew mas much about your whip!
I do know my C6 will walk.... no run all over your modded C43 anywhere dig, roll, up top etc.. You can't compare an improperly driven manual 6speed to my Automatic A4 C6 w/360 rwhp
Therickers C6 Ownzzz your frankenberry C43 all day long
I guess you were there huh!
Get a Z06 will ya if you want an 11 sec car. Therefore you own a mid to high 12 sec car which I showed you in dragtimes. Plus your C6 has gotten owned as witnessed in the Vadim video in this forum. You're too optimistic about the C-Sic. Hate to think of what I'd do to your C-sic with my Mitsu.
http://youtube.com/watch?v=qahAfIw4ahw
OWNED!
http://mymbonline.com/forum/viewtopic.php?p=20720
Again:
http://www.dragtimes.com/compare2.ph...ame=Compare%21
Auto C6: 12.5@110MPH 1.9 60ft
modded C6 :12.4@110MPH 1.7 60ft
modded CLK55 W209 heavy as hell :12.6@110MPH 1.9 60ft
I'd just get a Z06 and be done with it after seeeing the race vids where you were owned.
OWNED!
Again:
And some other old halfassed modded garbage? Yeah I really got owned
w/headers and toque converter on C6 w/A4 trans like mine guys running 11.60's
The C6 w/blowers or TT can be made much, much faster than C6 Z06 w/equal mods, there compression is to high etc.. you're a dork
and a waste of time
Wow are'nt we sensitive!
You're driving a Cavalier and the other's are driving Z06's. Shame !
Stop crying and run the Cavalier ,fiberglass ,piece of GM trash you own in the 1/4 and stop speculating what you will run.
You are sounding like a little girl now. Now take the C-Biotch to the track and post a real time slip.
Don't talk about other C-Biotch's talk about yours.
Show you the facts and you start whining! Just post your times
What a clown u are.
No wonder I see folks flaming you on here left and right.
PS Call my AMG what you will but the bottom line is ,I drive a AMG MB you drive a Chevrolet! That says it all. Only car I give props to is the ZO6. Should have kept the S500,you know you should have. Period.
https://mbworld.org/forums/classifieds/195516-must-sell-e55-20-hours.html
I think it's him with a new ID
https://mbworld.org/forums/showthread.php?t=195516
What a clown u are.
I love my C6 call it what you like, you're obviously jealous, your stable of trash adds up to about $10k and that's if you can find the right buyer
That went from a 4.3L AMG motor to a 5.5l AMG motor ! Which prior to me ever doing,had existed in Europe in limited #'s with a 5.5L motor (C55) which was an expensive option but you know nothing about AMG because you've never owned one. Ya wish you did though,you tried to get HPS to help your S500 run like one.
How do you say sucker!
Then we went for a test drive in there 04' CLK 500 w/HPS Gen II Supercharger w/Intercooler. You gotta see this thing in person, All I can say is WOW! I was extremely impressed! fit and finish looks factory installed
The Diesel is comming!!!!!!
Pipe Dreams:
https://mbworld.org/forums/s-class-w220/135342-regarding-hps.html
Seems like someone was going to attempt dropping a 5.0L motor (HPS recommended)and then ended up buying another 4.3L motor for your car thinking you were buying a 5.0L motor. Your a joke and here is the story
https://mbworld.org/forums/s-class-w220/138805-just-bought-500-motor-w-35k-miles.html
Looks like it cost you the tired old HPS kit($9K worth of junk) price + $50,000 to Adam.
Better sell the C-Biotch.
Whose the loser again?
Just squander your hard earned $$$Remeber you're driving a Plastic Coffin made by none other than Chevrolet!
One accident and the plastic death trap is history!
I'm done owning and sparring with you son!
Looks like it cost you the tired old HPS kit($10K worth of junk) price + $50,000 to Adam. Better sell the C-Biotch.
Whose the loser?
?(1) C6 has more technology, and airbags, to save my ****, than your outdated C43..As far as adam getting a thin red penny from me
On the contrary I'll be getting money from him if he doesn't drop it, I've filed (2) extremely powerful valid cases against him, trust me I'll be the one getting paid he's in the wrong in this entire debacle. I have countless witnesses in the cases w/huge leveling evidence.I'm going to end this here Carl, your getting far to personal making ridiculous digs into my pending legal cases, (your stepping over the line, I'll be reporting your actions to ther mods)
Pipe Dreams:
https://mbworld.org/forums/showthread.php?t=135342
https://mbworld.org/forums/showthread.php?t=138805
Dude you don't know what the hell you're talking about ,the C43 weighs less than a CLK430 much less a CLK55. Ahmad's car is heavier than mines. I suppose you have not chkd out his 1/4 mile times and trap speeds!
he's running mid to high 11's last time we all chkd at 117 or 118 moh. 11.0:1 compression with a supercharger my friend. And you think a Kleemann S/C added to a N/A 5.5L can't run?
A Kleemann charged 10.5:1 and 11.0:1 is putting out more hp than a stck W211 E55.
Thericker READ GENIUS:https://mbworld.org/forums/showthrea...hlight=benzmac
:https://mbworld.org/forums/showthrea...857#post517857
PS and NO Ahmad's not running Strict Drag radials! He has RA-1's on his car. I see you know nothing at all about his car. I do know that his car would wax THAT ***!
ALSO the CLK55 is based on the same frame as my car. He also has the stck 2.82 diff and mines has a 3.06 diff. you don't have a clue my friend.
Thericker You've been PWNED! You know NOTHING about these cars apparently. Goto the GM Cavalier forums!
Stck(no cams,exh,or headers) my car put out 310whp with the 5.5L motor. Have you forgotten I have Kleeman cams,Upgraded SW,Kleeman headers,3" stainless steel exhaust back?
I still have yet to dyno since the Car has adpated to all the mods. Have you forgotten? Stop hatin Biotch! We were all there. kill the sour grapes!
Here's JLee's car with the same mods with a horrid launch of 2.5 and look at his mph. And mind you this is in a w209 CLK55 like PTE's car which is also alot heavier than mines:
Guy? are you OK? I'm not angry why are u flipping out? I might not a know every intrinsic fact about your C43, Chilly ***** brohambie, I'll bet my left one You'll get smacked down by a C5 Z06 later model BONE STOCKER w/400 etc..ran by a proficient to good 1/4 miler, w/all your non-existant Benzmac mods... That super modded C43 you posted about has a plethora of mods that you haven't even come close to getting yet, you're counting your hp's before their hatched, so to speak.
MAGAZINE DATA VARIES WIDELY I NEVER DOUBTED A 13.40 1/4 JUST 4.8 0-60...... CALM DOWN-------
