LED plate light....?
Old Jan 27, 2010 | 02:03 PM
Benzo 003's Avatar
2008 ML350 4matic
So I've search the threads and found several discussions regarding which size and brand LED works for an 08 ML....
Answers vary.
Is anyone currently using an LED license plate light bulb that does not throw an error code and if so, is it 36mm or 39mm and what brand?
Old Jan 28, 2010 | 12:45 AM
Patel511's Avatar
2006 ML350
I have 36mm ones from ijdmtoy.com $36 a pair, because it has a resistor on it. The problem is the bulb doesn't fit well with the resistor on it, both width and length. So I had to make new holes other than the pre-cut ones that come with the car. By doing this the bulb sits a little lower and so it fit better, mine was a tight fit at the end but it closed up well. I will post pics soon.
Old Jan 28, 2010 | 01:47 AM
Benzo 003's Avatar
2008 ML350 4matic
Thank You...
Old Feb 1, 2010 | 12:44 AM
Patel511's Avatar
2006 ML350
Here are some of the license plate and the interior
Attached Thumbnails LED plate light....?-img_0384.jpg   LED plate light....?-img_0385.jpg   LED plate light....?-img_0386.jpg   LED plate light....?-img_0374.jpg   LED plate light....?-img_0375.jpg
Old Feb 1, 2010 | 12:50 AM
Patel511's Avatar
2006 ML350
Iphone 3gs pics sorry
Old Feb 1, 2010 | 08:18 AM
Benzo 003's Avatar
2008 ML350 4matic
very nice....I will check them out, thanks
Old Feb 1, 2010 | 05:45 PM
Patel511's Avatar
2006 ML350
No problem
Old Feb 2, 2010 | 11:06 AM
Benzo 003's Avatar
2008 ML350 4matic
iJDM Toys just released a new one...looks like a direct fit....
I ordered a set, I'll let you know.
Old Feb 2, 2010 | 02:22 PM
b3n10's Avatar
2006 ML 350
Is it a direct fit?
Old Feb 2, 2010 | 02:31 PM
Benzo 003's Avatar
2008 ML350 4matic
They say it is...ordered it today, already shipped. Patel probably ended up with the older square centered one is why he needed to modify his set up.
I will post ASAP when I get them in.
Other companies on eBay have similar for less but I've heard good reviews of this company in other theads in other models, especially when dealing with "light out" errors.
Old Feb 2, 2010 | 10:41 PM
360º's Avatar
2008 ML550
why would you want to make your plate more visible than you have too?
Old Feb 3, 2010 | 12:10 AM
Patel511's Avatar
2006 ML350
Yup I do have the old one, now that makes me made, oh well the modding is done already so no need to worry now
Old Feb 3, 2010 | 12:11 AM
Patel511's Avatar
2006 ML350
360 I didn't do it to make it look brighter, just wanted the blueish white look instead of the yellow
Old Feb 3, 2010 | 08:45 AM
Benzo 003's Avatar
2008 ML350 4matic
Exactly as Patel said....more white/blue-ish to match the front HID kit and matching fogs and parking lights.
What are you doing that you need your " identity " hidden?
Old Feb 3, 2010 | 04:29 PM
360º's Avatar
2008 ML550
im not hiding anything. i have the required amount of light on my plate
Old Feb 7, 2010 | 04:18 PM
dgiturbo's Avatar
His 2019 RAM Cummins Turbo Diesel Laramie; Her's 2007 ML320 CDI P3; Mine BMW R1200R
Benzo 003, any updates? Did they work without errors? Fit? Brightness?
Thanks.
Old Feb 7, 2010 | 08:17 PM
Benzo 003's Avatar
2008 ML350 4matic
Still waiting....went out of town friday, neighbor picked up the mail and now he's outo of town....
I will reply ASAP....promise
Old Feb 9, 2010 | 10:21 PM
Al benzo's Avatar
2014 E350
Zizza
I have a set in my e class plug in play .... No errors >> Zizza ECS tuning got them check them out ....
Old Feb 12, 2010 | 09:42 PM
Benzo 003's Avatar
2008 ML350 4matic
Finally got the bulbs in today...wow, nice difference. 36mm is the correct size and the LEDs with the resistors is the way to go..no errors.
Kinda pricey at 38.00 out the door, but now they match the HID kit, fogs, and parking lights.
Old Mar 20, 2010 | 11:08 AM
rip1125's Avatar
ML350 2009
Getting Error Message
So I ordered and installed the LED_ERROR_FREE_D36_SKU29 from iJDMtoys and they work, but I still get the error message in the display?? Any ideas what I'm doing wrong? Simple plug and play right? I emailed iJDM haven't gotten a response yet... Anybody else have the same problem?
Old Mar 20, 2010 | 01:05 PM
Benzo 003's Avatar
2008 ML350 4matic
I had a tiny issue with the left side. It appeared to not be making a good contact and would occassionally flicker, causing an error.
I just opened it back up, reseated it, it has been perfect since then.
Something odd I notice when installing the bulbs....they turned on when properly seated in the holder, even with the car off, key in my pocket. Turned the key on, then off, and they worked as normal after that.
Old Mar 20, 2010 | 03:18 PM
rip1125's Avatar
ML350 2009
I actually uninstalled and repositioned and now they don't even work. One question though, do both lights have to be installed before turning them on? Only I ask is because when I reinstalled the OEM bulbs, I did the left one first and then turned on the car, but it didn't light up. Then I reinstalled the OEM right one and now they both work.
But even after repositioning I still got error codes on both... I did notice on the pic that was posted of the bulb, the one I ordered has the 2 LED's, not 3 like in the pic...
Old Mar 20, 2010 | 05:57 PM
Benzo 003's Avatar
2008 ML350 4matic
My bulbs are 6 LEDs total, 3 per side. They worked perfectly after repositioning. Maybe a bulb thing?
Old Mar 20, 2010 | 06:36 PM
rip1125's Avatar
ML350 2009
I did notice that when I placed the order... But the site specifies this one to work on MB, and that the 3 LED's do not.... Odd. Well glad to know yours works. What year is your ML? I have a 2009, wondering if year matters.
Old Mar 20, 2010 | 11:11 PM
Benzo 003's Avatar
2008 ML350 4matic
2008....should not be any difference. I ordered 36mm festoon 6 LED....I never contacted anyone there.
They are an exact match for shape, length, and width the the original bulb.
In fact, I put one in my neighbor's 2002 E320 and it worked on his car with one LED and one factory bulb.
I think you were sent the wrong bulbs.
Here is what I have...D36 SKU30-0...they are in the euro error free section
http://store.ijdmtoy.com/shoppingcart.asp
You have already rated this thread Rating: Thread Rating: 1 votes, 1.00 average.
