ml320 cdi wont move with out giving gas
You must scan for codes in the Trans. Cont. Module and the Direct Select Module.
https://www.amazon.com/Autel-MD802-D...ateway&sr=8-3/
How can it be that you can shift it into gear without stepping on the brake and there is NO CODE/s. I'm not doubting your ability but there has to be a code.
The trans either does not generate enough oil pressure (ATF level, oil pump failure) or solenoid(s) does not engage.
If possible, raise all wheels off the ground and engage D. If the wheels start to turn, then the solenoid is okay, and there is an issue in oil pressure.
One possible culprit that comes to my mind is that there is most likely a spring loaded "waste gate" at the ATF pump which makes a by-pass at higher engine rpm, thereby reducing ATF pressure at high engine rpm.
That by-pass valve may have been stuck open, and hence insufficient ATF pressure at idle.
