06 ML350 Manual Liftgate/Rear door issues
Old Sep 19, 2020 | 12:52 AM
sirhc.c's Avatar
2022 X253 GLC 300 Silver
Exclamation 06 ML350 Manual Liftgate/Rear door issues
Good evening, (bit of a read)
I have been through as many threads, posts and google searches as possible prior to starting this thread. (Like really, I read through the first 20 pages of the W164 forum, and done all the searches).
I have seen many issues with the power or automatic liftgates, which we don't have, but have not been able to solve my problem, even with replacing the actuator twice.
So with a bit of history...
Back in about February 2020 we began having issues with the "rear brake light" sensors, they were indicating that they were out and the quick flash indicator would happen, when they weren't. Quite easy to prove. Then we began to have issues with opening the liftgate, sometimes you could pull the door latch and the liftgate would open, others it wouldn't. I did some research and remember reading a post on some forum about the rear lights indicator and the liftgate actuator being connected, so I replaced the actuator.
Well, due to Covid-19, this took a bit to diagnose. The first actuator that I ordered through Amazon and said "Prime", but shipped from the vendor which happened to be in China, and just after I ordered it, it was locked down and took awhile to show up..
So I replaced the actuator, which was really easy through Youtube videos, (
) and all seemed to be well. Then a couple of weeks later, we started having the same issues, but I recognized something. When we would get the "rear brake light" faults on the dash and the quick flash indicator, the rear door wouldn't open, then sometimes after a restart, or the next day, the lights wouldn't have the indicator and the rear door would work.
I thought it might be that I bought a cheap actuator, so I re-ordered a new one that was more expensive and not straight out of China. Still took awhile to show up, but NO CHANGE.
Sometimes the liftgate will open, and sometimes it will not. The big indicator that it didn't matter where the actuator came from was after installing the new one, the liftgate opened right away... close it and wait a few minutes, it doesn't open????? My original may be just fine.
I have checked the Rear SAM, NO moisture at all, and as I have also played with trying to install LED lamps in the tail light assembly, and with the "rear brake light" indicator tests, all the seals are perfect on the rear lamp assembly.
I have also removed the rear door latch/handle from the door, have checked the wiring, no open wires or odd grounds? (I don't know what amperage should be going through, but have at least visually checked plugs and wires.)
Again, Manual rear door, no "Power liftgate".
If anyone has any insight it would be great. Quite frustrating to load the rear hatch and then get home and not be able to open the door from the outside of the vehicle. (Yes, the emergency release works just fine.)
Thanks,
Chris
Old Sep 19, 2020 | 07:23 AM
Maj. Dundee's Avatar
2002 ML 320 & 2006 ML500
The problem must be with the door handle cable which then releases the door lock.
Please post your full vin#.
Old Sep 19, 2020 | 02:50 PM
sirhc.c's Avatar
Morning,
4JGBB86E96A002820
I had thought possibly the switch in the handle?
Are there ohm or voltage readings that I would be able to diagnose?
Thanks Maj.
Old Sep 20, 2020 | 04:49 AM
According to your vin # you have a 2005 ML350 which is a W163.
Please update your profile and change the year to 2005.
Copy and paste your opening post and post it on the forum below.
https://www.benzworld.org/forums/w163-m-class.35/
File Type: pdf
Old Sep 20, 2020 | 02:44 PM
sirhc.c's Avatar
Hi Maj.
I understand that the Delivery date shows 03/05, but the vehicle registered here in Canada is registered as a 2006, as per the sale and insurance registration.
I've also done a Google search where the VIN registers as a 2006. Could be a early model 2006?
Old Sep 20, 2020 | 04:46 PM
Originally Posted by sirhc.c
Hi Maj.
Take a photo of your instrument cluster..
Old Sep 20, 2020 | 04:54 PM
sirhc.c's Avatar
This was taken for me a few days prior to us purchasing the vehicle.
Old Sep 20, 2020 | 05:04 PM
OK it's a 2006 ML. Was not aware that Canada had early production vehicles.
sirc, you will have to read the codes in the tailgate module. Look at all the possibilities.
Old Sep 20, 2020 | 05:06 PM
sirhc.c's Avatar
No worries Maj.
Thank you for your help.
I will try this tomorrow and let you know.
Old Sep 24, 2020 | 11:51 PM
sirhc.c's Avatar
To let you know, I have been in contact with the company that manufactured the scanner that I purchased, as I wasn't seeing any of those codes from the scans. I thought that maybe it wasn't capable, but they do guarantee that it does read from the rear module, but they don't see any codes being sent? So there is a thought that I may have a communication issue with the module. They are looking over my last couple of scans.
Just waiting on their response.
Old Sep 25, 2020 | 04:38 AM
What scanner did you order? Post the link.
Did you remove the spare tire and everything else to check for water entry?
What other features are not working?
Old Sep 25, 2020 | 06:07 AM
sirhc.c's Avatar
Morning,
This is the FAQ page from the BlueDriver scanner that I ordered. Bluetooth scanner with a great app. I have also attached a previous scan with enhanced codes.
https://support.bluedriver.com/suppo...enhanced-codes
When I was having issues previously with the Hyperflash of the signal lights and trying to upgrade to LED bulbs, I had seen in the forums the issues with the taillight assembly seals, (which mine have shown to be good and in place). I've checked the rear SAM for moisture. I have not seen any, but I have not removed the rear SAM to check the board.
As we have lost the Rear backup sensors in the last couple of weeks, thought it might be connected to the rear door actuator, and the possibility of no rear SAM communication, it may be time to pull the cover off and take a better look.
Old Sep 25, 2020 | 06:38 AM
I'm sorry to say that the scanner you bought are posting there own code numbers and they are in German and do not compare at all to M/B codes.
For example, here are the codes for the front SAM and ESP. Compare your code numbers to the official M/B codes.
Delete all of those codes you have stored, then take it for a drive and recheck for codes in all modules.
File Type: pdf
File Type: pdf
Old Sep 25, 2020 | 05:00 PM
sirhc.c's Avatar
Thanks Maj.
I have passed that information onto the developer, they appreciated the feedback and I forwarded the sheets that you sent me.
He did state that they have tried to translate the database to have the correct codes associated.
If you have other code sheets that would benefit their database, I would love to pass them on so that their product is one that would be available to others that wish to DIY and have another product to purchase.
So far it has been a good product to deal with.
As per being able to drive the Mercedes and get new codes...just so happens that last night after a walk on the waterfront, we came back to a new issue, which could all be related with the rear SAM, but Crank and No Start.
I am going to search through and find the diagram of the rear fuse box and relays to do some diagnosis.
May have a new thread...hahaha
Cheers,
Chris
Old Sep 25, 2020 | 08:02 PM
sirhc.c's Avatar
Haha, and of course I go to do some diagnostics, and it starts right up.
Old Sep 26, 2020 | 06:50 AM
I still believe that you had water entry in the rear SAM and you should remove the plastic covers to see if there is corrosion.
Here are the diagrams for the rear SAM.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Sep 26, 2020 | 04:16 PM
sirhc.c's Avatar
[QUOTE=Maj. Dundee;8165652]I still believe that you had water entry in the rear SAM and you should remove the plastic covers to see if there is corrosion.
Well Maj.
You are correct again.
Here are the photos of the corrosion.
The SAM is place in a bracket off of the body, so not sure where it came from but either the Seals were added or upgraded at some point. They are good now through.
I will try and clean it up, and look at the plug that fits in that socket.
Thanks,
Chris
File Type: pdf
