ML350 Door pins.
I was disappointed to see the cheap plastic quality of the door pins that MB decided to go with. Taxi grade plastic junk. Granted you most likely will never touch them given all the automation of the vehicle's lock/unlock features. None-the-less, I have decided to modify with pins with something more worthy of the $60K vehicle.
Anyone have experience in swapping them out?
- Are they simple to replace?
- Do I need to remove that little ring around the base?
- Is it a one-size-fits-all? Is there a specific ML350 threading or curvature of the washer gromet?
These are some replacement parts I found on ebay and such: please give your feedback. I am willing to pay up to $20 a piece.
http://mercedespartspeople.com/searc...Round+Door-Pin
http://www.amazon.com/Mercedes-Benz-...9197396&sr=1-1
My top pick: *unavailable
http://www.amazon.com/Mercedes-Benz-...sim_sbs_auto_1
https://mbworld.org/forums/new-m-cla...ake-pedal.html
Here's what I'll probably end up getting:
http://www.ebay.com/itm/DP04-Merceds...#ht_558wt_1163
In this pic, the door is unlocked. When locked, the pin sits flush. I have done this to all my recent Benz's (C Sedan, E Sedan, GL, ML).
I was looking for a metal/silver/brushed aluminum look.
Thank you.
You need to be aware that if the W166 is consistent with the latest C/E Sedans, you can't change the rear pins without significant effort as they are fused to the door lock assembly. The front pins can be unscrewed. So if you opt to go with an aluminum door pin, they will be mismatched.
