Bluetec transmission downshifts
Does anyone else have this experience?
Mode. The ratios are
QUite close in lower range so a downshift is very normal. Or you lucked out and got the double clutch AMG speedshift. They can make that mistake on mine :o) Bamma Boys n Girls feel free july 27 double brown hahaha
It may be the result of a learning experience for the transmission, because I drive it in sport mode and I often downshift on curvy mountain roads to help brake the vehicle. I have the Airmatic suspension and active curve options.
And for the record, the Aston Martin does EXACTLY the same thing.
I have simply thought of it as "engine-drag," more of it, than in previous cars with automatic transmissions. In a car with a manual transmission, you were always aware of it and could use it a lot if you wished. Automatic transmissions always had a "free wheeling" aspect to them and engine drag was usually not very noticeable. I think some early auto transmissions had a roller bearing/ratchet kind of free wheeling device so that when you took your foot off the gas peddle, you were simply coasting... no engine drag at all. I could be wrong about that.
I think in recent years the ability to use the engine-drag feature has been added back to the transmissions as they have added the "manual shift" option to the transmissions. My 2007 R-Class also had paddle shifters. I NEVER used them except to experiment a little.
The paddle shifter lets you use available engine drag by letting YOU select the timing of the downshifts when slowing down. If you don't use the paddle shifter, the transmission itself decides when to do it, and it is much smoother and you don't get the sensation of engine-drag.
My immediate impression in the new ML, was that they changed the timing of the automatic downshifting... But... I am getting way over my head here in my speculations. I am not an expert in such things by any means.
Al
