ML350 Coil
Old Apr 20, 2022 | 01:30 PM
Kurt Wiegers's Avatar
1998 ML320
ML350 Coil
My 2015 ML350 has been in the shop for 36 days. Great truck with 130k miles. We’re not able to find replacement coils that work. Tried two after market coils, but no luck.
Could anyone point me to a source for OEM coils? Most of the usual suspects show the part as back ordered. I’d really like to get my car up and running again. Thanks!
Old Apr 20, 2022 | 09:26 PM
chassis's Avatar
2017 GLE350 4MATIC
3.5L V6 gasoline correct?
mbparts.mbusa.com has them. Change your location using the search parameters until you find a dealer with inventory.
Buy OEM parts for these cars 95% of the time.
Old Apr 24, 2022 | 06:21 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W166 forum...
Old Apr 26, 2022 | 08:02 PM
C280 Sport's Avatar
MB’s of all kinds.
What about Strutmasters? What about going to the dealer and buying parts or even from FCP Euro?
https://www.fcpeuro.com/Mercedes~Ben...b=11&d=4519&v=
Old Apr 27, 2022 | 11:07 AM
rmassmann's Avatar
Mercedes ML350 Bluetec 2012
Broken Rear Spring
While working to add an OEM hitch assembly to my 2012 ML350 Bluetec I discovered that the rear springs need to be replaced. They are both broken at the lower end of the coil. Passenger side has (2) breaks while the driver side has (1) fracture. This car has less than 90K miles. I am thinking of buying Bilstein springs instead of the OEM. Would like to verify the significates of the color strip on the spring, is this associated with effective spring height to keep the car level?
Old Apr 27, 2022 | 09:56 PM
chassis's Avatar
2017 GLE350 4MATIC
Use mbparts.mbusa.com and enter your VIN to search for the correct springs for your vehicle. Looks like the spring has been broken for quite some time.
Old Apr 29, 2022 | 11:53 AM
rmassmann's Avatar
I am a bit disappointed with the local Mercedes dealer, as I took it in for an overall heath check a week or two after taking possession of the car and they didn't find the broken springs but did find a bad oil leak from the oil cooler or rear main. I completed the oil seal fix and replaced crankcase vent valve due excess soot oil accumulation of the intake air path to the engine.
Old May 4, 2022 | 06:53 PM
rmassmann's Avatar
Cool Broken Rear Spring
It is amazing this car has about 87K miles on it and the passenger side spring in the photo actually has broken twice and the driver side spring has broken once?
Old May 14, 2022 | 09:29 PM
PDGCT's Avatar
2022 GLE350 2021 GLC300 2015 BMW 335ix MSport
I just installed an OE unit from FCP Euro on mine, no issues. Have you tried sourcing from them?
