Ml350 2012 rattling noise of engine
Old Dec 1, 2024 | 01:30 AM
Thv2023's Avatar
My Benz ML350 2012 model is giving me this rattling noise and very loud sound from the engine very sharp . This will stop in few seconds how can I fix this ?..
Old Dec 1, 2024 | 05:42 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W166 forum...
Old Dec 1, 2024 | 05:45 AM
Thv2023's Avatar
please how can I do this and can this forum offer me the help I needed? Thanks
Old Dec 1, 2024 | 05:48 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
https://mbworld.org/forums/new-membe...-subforum.html
check correct subforum and then create post...
Old Dec 3, 2024 | 03:03 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
what kind of scanner do you have? Are you getting an error code already, or only the initial noise at startup?
Since your vehicle is a 2012, it is likely in the range that requires either the check valve, or the new chain tensioners per MB-Technical bulletin. Please use the following to determine your exact engine number https://www.lastvin.com/
File Type: pdf
Old Dec 5, 2024 | 06:01 PM
Mikey178's Avatar
2013 Mercedes GL350 Bluetec (X166) & 2019 Mercedes A220 (W177) & Retired 2008 Mercedes C300 (W204)
If your vehicle has had the AEM Field Measure done, the timing chain will be covered under the extended warranty. I had a very similar issue in a 2013 GL (Same OM642 engine) and it would rattle for a few seconds upon a cold start up.
Took it to the dealer for the rattle and they found the chain was out of spec and replaced under the warranty. Never had a rattle since.
Old Dec 5, 2024 | 06:43 PM
JCM_MB's Avatar
Not certain if the OP has a Diesel, or Gasoline engine. Let us see if he updates the thread.
Old Dec 7, 2024 | 05:58 PM
ml3504matic____'s Avatar
2015 ML400 4MATIC, 2016 C300 4MATIC, 2014 E350 4MATIC (Totaled), 2006 E350 (Sold)
Without looking at anything and assuming you have the gas variant, it is most likely the Timing Chain Tensioners that have failed + Check Valve.
Since yours is a 2012, it most likely does not have them.
Symptoms of this is Rattle on Cold Start Up; see someone has linked the bulletin, refer to that for more details.
Old Dec 8, 2024 | 01:51 PM
Leetom's Avatar
2013 ML550 US spec. Air+Offroad pkg
Does it have an extended startup cranking from time to time as well? If so, could also be the Cam adjuster. It will cause both the startup rattle and extended start crank (like 3+ seconds). Typical causes are, as stated above, missing oil pressure check valve, chain tensioner(s) worn out, cam adjusting gear assembly worn out.
Old Dec 8, 2024 | 03:13 PM
JCM_MB's Avatar
And/or camshaft reluctor/tone wheel slipping
