OM651 P0132
Regards
Amir
7
[img alt="O2 sensor for Mercedes Benz W166 ML250 CDI 2.1L 12-15 OM651.960 Oxygen EGO | eBay Australia"]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBwgHBgkIBwgKCgkLDRYPDQwMDRsUFRAWIB0iIiAdHx 8kKDQsJCYxJx8fLT0tMTU3Ojo6Iys/RD84QzQ5OjcBCgoKDQwNGg8PGjclHyU3Nzc3Nzc3Nzc3Nzc3Nz c3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3Nzc3N//AABEIAHAAjAMBIgACEQEDEQH/xAAcAAABBQEBAQAAAAAAAAAAAAAGAQIEBQcDAAj/xAA8EAABAwMCBAMFBgMIAwAAAAABAgMEAAUREiEGMUFRImFxEx QykaEHI1KBwdFCYnIVMzSSseHw8RZTgv/EABoBAAIDAQEAAAAAAAAAAAAAAAAEAQIDBQb/xAArEQACAgEDAwMCBwEAAAAAAAAAAQIDEQQhMQUSExQiQVGRIz JDYXGBoUL/2gAMAwEAAhEDEQA/ADNyGu4BDqCG3mcKjyEbjHY+W24/3qxuVrjXW3Khz0haVDOsDBSropPYipVrjspjK0xVxjqOpB6nuP 8AapQYAOyiB59KnIGA8T2qXw5PVEfRqSoEsvY8KxnOR5+XSh8B SyTvjPM19GcRWCNfbW5DmICkq3bcT8TauhHnWLXGwTrYpSH4Mh LbRKUuqZUEL88nvW8Jp8mclgiwLhcoLKTDuk5lR+FLTygkflnH 5VaQftB4ltygFSI7+2Pv2EnI9U4NUTZ9krOctnnk/D6nt51xuMltKcsHWsfxkbD071Mu35IWQ4a+0e3LWVXazll1ZCv bxJBJB1A50KBHNIz3xU2RNFycRcIMlL0bUfvGxqcQVbqUodDz+ fLasdcd3KioqUeZNSo1wk2+cuRCeU04EjGk7FPYjqP3pWdalwM wvnHnc0eVbY/ELLglNrakNeFMrSEqPbI67YPlnHMUD3eyTrQ5iSnU0ThLyPhV+ x8qKrHxe1JQhq4IRGeJ+NPwKPfyzRQiE5OStLuERFDHiGS56A9 KTv1MaF72XUPI8xQIfZm2o3CS4B4Et6VHzzWlgk1WxY0e3MJYj oQwyj4Ug4+fnUtMljq+1/nFec1Vr1FjmkOVxUI4yShS1zbcQ5s2tKv6TmuoFJtNcmiY3G9L inYr2KgkZivYp2K9poAvUnS/7U7q06c74xnPKoN54rtln+5klTj5xlhjBUAepBIA/OgK/wDF94iWlmNBCEuKOgyea0joAOWfOgOUtxIUj2pccWSp1xR3Ue5 Jr3tLjbDvXBx55g8GvOcUWG7SCEXthoJ0KQxLbLelaTkYWdhnb PM7VKMx+2Rgp+c6thSC6lyKoSPaHJ2VqB2xjkACTWBPTW2jhgh a/wD2EbD0H6mkgX2fbXi7DluoJOVJzlKvUHaidaz7TSF0ksNbGsT 2ovFLLpuEBERSVFOqOQg6snIOMhWNtz1zsKAOIOE7pBSowyJcY b/djCx6p6/l8qtoHHzam0e/RShJ2U6xuAfNP7VaLu7dyaAtb6Xs51aDuPLHMGqJuK9xWTUn7V gydYUFFKwUkHBBGCDU+BDdmqSlCCVp2G3MedGl0jwC3qnNNuyM/GBunyBquR7w637NlPukXmSkeJX596HZnnYrgk2oQrO424ttMm4 DdO2pLfokdfMmrOdebpIUNUoMpP8ACc5+lV0Nl6QSxZ2wpQ2Ut Q8I7lSv0q8hcJyHv8fM1DmpLCMZ/M5+mKRuu0tTzPd/c2hCyS2KJySHlezemKK/5AAfma5pCUNlHvUhIPVZCsfSj1vhi2hpLXuTOgd05Pz611PDFq x/gGNv5BSi6xBcRNfSv6mctMSI6y5Fn+0cPIKyPrRBZuL5kMBq6+ LfBC9jjuD++auJPBkRaVGO44x10pI0/I0M3W2yIJ92uSSpg7JWeSvQ9DW8NTptZ7JL7lHXZXujSoMyPPZ DsVwKT1HVPkRUnFZJCvsix3BAOShKR4s/GnsRRsjjmyqZDgW8pe+ppDZJTj6VydX0yyqf4W6YxXepL3chLS 48qz9fF1yvalN2hkQo2+p91SQQPMnZP1NV8niu5QViPHvAkpSn dYYBwe2SMn1qI9Lvay9izvgXlyhJcbWlScpI3FZ7xNFlNPkKbS 3FOCn2Y8JPLfz/AOCtbkM5BqjnNqjEvIRqA+NH4k9RW+g1jql2vhlb6lJZMoDGlC cAFa9wfwikVHOFaj8PXFaXcLRZnmWVPxtLzqfji+AgHr2/6PaoKeCBKUDFmr92CsKU61hQHl3rtz1lcFmTwKeCfKQFW6E9Jf 8Ad4zS3lubaEjeidNmTYUo9ssOTSMqSg+Fryz1NGsKBBsMFz3R kDSklbh+Nw+ZoftMVV0uanpHiQk6lA9T2pKOu8ilZ/yv9Zp4cNR+WOs9iMoiZcSfZkakoPUdz2FIlJu1zQykBLedwNtK B0+W1Fs9Hs7TKWOYZV/oapuEVsqmyG0tp1FAUFAb+np1pSvUTnVZd88I0cEpRiEUOG222 EobShCeSUjAFTUIA5DangbU8DauK3l5Y0IECnaacBtUG6XaNbA lLpUt5fwMoxqPnvyHnRGEpvEUDaXJM0gDJxihy/3S2yWFwkNCas7EJHgQfNR/TNV1+l3GdbjMkIS1bmlgrbScJWORyo41kZzhI6VAlcR2i1gt2m N/aD6eT0hOllP9LfX1V8q6+l6a1iVj3F53LhFFfbFMET3/AEqWyhOy8BKdtykE8zjfbsaHoE4xXzpSD7TYZ6GrPiC+Srnl26 zXHSPgQDhKewA6D0FVFvjKmOhLbasZHizy7V3IvCFZck0sTZj2 PaEMA7Anwp9BRRbuE4z0VK3A6tR6jYVd2LhZtlpC7grUvH92k7 CipvQ2gIbSEpHIAVw9X1Bt4gxqulJbnNaQedRXYrawQetTCKYR XKy0MkCPaY6VeNIW3g+EpHyzzxU5ZyAlIwkDAApQDS6KmU5T/MyMYRTcSEt2l3TzJSPrXPg+MUwCtQHjWTU++Ri/bXUpG4GR6io3BrmuApoqGpteAOwpzOdE0vruY/ql28wHmVtEbKTg0BJdlcPXMtk7J5ZHhcT2NaMBVfebQxdY/s3k4UPhUOYrPSalVNxmsxfJayHdxyVUPitBViZHwD/E0rVj1Bro/wAdcNMFYcuSQpHNAbUTntyofl8IT42VRZCHAOQIKT+tAz/CN6Q8U+7rVvzAro+n6fdvF4MO+6PO5oaPtAt90vESBHkOQYjiV +0lvDRhQGUjqQOfnkioN3uEQqKbS17w+04FtyFI2UMagSk7nlj fue9Uln4AlufeTcN4GQFnfPoKNIHCsdCAJjqnscm0DQgfl1rT1 Ol0se2tAoWTeZAJNeul3lEz5S33eSUg6zjyA2Arsrh+YGi+60W WRj+8O6iegHU1pBYg2mOtxLSGWx+EbqP60JXW4vXGWltpBK1HS 02nfTn9anT32ah54iuWRZGMFj5Ku1WNmdc0xShKmmhreXp5/wDDXWPESLmpDKQlJkaUgdgaLoVvTY7K86vCninUtXc9qpOH2C7 dGQd9A1qNaV6nyeWxflSwirhjti+WGaAa7BJxT229uVdgivNtj xFr2KWlFQSIE4pwFKKcBQAxaAtCkkbEUHyEuWG8JkIB9ipW+OW DzFGqRUedDZmNFp5IINb6e/xNp8PkpOHd/I6DcIk5I91fQtWMlOfEPyqXigSbYJ1vdD1vUtQScp0nCk1zHE9 3jKCH1kqT0cbAz9BTPoYW70z/AKZn5XHaSD5SQa5Ljg0I/wDm0jQAIzIV1JBI+Wa4u8aTCjCUNIP4ko3+pNQumaj9vuD1EAz TGAqpu99i28lpvS88Oe/hT6/tQsq83u55bYU+4k/gTgfMAD51Ig8JypCgu4O+yT+BJ1K/YfWtoaSil918k/2RV2TltBFfKm3C+yktM63D0AGAB+g86LOH7A1bW/aOkLfI8SzySOwqwgW2Lb2ClhtLSAMqJP1JrO739pE1x2XHtUaI mIdTaHXUqUpScYzjIAq7st1v4dKxFEYjV7pchJxXfYD0NMO3To kp0uDU0y+lSzvsABnrS8HsZcluqGFIcLJHPBB3wetY0y8tlxtU ZamnGlBSFJOCCORrbeAbgbpYmnVxww42dCwlOAo/iHr/AK5rbV1el0njhw2RXJWTywoSnanaaVIpwFefyNkAUoFeFKKsAo paQU8VACilxSCnCgBCkGuL0Rp5OHG0rH8wzUkUtQm0QVCrFb1b mGwT/QKc3ZoTZy3EYSe4QKttq9ir+Sf1DCIrcYJAAAA7V2S2B0rpioF 8ukey2t+fKPgbT4UjmtXRI8zURi5yUVyweEgO+1PiIQ4f9ixFf fyU5fI/hbPT/wCtx6ZrJnF6UAYOTzqbcpsi4zX50tWp55ZUsjkOwHkOX5VA5kk 16/SULT1KH3ObZNzlkc217UpSjJWTtit/4ZZcYs8Np1IStLKQoAY3xvWWfZ7Y/friJLycsMnO/InpWyRhgVyOq3qTVa+BnTwxuSk08YpqeVOriDRXilFIKUVcBRT xTKeKgBRThSAUtADhSikFKKgBwpaQUoFAHqHOMrabxblQ1oOge IK6pV3HzokxSLQFDcZq9c3CXcvghrKwfM1ygy7PNXFlJOR8lDu KWCwqZIbbaBUVnAxW78Q8LwL0yUSGRkDwqGxT6GhzhzgJuzXFU pbxdSPgSRyr0MeqVyqy9pCT07T24L3hi1ItVtajpA1Yys9zRE0 nauDDflUxAwK4Fk3OTbHEsIUJp2K8KdisSx//2Q==[/img]
The Mercedes W166 OM651 P0132 code indicates an "Oxygen Sensor Circuit High Voltage (Bank 1, Sensor 1)," meaning the upstream oxygen sensor on the first bank of the engine is sending a signal that is consistently too high. This usually points to a faulty sensor, a wiring problem, or a rich air-fuel mixture condition caused by other issues like fuel injectors. The primary fix is to diagnose and replace the faulty O2 sensor or repair the wiring, but a mechanic should also inspect for underlying fuel system issues.
What a **** spot though, it's right next to the chassis leg so barely any room to fit tools plus air box is on top
I'll figure out sometime how to remove it lol
