M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Cooling down the V12TT
Old Dec 4, 2016 | 06:38 AM
  #101
ZephTheChef's Avatar
2004 S600
Originally Posted by Welwynnick
I don't think the X3 radiator would necessarily fit.
http://webshop.nissens.com/Product
The W215/W220 radiator core measures 641 x 469 x 40 mm
The W216/W221 radiator core measures 640 x 459 x 40 mm
I only know that the X3 radiator fits (with some difficulty) because I measured up my own car, and I used trial and error.
Given that the later models have a shorter engine radiator, that suggests to me that the X3 rad would be too tall.
A BMW 3-series or Land Rover Discovery radiator would probably be a better fit.
Nick
I wasn't aware they had changed the main radiator size/packaging up front. Glad you chimed in.
Old Dec 4, 2016 | 01:05 PM
  #102
Welwynnick's Avatar
2006 S600
Originally Posted by black-series
Welwynnick, thank you for your input and experience, I also would have thought that heat shielding might help a lot, but now I will safe myself a lot of work and leave it as is. Probably I will go with Renntechs solution because this seems to be the only reasonable place for another heat exchanger. Adding a big heat exchanger to the main cooling sandwich seems impossible, the available space is so tight plus I would have to eliminate the ABC cooler as well. And I cannot imagine any air molecules voluntarily going through this wall of resistance and all the heat exchangers will reheat each other like crazy as well.
So yeah, I will go with the small one which luckily doesn't require a crazy amount of modifications on the car (like to keep it as stock a possible). Hopefully it will be enough to solve the cooling problem.
I wouldn't worry unduly about stacked heat exchangers and airflow. It's the norm for modern cars to have three full height heat exchangers - 16mm AC condenser at the front, 32mm intercooler in the middle, and 32mm radiator at the rear. They're cascaded in temperature - coolest at the front, and hottest at the rear.
With water cooled charge cooling, the HE is actually a benign burden to airflow, as the water passages are so slim. Most cars have air-air coolers, which block 50% of the frontal area due to the horizontal air tubes.
When I fitted my full-height radiator/HE, I was indeed worried about airflow blockage, as nobody had done this before. I tried blowing through the radiator out of curiosity, and found very little restriction - the air went straight through. On the road, I saw no difference in the cooling system behaviour - only improvements in the IC performance. I monitored it with STAR, OBD2 and a separate IC coolant temp sensor.
The bigger pump and HE worked great, and the only issue was heat soaking when stationary after a run. The engine compartment is like a 90 deg C oven, and nothing stops the IC coolant heating up unless you open the hood. Insulating the pipes and IC's slows it down a little, but it can't stop it. Sure, there's a small, measureable improvement, butit's almost intangible in use, and it's not worth the significant grief IMHO.
Far better to make an ally heat shield for the coil packs, and extend that downwards to wrap around the coolant pipes as well, and shield them from direct line-of-sight to the turbos. That's easy. Like this:
Old Dec 4, 2016 | 04:01 PM
  #103
Welwynnick's Avatar
2006 S600
How can i reliably check whether all the air is gone after bleeding the system? If I cannot manage to bleed it without the recommended full vacuum pump, I will buy one. Just want to try it without first, although it seems to be impossible according to all the post.
Thank you all for your help and input!
Yes, bleeding is difficult. The V12TT IC system is, by the standards of modern cooling systems, a TERRIBLE cooling system. Cooling was solved a long time ago, but Mercedes forgot about all they learned, and made every mistake all over again.
If its working, it works well, but it's needlessly difficult to maintain. A tiny bit of air in the coolant causes frothing and a huge loss of cooling capacity.
The pump uses a commutator and brushes, which wear out. Problem is, you never know for sure when it fails.
The dynamic seals leak eventually, but it's difficult to check the coolant level as there's no header tank.
The system is full of air locks, and there's no provision for bleeding. So the only way to bleed is with a vacuum refill tool like this:
This is similar to the Mercedes special tool, and uses a compressed air vacuum pump. However, that only generates about 80% vacuum. That isn't enough to get all the air out of the system, so there will still be airlocks, and it has to be done again and again.
The answer is to use a real vacuum pump that gets over 99% vacuum, THEN the system will be filled and bled properly.
Like the suspension and like the ignition, it shouldn't be like this, but Mercedes made a leap with the W220 and the V12TT in particular, but tis what we've got and there are ways to work with it.
Nick
Old Dec 4, 2016 | 04:43 PM
  #104
freestylebiker3's Avatar
w215 cl65, W212 E63, R53 Mini Cooper JCW, E92 328I
one of my old posts, just in case you need it...
https://mbworld.org/forums/cl55-amg-...p-upgrade.html
Old Dec 4, 2016 | 06:46 PM
  #105
Welwynnick's Avatar
2006 S600
The Meziere WP135 is like the Johnson CM90 - it's no better than the Bosch -010 pump when installed in our systems.
Nick
Old Dec 5, 2016 | 03:07 AM
  #106
Nick
the Meziere pump i installed provides 20 GPM, and worked great for my car. if you personally like the Johnson pump more then the Meziere, all power to you, i cant argue with that.
both pumps will work well, i personally have worked with Meziere more then johnson, so i trust it and understand it better..
Old Dec 5, 2016 | 05:27 AM
  #107
Welwynnick's Avatar
2006 S600
I'm sure your car works great with the Meziere, and that's what matters, but it doesn't flow more than the Bosch. IC systems have too high restriction for high flow pumps like Meziere and Johnson. 20 GPM is the open outlet figure.
Nick
Old Dec 5, 2016 | 06:01 AM
  #108
2004 S600
Nick
I'll second that. I don't think even my 55gpm Meziere would outflow the stock pump in this system. It does great in my Buick with 1.25" lines. Which may not sound that much bigger but it's 3x the flow path of a 3/4 line. These systems are just too restrictive for those engine cooling pumps designed with just a few psi pressure in mind.
Old Dec 5, 2016 | 06:51 AM
  #109
Welwynnick's Avatar
2006 S600
I think 3/4" pipes are universal, but too small for powerful engines. You might think it's water, so its got thousands of times more heat capacity than air. But its also got more density and viscosity, so it moves MUCH slower. When you compare the mass flow rates, we have around 400g per sec of both, and that's a bit marginal. We could really do with bigger pipes!
Nick
Old Dec 5, 2016 | 05:47 PM
  #110
2004 S600
Nick
Yeah, I assume you mean volumetrically when you say thousands of times. If you have the same mass flow rate on both sides, you're going to get the water temp rising 1 degree F for every 3-4 degrees F (depending on ambient humidity) of cooling on the air side. That's going to heatsoak the water pretty quickly when your turbo outlet temps are 300 degrees F!
Old Jan 5, 2017 | 09:49 AM
  #111
black-series's Avatar
Nick
Thanks again for all the help. As you said, of course bleeding didn't work without special tools, so I ordered a vacuum pump that is supposed to lower the pressure to 0,05 mbar which should be sufficient for a vacuum. Do I still need a special vacuum refill kit like the one in your link? Could you roughly explain how to connect the pump to the car for proper bleeding?
Old Jan 5, 2017 | 06:15 PM
  #112
2004 S600
I have had "moderate" luck with the venturi-type vacuum tool like that. The actual air conditioning vacuum pumps work much better, but still need to be used with a refill kit like what you purchased. Typically with those kits, one of those adapters will fit the intercooler filler neck and adapt it to fit the main part of the bleeder. Then you hook up shop air and set the valve to let the system build vacuum. Once it's at full vacuum you change the valving so it draws coolant back in through the other hose. It will get most of the air out but you may still have to do some further bleeding. If you adapt it for use with an A/C vacuum pump, you will get all the air out.
Old Jan 5, 2017 | 06:30 PM
  #113
Hi, I didn't buy a Venturi type vacuum pump but a rotary vane pump instead
http://www.ebay.de/itm/Vakuumpumpe-5...3D131861240602
I managed to get hold of the workshop cap that enables me to connect the hose to the intercooler filler neck. So I guess I need a splitter with two valves to enable me to draw coolant back once at full vacuum, right? Is it better to order a whole refill kit additionally or just the parts I need (valves, splitter, hoses)?
Old Jan 5, 2017 | 06:33 PM
  #114
2004 S600
Oh, sorry, I see that the picture was in the quote of Nick's post, not yours. Yes, if you have an adapter for the factory cap basically you need a valve that will switch the connection from the system from the vacuum pump to another hose, which you will have primed with coolant and drawing from a bucket of coolant with enough capacity to fill the system. This can either be done with multiple straight-through ball valves, or probably with a single 3-way valve.
Old Jan 5, 2017 | 06:39 PM
  #115
Ok, thank you for your help, I will try to get a 3 way valve.
Old Jan 5, 2017 | 06:46 PM
  #116
2004 S600
Just verify you get it set up the right way before you try it with coolant. Would suck to accidentally switch the coolant supply to the vacuum pump side instead of to the intercooler circuit.
Old Jan 5, 2017 | 06:51 PM
  #117
That's a good advice, that really would suck, even more than bleeding the whole thing
Old Jan 8, 2017 | 05:18 AM
  #118
Welwynnick's Avatar
2006 S600
Yes, you would still need one of the vacuum refill kits, or something similar. You need a way to get the coolant in without letting any air back in, having evacuated it.
This is the one I got. It has a tapered filler adapter, which I don't like, but it has TWO valves - one to isolate the vacuum pump (on the left) and one to isolate the coolant. I think this is ideal, and it's cheap.
The reason why a rotary vacuum pump is more effective than a compressed air / venture pump, is that a deep vacuum in the cooling system will boil the water at ambient temperature. That means the system will be filled with water vapour, and all the air will be purged out. Not just 90% or 99% or 99.9% of the air, but all of the air.
Then, when you fill the cooling system, all the water vapour condenses back to water, and you get a complete fill. You need at least 1 kPa vacuum for that to happen (depending on ambient temp). Venturi pumps don't get close, which is why they're hit and miss.
Nick
Old Jan 8, 2017 | 08:15 AM
  #119
Thanks for the explanation Nick, this will help a lot. I had a similar setup in mind but the whole kit makes it a little easier.
Old Jan 23, 2017 | 11:37 AM
  #120
Hi guys,
finally I managed to get all the parts I need for bleeding my car, but I am unable to create a vacuum. Reason being is that the pump always pulls water out of the system together with the remaining air, so I have to turn off the pump to prevent the water from entering the pump. Is there a special trick to it? Do I need a vacuum tank or something?
Marcel
Old Jan 23, 2017 | 01:27 PM
  #121
Welwynnick's Avatar
2006 S600
Don't run the pump when you evacuate. Vacuum filling is static bleeding.
Nick
Old Jan 23, 2017 | 06:54 PM
  #122
2004 S600
I have best luck starting with as empty a system as possible.
Old Jan 24, 2017 | 01:08 AM
  #123
Ok, I will try to use a vacuum tank, this might make the process a little easier
Old Jul 21, 2017 | 01:55 PM
  #124
I have one question concerning the intercoolers. I already installed the Renntech heat exchanger + pump upgrade and made sure that the system is bled properly.
I am running a Renntech tune which should provide between 670-680hp and 1150NM (limited) This was a noticeable improvement, especially at higher speeds.
Will an intercooler upgrade be worth the effort and lead towards a similar jump in performance or does it only help the car to stay cooler?
Slightly off topic, sorry: Will reinforcing the gearbox (by Renntech or MKB) and removing the torque limiter (which leads to 1200-1250Nm) help the car to be faster at speeds above 150 km/h or is it not worth the effort and cause more harm than good? If it only creates wheel spin and stress even at high speeds, I won't do it.
I do not want to modify my car any further by trying to get more horsepower, I just try to make use of everything the car already got by addressing the two bottle necks, transmission and cooling. Thats the reason for my two questions.
Old Jul 22, 2017 | 04:21 AM
  #125
Welwynnick's Avatar
2006 S600
Better intercooling will always increase power, but the Renntech pump is pretty good, and I don't think any further gains would be great. Zeph and I both have an BMW X3 engine radiator for an HE, so we went a bit overboard.
What does the Renntech HE look like?
Nick
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
