M275 V12 Bi-Turbo Platform Technical discussion relating to models sharing the M275 V12 Bi-Turbo (V12 TT). Including SL600, SL65 AMG, CL600, CL65 AMG, S600, S65 AMG.
Question about MAP reading from the OBD II
Old Jun 18, 2012 | 09:52 AM
shardul's Avatar
Former Vendor of MBWorld
2003 W211 E55, 2003 W220 S600
I have a 2003 S600 V12TT. When I connect my Actron scanner and look at the MAP reading I am seeing abot 150 KPA which equated to 20 psi at WOT for a couple of seconds. At idle it is 33kps which would be about 4.5 psi
My question to you is that does the 150 KPA include the baro pressure? If it does that means I am boosting only 5 psi?
I spoke a reputated board member about this yesterday and all the S600 he has logged via a scanner the baro pressure has to be subtracted.
My car feels quick but then I have not driven another S600 so I have nothing to compare to.
Old Jun 18, 2012 | 11:23 AM
1995E320Cab's Avatar
2003 CL600 2005 745Li
On another note, did you do the ECU / TCU reset yet ?
Old Jun 18, 2012 | 12:22 PM
shardul's Avatar
No I have not. I have disconnected the battery for extended periods of a time, this may have reset the ECU. I will try the TCU reset.
Old Jun 18, 2012 | 12:31 PM
It made a crazy difference with my 600, I think most 600 drivers really baby their cars so the car adapts to that.
Old Jun 18, 2012 | 01:35 PM
shardul's Avatar
Any info on the map readings?
Old Jun 18, 2012 | 02:30 PM
None sorry
Old Jun 18, 2012 | 08:23 PM
dtohio's Avatar
05,cl65;33ford3wc.
Well if they follow thier terminology, map means manifold absolute pressure which means your only getting five pounds of boost from your twenty pound reading as you suspect.
Old Jun 18, 2012 | 09:17 PM
shardul's Avatar
Hmm time to check for boost leaks. Any pointers?
Old Jun 19, 2012 | 01:31 PM
dtohio's Avatar
05,cl65;33ford3wc.
I havent much experience here, but I doubt a plumbing leak. turbo boost is primarily controlled by the turbo wastegate/ecu set up. Remember how much trouble others on this site have with bad intercooler pumps and clogged catalytic converters.My gess is a search on this forum would yeild a lot more imfo.
Old Jul 4, 2012 | 03:53 PM
Any updates on this?
I'm expecting great things coming from you on your S600 and its V12TT, what do you have planed ?
Old Jul 6, 2012 | 06:34 AM
shardul's Avatar
I installed a temporary boost gauge and the readings were in sync for what a stock car should produce about 13 to 14 psi at wot. As of now the car is in the shop getting a custom primary and secondary heat exchanger installed. A fellow member adam has been very helpful in answering by novice questions
Old Jul 13, 2012 | 03:16 PM
Welwynnick's Avatar
2006 S600
I logged MAP last night, and I also got around 30 kPa at idle. However, on WOT I got a max of about 240 kPa at 3000 rpm. That equates to about 20 psi above atmospheric.
Nick
Old Jul 17, 2012 | 01:46 PM
Benz-O-Rama's Avatar
I'll log MAP using my scanner for you and we'll compare. I'm tuned, as you know. But if memory serves, and it's been a good while since I've looked at MAP, but I always had to subtract atmo. For quick and dirty, I just minus 13.7
Also, keep in mind that stock K24s spool up quickly, so we don't have turbo lag. But they run out of breath VERY quickly and only hold peak boost for a short time.
I'll try to get a run logged for you. It's a million degrees up here in DC this entire summer, so I'll no doubt be heat soaked.....
Old Jun 27, 2015 | 05:10 PM
razb0yn1k23's Avatar
a few AMGs
hello can anyone help me to complete my boost gauge installation on my cl600 tt i need some detailed info pleas looking for help. thanks mbworld
Old Jun 28, 2015 | 04:45 PM
ItalianJoe1's Avatar
2003 CL 600
What do you need help with? Why are you adding a boost gauge, what other mods are done to the car?
