ATF fluid (Life Fill) MBTech Help!!
"Dear Mr. Busch
The approved ATF for your vehicles are listed below:
Castrol Dextron III/Mercon ATF
Castrol Transmax M-22257
Chevron ATF Dextron III
Citgo Multipurpose ATF
Exxon Superflo ATF Dextron III
Havoline ATF Mercon/Dextron III
Texaco ATF Mercon/Dextron III
Pennzoil ATF D-22413
Quaker State Dextron III/Mercon
Sunoco ATF Dextron III/Mercon
Unocal Multi-Purpose ATF D22413
Valvoline ATF Type D
*Mobil 1 syntetic ATF is not approved for use in your vehicle*
If you have further questions, please contact our Customer Assistance
Department at 1-800-367-6372
Surya Boonphadung
Elite Customer Assistance Coordinator
Mercedes-Benz USA LLC.
1-800-367-6372 ext. 4661"
Well what do you guys think?????
Subject:
Mobil
Date:
Mon, 17 Dec 2001 10:27:53 -0600
mobilproducts@ourdataworks.com
To:
Thank you for your inquiry:
Unfortunately, Mercedez Benz insists on using only Mercedez approved
fluids. We do not have the Mercedez approval on our fluid. You will
need
to obtain the fluid from the Mercedez dealership.
Technical Support Engineer (LWK)
The above information is provided in good faith based upon the
information presented by the customer. ExxonMobil is not responsible for
any loss or damage resulting from inaccuracies or errors in any of the
information provided or any acts or omissions taken in response to our
advise.
If you read about it on some of the topics on atf, you may wanna buy my car after all.
In my Dodge Ram I use ATF +4 direct from Mopar. My opinion(note I said opinion) is transmissions should only use factory fluids. The cost difference between fluids is cheap insurance to me.
140-991-00-55 Lock Pin ($2.09)
BG3124 Synthetic Fluid ($116.95)
BGK6600 Auto Trans Flush (I assume that this is the machine used). ($22.95)
I also got the brake fluid and power steering flushed. Here is the power steering information:
BGK6700G (I assume that this is the machine). ($93.95)
I got an acura from my uncle years ago he went to a lube shop and they put non factory atf in the tranny it shifted like crap
I changed it out to honda stuff (2 changes) and it shifted like new and has for 100,000km now
same with my dodge dakota atf+3 for that and 506,000km it shifted perfectly when i sold it
use the MB stuff better safe then sorry!
http://www.mobil.com/Italy-English/L...il_atf_134.pdf
. You can tell by their writing and their phone etiquette.
Given they don't have that support mechanism I would have to make the leap that some 'other' oil company produces the lubricant and puts MB label on it.
UMMMm I wonder...
UMMMm I wonder...
Any time they change fluid specs, which was done when we went to 134, it usually will first come in it's original packaging(Mobil)...that is until benz can print their labels up and slap them on.
There always seems to be a problem with European manufactures and specified oils or lubricants. Ducati recommends Shell Advance 4, but is impossible to get in the US.
What is the best method for removing all BG ATF from my transmission and replacing with MB approved ATF?
I've read all of the DIY docs on this forum. I know that I can simply drop the pan, install a new filter, reinstall the pan, then flush thoroughly with an MB approved ATF.
However, if using the above-mentioned procedure, will the new filter become "contaminated" with the old BG fluid that is being flushed out of the system?
2) If it can't be confirmed OR is confirmed not meeting spec the only thing you can do is a power flush to remove the old fluid. It is possible to do at home by removing pump suction line and return line then pumping new fluid through until previous fluid is removed. I would prefer to have a professional do it and do the correct flush.
3) If it meets the spec don't change it. Since your MB dealer did this and will have to warranty the work you might call MB service rep and confirm they did the correct procedure / fluid. Perhaps they just errored and will install the correct fluid.
Take a look at the attached Star Bulletin that I just located. I'm thinking that it could prove useful when I talk to the service manager since it specifically states to "Only use the transmission oils...in sheet 236.14." MB can't make it much clearer than that. I've looked all over the place and BG ATF is not listed on any of the MB sheets that I've seen.
I don't have a problem flushing it myself if it comes to that. My only concern with flushing it myself is contaminating the new filter. Is it possible to flush out the old fluid without comprising the new filter? Would it be safe to flush the system without a filter installed?
I sent an email to MBUSA this evening requesting their official response to the work that was performed by my local MB service center and the fluids that they used. I guess I'll eventually have to discuss this issue with the service manager where they performed the work.
If it doesn't have the spec on the product and it is word of mouth, won't hold up in court. It must be on mfg spec sheet OR label stating meets spec.
If not it doesn't. Just say, show it on the spec sheet or label in writing.
If the BG transmission fluid is NOT approved by Mercedes, why would ASC use a non-approved fluids?
I have since moved to Williamsburg VA and spoke to the service writer at Tysinger Mercedes in Hampton, VA. I asked him how they performed the transmission service. He said that per Mercedes guidelines, they drop the pan, change the filter and install new fluid (approximately 4 or 5 quarts). They do not flush or drain the entire system and does not offer that service.
My cdi currently has 90k miles on it. I am at least happy that the filter will be changed, but my concern is the mixing of the BG and Mercedes fluids. I plan on getting this done in August as I have an inspection due.
Mike T.
