Unknown Engine
Left->What is this part?
Middle->There is a screw missing there and the engine sound awful because of that. I have tried to screw one into place but it won't screw. Can I do anything about it?
Right->What is that? Is it a sensor or something?
I'm a total noob so please don't laugh at me if these are silly questions
The circled item on the left is the EGR valve (emmisions equipment). Unless you need to get your car inspected, don't worry about it.
The item in the middle is a bolt for the injector cover. Unless the cover is rattling and annoying you then I wouldn't worry about it.
The item on the RHS is the coolant temp sensor. Looks like it was retrofited there for your installation because i can see the wiring across the engine bay.
Any other questions?
About that bolt....The cover IS rattling and it is extremely annoying. I found a bolt but it won't screw. I don't know what you call it in english but that thing that the bolt screws on must be broken. Can I do anything about it? Is it repairable?
not sure on power, from memory it was around 70-75kw and 160-180nm
if the bolt won't hold then you can try a larger bolt or get a helicoil kit and fit a new thread.
