---> CALI's hands-on ... STABLE CHASSIS VOLTAGE !!!
Old Feb 9, 2025 | 06:12 PM
  #601
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Originally Posted by KristiyanPetrov
when i search for 10w40 SP is it a problem if it's not MB Approved?
The way I understand "MB Approval" is it's a limit to 0w40 or 5w40 rating, nothing outside of that range.
So you're not going to find any 10/15w40 or 5/10w50 in any API SN/SP formula.
Motul 5w40 happens to be "MB Approved"
The non Approved higher viscosity cary the risk of higher abuse reflining unbalanced engines... so they must be used responsibly... can be rev'ed up safely with balanced-contribution engines.
Old Feb 9, 2025 | 06:19 PM
  #602
preferring cleaner SP over older SN
here in BG we have distributor of Amsoil but i saw it's API SN since Cali suggestion im chasing API SP
Yeah keep your targets straight!
cleaner burning is where we're going:
less burned oil,
less carbon,
less ZDDP
gets cleaner Lambda... better fuel maps!
Try the oil you like then dump it when it carbons up, hopefully after 3 to 4kMi, not 1k
Old Feb 9, 2025 | 06:26 PM
  #603
KristiyanPetrov's Avatar
C43 AMG '17 / Stage II
So you're not going to find any 10w40 or 10w50 in any API SN/SP
just found somewhere you talking about this, that if you want better oil you have to kind of sacrifice "MB Approval" label on the tube
so next oil it will be again motul 5/40 gen ii BUT SP or.. motul 5/40 power SP or maybe if you recommend some good 10/40 SP that i can look if i can find it in Europe to pre order it
Old Feb 9, 2025 | 06:34 PM
  #604
You know all oils are good, for some time.
It's not easy to find a great one.
Ultimately what separates them is the test of time.
How good for how long?
I want a good W40 to work stable VVT gear so I use light w50. Not too high either so it helps seal without perfect seal either - ITS A BIT OF A BALANCING ACT based on engine temps.
I may bump 100mL shots if 5w50 thins out before 5kMi mark then I may upgrade to a 10w50 or try a different 5w50 JR is using
Old Feb 9, 2025 | 06:50 PM
  #605
can i do this and is it safe:
5/40 motul gen ii SP or 5/40 motul power SP and add X amount of ML of 5/50 motul power SP?
Old Feb 9, 2025 | 07:07 PM
  #606
I have done exactly that when 5w40 viscosity was dropping too low.
I used measured shots of 100mL gradually... go easy.
Old Feb 9, 2025 | 07:12 PM
  #607
hmmm okay, so you don't bump W while is fresh and instead you do it when you see W goes down (when start losing it's nice color on white paper )?
Old Feb 9, 2025 | 07:14 PM
  #608
W205C43PFL's Avatar
That is how I understand it too, the approved means EPA approved
Old Feb 9, 2025 | 07:21 PM
  #609
W205C43PFL's Avatar
Sorry for stating the obvious but make sure to siphon the old oil out and not just add the new oil or you will overfill the oil. The equal amount you remove and add. Always check the dipstick : )
Old Feb 9, 2025 | 07:39 PM
  #610
W205C43PFL's Avatar
W stands for winter, but you know that already : )
Old Feb 9, 2025 | 07:40 PM
  #611
upgrading viscosity by steps
That is a good point!
When I replace fresh oil, I keep level between Min/Max so I have room to play around a bit.
Besides engine burns enough of thin oil there should be room for 1 or 200mL of booster shot.
Playing with booster shots on 5w40 oil still clean is a good learning preview for how effectively VVT respond... it is touchy! You'll get to experience the relationships I describe next...
Old Feb 9, 2025 | 08:08 PM
  #612
NUGGETS
  • low viscosity causes:
  • low oil pressure causes:
  • poor VVT positioning causes (*Tensioners!):
  • jittery CKP timings causes:
  • combustion misfirings causes (*ALT-ECU!):
  • lean mixtures causes:
  • laggy throttle causes:
  • confused gearbox causes:
  • causes sloppy shifts!
Using adequate engine oil viscosity helps tranny shift seamlessly with engine demands.
> Extreme heatsoaks FAN:ON are caused by a combination of:
  • Laggy fuel map
  • poor timings
  • dry pistons
  • slow-learning Tstat
Extreme heat gradually gets normalized as a result of engine improvements.
Old Feb 9, 2025 | 08:54 PM
  #613
W205C43PFL's Avatar
Always happy to hear you playing it safe : )
Old Feb 9, 2025 | 08:57 PM
  #614
W205C43PFL's Avatar
  • Laggy fuel map
  • poor timings
  • dry pistons
Great summary, someone pin this : )
Old Feb 9, 2025 | 09:58 PM
  #615
JOURNEY... NO MYSTERY
The self-improvement journey begins with
  1. Stable oil pressure + voltage
  2. results in precise throttle response then
  3. results in precise tranny response then
  4. results in precise engine heat mgt
These results can be summarized by precise conditions are essential to GDI timings.
The more variabilities are chased away the more stability and predictable power are regained.
Interactive:
Engine conditions is what limits improvements managed by ECU.
Journey is 5 to 15kMi long: don't rush to redline prematurely so your engine balances to get a whole lot more later.​​
Unsmooth timings will limit progress.
Old Feb 10, 2025 | 07:58 AM
  #616
W205C43PFL's Avatar
Interactive:
Thanks for taking us on the ride.
Old Feb 11, 2025 | 03:13 PM
  #617
just found my invoice from last service and i notice SKU of Motul oil is the one that is SN and not SP..
so i will know for next time to check the bottle for SP label OR if i order it online to have this SKU 112351 - 5L and 112351 - 1L
@CaliBenzDriver btw do you service your gearbox with oem oil or you found better one
Old Feb 11, 2025 | 04:23 PM
  #618
W205C43PFL's Avatar
Interesting.
Old Feb 11, 2025 | 04:48 PM
  #619
JettaRed's Avatar
Veteran: Army
I use Pentosin (a.k.a., Fuchs). I'm not sure there is something better, but I'm sure there is something equally good.
Old Feb 11, 2025 | 05:00 PM
  #620
well if we consider that i was thinking AMG oil was good and after i learned some stuff for oil and specifications, now i know is complete trash, so i will be not surprised if there's better choice for tranny than OEM
Old Feb 11, 2025 | 05:26 PM
  #621
W205C43PFL's Avatar
Where did you get your transmission mount, my local dealership said it is sold out nationwide Canada and he said he can't order it because Germany is not making them and went on to say sold out globally, what in the world. Matter of fact I called multiple dealerships and they said the same thing.
Old Feb 11, 2025 | 05:38 PM
  #622
wow that's strange..? my one was ordered through MB dealer and was on pre-order so i wait around week and a half to come from Germany.. i might find locally for you but to send it abroad not sure what will be the postage..?
P.S. just checked my invoice and this is the part no: А2132400300
Old Feb 11, 2025 | 05:40 PM
  #623
W205C43PFL's Avatar
Ya I find it strange as well, when did you make the order? Maybe the shortage started this month or this year in case you were able to order last year?
Old Feb 11, 2025 | 05:41 PM
  #624
W205C43PFL's Avatar
Something is clearly going on since FCPEURO also shows backordered: https://www.fcpeuro.com/products/mer...eco-2132400300
  #625
early Dec last year, please check my prev post above your one i added info from my invoice like part no
