ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Ansel BZ700 Scanner
Old Nov 29, 2023 | 06:44 PM
Joshinator99's Avatar
ML 63 AMG
Ansel BZ700 Scanner
Got this scanner on a “Black Friday” special (that you can still magically get for the same price lol) for just over a hundred bucks. It has “Mercedes-specific” scanning functions for resetting replacement batteries, resetting brake pad sensors, etc. For such short dough it seemed pretty cool. I can scan and find faults in body modules, HVAC modules, etc too. And of course it’s an OBD-II scanner as well. My one beef is it will tell you there are faults in some of these modules (and let you clear them) but doesn’t know the names of all of the faults which is a little aggravating. But for the money it seems decent. Anyone else use it?
Amazon Amazon
Old Dec 15, 2023 | 12:12 PM
W205C43PFL's Avatar
https://www.amazon.com/dp/B0B2NR31DQ...t_details&th=1
Hmmm, never heard of it (this specific model mentioned on the forums, or I missed it) what are your impressions so far with it, OP?
Old Dec 15, 2023 | 07:32 PM
ML 63 AMG
Originally Posted by W205C43PFL;[url=tel:8892675
8892675[/url]]Hmmm, never heard of it (this specific model mentioned on the forums, or I missed it) what are your impressions so far with it, OP?
So far it seems like pretty good bang-for-the-buck but very limited use (mostly just what was in my original post). For $100, to get something with several MB-specific functions seems like a deal. Be handy for flushing brake system or changing brake pads, recognizing new batteries, etc. Probably not curing cancer with it. 😂
Old Dec 15, 2023 | 08:05 PM
W205C43PFL's Avatar
Thanks OP
Old Dec 15, 2023 | 08:42 PM
ML 63 AMG
Thanks OP
If there is a particular function you want to know about, just post it up and I’ll see if it has it. .
Old Dec 15, 2023 | 08:45 PM
W205C43PFL's Avatar
Sounds good, forum members often ask about scanners that can perform the rodeo, is this one capable (not like I have a car with ABC but I am curious)
Old Nov 25, 2024 | 09:54 AM
ML 63 AMG
Just an update as I’ve had a chance to finally play around with this scanner… TLDR; it’s garbage. Not sure what the point of buying an MB-specific scanner is if it can’t do anything beyond a typical OBD-II scanner? It can’t register a new battery (even though it’s advertised to) and it will tell me that other modules have error codes…but it can’t tell me what the code is… So if you’re looking for a good MB scanner, this Ancel junk isn’t it. 👎
Old Nov 25, 2024 | 12:13 PM
W205C43PFL's Avatar
Yikes, I am sorry to hear that, if you still need a scanner forum members often recommend Launch CReader V2.0 Elite Benz or just go full out and get XENTRY.
Old Nov 26, 2024 | 03:47 PM
Blk63bk's Avatar
Current: 2007 ML63, 2008 CLK63 AMG Black Series
Thinkdiag+ has been a lifesaver TBH. For <$200 it can code modules and perform special functions. recently coded out the SOS light and re-coded my rear SAM
Old Nov 26, 2024 | 04:10 PM
W205C43PFL's Avatar
neat stuff, there is also this thing: https://mbworld.org/forums/c-class-w...bd-device.html
Back to the Launch scanner for a second, not sure about coding but it at least can change certain parameters such as:
https://mbworld.org/forums/e-class-w...-2-0-benz.html
https://mbworld.org/forums/e-class-w...-reader-2.html
https://mbworld.org/forums/g-class-w...disabling.html (this might not had been successful)
https://mbworld.org/forums/e-class-w...31-coding.html
https://mbworld.org/forums/e-class-w...nk-remote.html
https://mbworld.org/forums/e-class-w...ite-2-0-a.html
https://mbworld.org/forums/e-class-w...-euro-ils.html (I don't think this particular was successful)
