Considering 2018 S 560 Coupe. Should I or Nah!???
I'm considering upgrading from 2014 CL 550 4Matic to a 2018 S 560 4Matic Coupe. My CL runs like it did the day I bought it, zero issues.
Anything I should know about the S 560 before pulling the trigger?
I bought my 2019 S560 coupe brand new. It has been trouble free and is the favorite amongst my other 2 MB's. I will NOT sell it. It is a keeper. Althiugh it may be lacking in some late model equipment I will keep it due to it's reliability. I have not had the first problem, big or small, with this vehicle.
Ron
I'm really loving this 2018 that I have my eye on.
White Designo w/ Red interior. 🔥
and this: https://mbworld.org/forums/s-class-c...d-c-217-a.html
TLDR: yes the S560 coupe is great
Trenton O. Gibson
tgibson@highline-autos.com
Highline Autos
Direct: 602.909.9216
Office: 480.348.0777
There were some issues.
A coil pack caused misfires. I isolated the faulty one but then decided to just replace all of them. Did this myself.
While replacing the coil packs and plugs discovered there was some oil in some of the plug wells. This is caused by minor leaks in the valve covers. If you're familiar with older cars you may be thinking that's something easily handled. On most modern overhead cam engines, especially with direct injection, it's a fairly big job to replace the valve cover gaskets. Actually, there's no gaskets, just sealant. Probably why they leak. One theory is it's the oil separators clogging. On some engines this can also lead to a rear main seal leak. I checked the separators and they weren't clogged. My view is the leak wasn't bad enough to fix. I'll check the plugs occasionally.
The car has the ILS LED headlights, which in the US gives you just automatic high beams and some steering of the lights in turns. The left headlight has a subtle fault that will cause the advanced features to become inoperative. Doesn't affect basic operation or manual high beams. This fault came with the car when I bought it, no extra charge. I didn't get a warranty. I'm in the process of solving this one on my own. Needless to say, headlights are very expensive on these cars.
If you're not a DIY type, then I suggest getting a warranty if possible. If I buy another one I think I would also get a warranty since this is our daily driver.
One other item. Most S class cars depreciate from new fairly rapidly based on mileage. If the car you're looking at has unusually low mileage then be cautious. Odometer blockers and other methods are readily available out there. It's possible to spot this using diagnostic tools since mileage is stored in more than one module within the car.
Yes, I would buy another one. I prefer the coupe so newer options are going to be limited. I think 2021 is the last year for the coupe.
So far I am pleased. Nice 300 mile trip home and I put her to the test.
The 9 sp trans seemed a bit more responsive than my 7 speed.
I think I got the right one.
Had been looking all over for over a month.
