Sunroof problem, please help!
Old Sep 28, 2010 | 09:36 PM
tuflon's Avatar
w220
I recently got my headliner in my 03 s500 redone because the previous owner had stained it. Now, when go to open the sunroof it moves a few centimeters then stops, and I have to keep hitting the button repeadtedly to get it to fully open. The weird thing is, it closes fine without problems. The tilt function is also acting funny.
I did the push gas 5 second ect ect thing to reset the ecm but it didnt help. I also tried holding it in one position for 10 seconds and that didnt help either. The interior guys said that they called the local benz dealership and they said that sometimes if you disconnect a certain swich(involving the sunroof) that if it is going bad, it can cause it to get worse by disconnecting it(sounds like bs).
Any ideas? The material that I switched the headliner to is thicker if that matters.
Thanks guys, I really need help here
Old Sep 29, 2010 | 01:28 PM
Corsa9000's Avatar
2004 S55 ///AMG, 2007 E350
I think it is supposed to open in two stages. First time you push the button, it opens partially, second hit will open completely.
Old Sep 29, 2010 | 01:51 PM
Trinsoca's Avatar
2005 S500
mines opens with the first push. sometimes it closes and stops and i have to push the button again. This is when the tracts may have some thing in them so try cleaning the tracts and lubricate (not sure what MB uses). it is like the door windows if something blocks them they will stop and go in the opposite direction for a while.
Old Sep 29, 2010 | 06:50 PM
tuflon's Avatar
w220
Thanks for the help so far guys. Maybe I didnt explain what its doing properly. When I hit the open function,it opens about 1/2 inch, then I release the button and hit it again and it only opens another 1/2 inch. I have to keep on repeatelly hitting the button probally 20 times to get the roof fully open.
Old Sep 30, 2010 | 12:57 AM
andrica11's Avatar
2003 Mercedes S-430
cassette
hey i have the same problem on my s430. It started to act like that and then i just left it closed for a while and now it never opens. I was told its the sunroof cassette thats messed up. A new cassette is 1800 to replace so i just keep my sunroof closed. just make sure u dont open it too far and then cant close it.
Old Sep 30, 2010 | 10:31 PM
regalchef's Avatar
2000 S500
sunroof problem
I too had the problem open the sunroof all the way when it is fully open keep your finger on the button for 5 to 10 seconds close it and see if it works if not try 1 or 2 more times that usually frees it up mine works fine now good luck
Old Sep 30, 2010 | 10:46 PM
Das Geld 2's Avatar
SL55, S500
It's out of sync because the battery was disconnected.
The method is somewhere here, I think you hold up key few seconds and then out key. You basically reprogram it. It's an easy fix.
Old Oct 1, 2010 | 03:26 PM
tuflon's Avatar
w220
PROBLEM FIXED!! Turn ignition to on position, hold the tilt button until its fully tilted then continue to hold the tilt button for a few seconds until you hear a click sound. Then its fixed.
Old Oct 1, 2010 | 03:48 PM
ohlord's Avatar
See if you
can reset resync it via your express feature on the key.If the car is so equipped.pop doors keep pressing key after door popped until sunroof is open.lock doors repeat holding till sunroof closed.
Old Feb 7, 2025 | 04:56 PM
tsm925's Avatar
w220 s350
Thank you, this worked for me!
Old Feb 7, 2025 | 04:57 PM
tsm925's Avatar
w220 s350
Originally Posted by tuflon
PROBLEM FIXED!! Turn ignition to on position, hold the tilt button until it's fully tilted, then continue to hold the tilt button for a few seconds until you hear a click sound. Then its fixed.
