OEM Spark Plugs
Old Nov 3, 2010 | 12:16 PM
Das Geld 2's Avatar
SL55, S500
OEM Spark Plugs
I did the search and there was no definite answer on the OEM Plugs other than Bosch Platinum. What's the exact part number? I did a search on AutohausAZ and found these:
http://www.autohausaz.com/search/pro...2@Spark%20Plug
Is it 7422?
Old Nov 3, 2010 | 01:37 PM
ohlord's Avatar
Bosch
7422 is the most effective plug for your engine.
Avoid multi tip they lead to issues.
Use no anti seize
Old Nov 3, 2010 | 02:42 PM
Corsa9000's Avatar
2004 S55 ///AMG, 2007 E350
Use no anti seize
Why no anti-seize?
Old Nov 3, 2010 | 04:57 PM
xexpo's Avatar
2000 S430 140k (07/11)
What kind of issues would come up if 4418 (Platinum +4) or 4501 (Ir Fusion +4) used?
Old Nov 3, 2010 | 05:23 PM
ohlord's Avatar
The plugs
are plated with trivalent metal so no longer need anti seize like the old days.
Use of anti seize affects torque settings and also can lead to plugs shorting if used incorrectly.
M112 and M113 engines are known to experience misfire issues related to multi tip plugs. They offer no increase in performance too boot.
17mm special boot tool
Old Nov 3, 2010 | 09:54 PM
Corsa9000's Avatar
OK, thanks OhLord.
Old Nov 3, 2010 | 10:58 PM
Das Geld 2's Avatar
SL55, S500
Thanks!
Old Nov 4, 2010 | 12:28 AM
ohlord's Avatar
Tighten
to 20-30Nm 15-22ft lb torque.
Corsa9000 the 04 55 engine calls for a 2 range cooler plug
NGK ILFR6A http://www.amazon.com/NGK-ILFR6A-Las.../dp/B001MU112I for performance applications or the bosch 7422
still single electrode
about $80 more for 16 plugs the ngk
Plug oem standards are still one of the things that Mercedes lists in the tech section of owners manuals
They are getting stingy with tech info in the hopes that if they make part choices or fluid types tough to find info the average owner will just go to the dealer and pay for a thousand dollar spark plug change that they could have done in a few hours for 100-200 bucks and a few beers
Old Nov 4, 2010 | 01:40 PM
xexpo's Avatar
Good stuff, thanks ohlord.
Old Nov 10, 2010 | 04:28 PM
indigo_kid's Avatar
06' C-230
Originally Posted by Corsa9000
Why no anti-seize?
I have the basic question.
Should I put any anti-seize when i replace my spark plugs this weekend??
(i have a M272 engine)
Thanks!!
Old Nov 10, 2010 | 04:32 PM
xexpo's Avatar
Read ohlords's #5 post about the use of anti-sieze.
Old Mar 29, 2017 | 12:09 AM
myscion04's Avatar
W211
I have a 2003 E320 and I am looking for plugs also and don't know which are best.
Old Mar 29, 2017 | 03:38 PM
Welwynnick's Avatar
2006 S600
Have you read the owner's manual?
You can download it from MB USA.
Nick
Old Mar 29, 2017 | 07:49 PM
amstel78's Avatar
Veteran: Army
2006 W220 S65 AMG
Old habits die hard I guess. I used a little bit of anti seize when I changed the plugs on my M275.
