Max speed in a S600
Old Sep 30, 2011 | 02:24 AM
benzdreams9's Avatar
04 s600
Max speed in a S600
Whats the top speed my 2004 S600 can get to? Is there a limiter?
Old Sep 30, 2011 | 05:55 AM
1989amghammer's Avatar
2008 MBZ s550 - 2006 MBZ s600
Electronically limited to 155 mph.
Old Sep 30, 2011 | 07:57 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Not mine
Get a tune, and have them change it for you. Mine is at a nice safe 199.
Never want the boys in blue to see 2 as my first digit
PS: Eurocharge for the win
Old Sep 30, 2011 | 10:02 AM
fhfwolfy's Avatar
2001 S600
Not so sure about the 155...Many of the cars for America were limited to 130 due to tires. The German models are 155 but just wouldn't guarantee it is that high on the American version. I have seen the specs for the TT at: Sub 5 seconds 0-60 and a top speed of 186
Old Sep 30, 2011 | 10:07 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Although what you say is true/fact about MANY USA cars, I can assure you my STOCK S600 would do well north of 130MPH. Never did hit the top aka 155 stock, but It did see north of the 130, in Mexico of course.
Old Sep 30, 2011 | 10:12 AM
fhfwolfy's Avatar
2001 S600
Hence the "many" not "all" part As a pure mental exercise though unless you intend on actually testing the limiter just go with the published top speed of 186 (unmodified) and a 0-60 of <5 seconds and about a 13 second quarter mile when your friends ask. Obviously I am not talking about AMG or Brabus before I get people screaming at me.
Old Sep 30, 2011 | 01:20 PM
abeprieto's Avatar
CL 600
I have a CL600 and i have done a few miles over 130, car doesnt exceed 13X
Old Sep 30, 2011 | 01:59 PM
MRAMG1's Avatar
S600, GL450, GLC 43
Buddy, I have been racing for a LONG time now. Think decades here as I am an old fart I know exactly whatever car I am driving does
PS: My 0-60 best is 3.91 by the way 4.0's are common now.
And I do apprecieate your Many not ALL comment
Old Sep 30, 2011 | 02:13 PM
babyman1737's Avatar
2005 CLK500 cab, 2004 S600 designo mocha
Mods / tires? There's no way this is on factory tires is it?
Old Sep 30, 2011 | 10:49 PM
tusabes's Avatar
Mercedes
The USA spec s600 Is indeed limited below 139mph.
You need to remove the limiter to go faster
Old Sep 30, 2011 | 11:06 PM
04 s600
How can I remove the limiter???
Old Oct 1, 2011 | 09:07 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Eurocharge tune
nitto 555 275's, NON drag raidials.
That's all my friend.
After a tune, these cars REALLY do become a beast
Old Oct 1, 2011 | 03:13 PM
classyS's Avatar
2001 S430
man....
i want a s600 with a tune and good tires!
Old Oct 14, 2011 | 04:47 PM
scarybary's Avatar
2004 S600
well my 2004 v12tt s600 was limited to 130 , i tried repeated times to go in excess and got to 134 but that was down hill with a tailwind. then i got a service provider to try and remove the limiter with th mercedes star system software but that never worked so i finally got a kleeman ecu and tcu tune and the sprint turbo booster, to minimize the drive by wire throttle lag , and i turned a fast car into a really really fast car , . since my speedometer stops at 160 i dont know how fast i can go , but i know its a lot faster than 160.
Old Oct 16, 2011 | 05:23 PM
Jerry-'s Avatar
2004 S600 (V220.176)
The Mercedes internal maintenance documents show that a stock S600 can do 305 km/h (191 mph) if the limiter is turned off (software). That seems a bit high, but then, who wants to argue with them.
Old Oct 16, 2011 | 05:46 PM
04 s600
Wheres the best place in SoCal to goto to get the limiter removed?
Old Oct 18, 2011 | 08:14 PM
Stephen04E55's Avatar
'09 CLK550, '18 AMG GTR, '06 C55 AMG, '25 GLS450, 09 E63
with the renntech tune my 03 S600 was going 156 at VIR back stretch. My S65 will go 158.
Old Oct 18, 2011 | 08:46 PM
Jerry-'s Avatar
This is the speed all European S600 (and S500, S550) do out of the factory, without a tune. The limiter in Europe is 250 km/h equals 155 mph; positive variances up to 4 mph are common.
This is the stock acceleration to 255 km/h (159 mph) http://www.youtube.com/watch?v=sCSaHPkQNDU
European tunes are often limited to 300 km/h due to tire limitations (V tire limit). Even S65 that can go faster are factory limited to 300.
With a tune and no limiter a S600 will exceed 200 mph
Old Oct 18, 2011 | 09:43 PM
Fraser's Avatar
A Mercedes obviously!
What about top speed in reverse?
Old Oct 19, 2011 | 08:13 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Just don't try and race ANY Toyota in reverse as they will hand you your ***
Old Oct 19, 2011 | 10:54 AM
Jerry-'s Avatar
I have the following two details second hand and do not know if they are correct.
1. Two reverse gears; Reverse Ratios 3.16 and 1.95 (Comfort Mode)
2. Acceleration to 50 mph about 5 seconds.
If the second reverse gear ratio is correct and given that the final gear ratio is 2.65, the overall ratio is 5.17. In that case you can get to 90 mph at 5900 revs. I wonder if the revs are limited though. If the revs are limited to 4000 rpm then the top speed would be 61 mph in reverse. This ignores slip and transmission train losses.
Old May 31, 2019 | 08:53 AM
jasontaylor7's Avatar
bmw 528i
Thanks for posting this information. It's not surprising. I've hypothesizes why on some answers I've written on quora. (See, e.g., https://www.quora.com/Where-is-the-b...ason-Taylor-16 .)
It would be nice if more readers posted this data. It's real easy to obtain. Let me explain how.
The speed limiter limit of the non 4Matic USA benzes can be discovered by going to an unhooked dyno. This is much safer than a road test. And, to save $100 one can just carefully jack up the rear tires, and floor it. You should over-inflate the rear tires slightly (~5 psi) beforehand to reduce the chance of a blowout as the sidewalls come in and middle of the tire bows out due to centripetal force. Of course, to increase safety you can place your foot on top the brake and park directly touching an obstacle, or you can do it where there a little empty space ahead. Stop the test if you have a shimmy because your car might walk off the jack stands. However, your car would not lurch forward to the tire speed in case the rear fell down. I think it is a good idea to do this test before any actual speed run to test tire speed ratings, since a blowout at high speeds is much more dangerous.
I wished more benz owners did this. Top speeds of sports cars are more important than you might be led to think.
Old Jun 1, 2019 | 01:18 PM
Kebowers47's Avatar
001 s600, 94 sl600
Mercedes s600 and their others are supposed to be limited to 135 MPH. Reason is TIRES max speed. Germany requires autos be sold with tires suitable for the max speed. After all, there are many locations there with unlimited speed allowed. US Purchasers,would not accept the short tire life and high cost of the tires rated for the max speed (class W?. ).
Old Jun 1, 2019 | 08:29 PM
Astro14's Avatar
Veteran: Navy
2005 S600 2005 SL600
Or, you can hook up your copy of STAR and read out what the limit is. It's in the ECU adaptations. Far, far safer than running the car with the wheels in the air, which strikes me as incredibly dangerous.
Mine was 210 KM/Hr, and I changed it to 250 KM/Hr.
Old Jun 11, 2019 | 01:16 AM
rowekmr's Avatar
Soon to be E55
What modifications if any were done to your car?
