2003 S55 key wont turn ignition and lights are blinking
Old May 26, 2017 | 11:38 PM
DirectAMG's Avatar
2003 Mercedes S55 AMG
I have a 2003 S55 AMG, Recently the battery died and I bought a new one, and now the key wont turn turn at all. Cannot put it into ignition. Headlights are blinking. Key also wont unlock or lock from remote. Ordered new key FOB from dealer, still no luck. Does anybody have any idea what the problem can be? Any help will be appreciated.
Old May 27, 2017 | 12:34 AM
DirectAMG's Avatar
Could it be the battery alarm siren causing all of these problems? The car was standing in the driveway for about 6 months before I changed the battery.
Old May 27, 2017 | 12:52 AM
hvacdude's Avatar
2006 CLS55AMG & 2005 S55AMG
Your battery is dead. Use the key that is inside the key fob to open the drivers door and the trunk. Battery is under the trunk carpet on the right side. Get a jump or charge the battery and have your alternator checked. Could also have something draining the battery when the car is parked. Alarm system has it's own battery that charges it self off the main battery. Yes, it can drain the main battery. I disconnected mine. It's a known battery drain issue. You're lucky if that's all it is.
Old May 27, 2017 | 12:54 AM
DirectAMG's Avatar
But I put a new battery in.
Old May 27, 2017 | 05:16 AM
tusabes's Avatar
Mercedes
You probably blew the main fuses Under the pasenger floor when changing the battery
Old May 27, 2017 | 05:21 AM
DirectAMG's Avatar
Do you know which fuses they are? The ones another backseat?
Old May 27, 2017 | 07:55 AM
wallyp's Avatar
2003 S500 2007 GL450
Pull the carpet up on the passenger side. the fuses are blocks under the metal shields.
There also is a possibility that the new battery isn't fully charged, and a small possibility that it is defective. "New" is not always the same as "good".
Old May 27, 2017 | 03:55 PM
DirectAMG's Avatar
so I found the fuse and got the key to turn but now it wont start just cranks. any ideas?
Old May 28, 2017 | 04:45 AM
tusabes's Avatar
Mercedes
If the fuse blew you might have damaged some other electronics too
need to get a SDS computer scan
i bet you blew the SAM or ecu-
and if it's the ecu which means you'll have to replace 4 parts if you take them from a used car - key shifter ecu and ignition switch . They must all come from the same car because they are mated together
Old May 30, 2017 | 12:25 AM
ibeforreal's Avatar
2003 S500 - Toyota Corolla (in the rain)
I always make it a point when disconnecting my battery to make sure I wrap a cloth or something around those cables to make certain they don't accidentally touch anything. I have seen too many sparks fly from a wrench or something else touching the cables while they are near the post causing numerous electrical problems.
Old May 30, 2017 | 01:25 AM
DirectAMG's Avatar
Update...
Changed the fuel pump relay today and it started right up.
I was thinking on putting the battery protector in there. Is it worth it? If so which one would you guys recommend?
Old May 31, 2017 | 07:58 AM
tusabes's Avatar
Mercedes
Originally Posted by lashchukv
Update...
are you looking for a battery tender to keep the car plugged in to a wall outlet and fully charged when not being driven ? Ctek and battery tender are the best brands
If you are looking for a battery protector to disconnect your battery when the car is not used , get the battery brain t3 sold on Amazon
it it has a remote keyfob which connects and disconnects the battery to prevent both battery drain and vehicle theft
Old May 31, 2017 | 08:06 PM
DirectAMG's Avatar
Ye im looking for the (t3) protector. Any difference between the (t4) and (t3) Which make would you recommend? Are they pretty easy to install?
Old Jun 1, 2017 | 07:54 AM
tusabes's Avatar
Mercedes
Get the t3
the t4 does not have the remote control to connect /disconnect the battery
super easy to install , it connects directly to the positive terminal on the battery
Old Oct 3, 2021 | 02:05 PM
dannycusuloss55's Avatar
2003 s55
im having the same issue what exactly was the fix? i saw you ended up finding the fuse but what exact fuse did you find? and how did you fix it?
Old Oct 4, 2021 | 10:05 AM
wallyp's Avatar
Which problem?
"the key wont turn turn at all. Cannot put it into ignition. Headlights are blinking. Key also wont unlock or lock from remote. Ordered new key FOB from dealer, still no luck."
"so I found the fuse and got the key to turn but now it wont start just cranks"
It would be much better to create your own thread, starting by giving full info on your car, including the market (lots of differences between USA, Europe, Japan, Middle-East, etc.), then telling us exactly what the symptoms are in detail.
