New member from houston
Old Jul 22, 2017 | 05:04 PM
W220 sclass's Avatar
02 s430
I have a w220 s430 that my voltage keeps dropping .. ive replace 3 altenators and 2 baterries in 2 months. Ive checked the x4 box and no blown fuses in front or back in the trunk any one onow what may be the problem
thanks in advance
Old Jul 22, 2017 | 05:14 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
thanks in advance
Cant help, but welcome to the club. Hopefully, someone can assist you.
Old Jul 22, 2017 | 05:19 PM
02 s430
Thanks man
Old Jul 24, 2017 | 10:57 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W220 forum...
Old Jul 24, 2017 | 12:45 PM
wallyp's Avatar
2003 S500 2007 GL450
"I have a w220 s430 that my voltage keeps dropping..."
No immediate answer, but perhaps a few questions will lead someone to a viable suggestion.
Do you mean that the system voltage will intermittently drop to a lower voltage reading, and then go back to a proper reading?
Or, do you mean that the system voltage was originally 14.4 vdc, then it was 13.6, then 12.9, etc.?
How and where are you measuring the voltage?
What is the voltage?
Does the voltage vary with differing conditions? How?
Are there any other symptoms, such as flickering lights, fan speed dropping, slow starter speed, etc., etc.?
Has any work been done to the car recently?
Old Jul 24, 2017 | 03:10 PM
tusabes's Avatar
Mercedes
Houston got some huge rain didn't it ? These cars get damaged in the rain
Your car probably has water damage under the carpet which is destructing your electrical system
see here
https://mbworld.org/forums/s-class-w220/265605-2nd-s-flooded-week-s-owners-keep-your-drains-clean.html
Old Aug 5, 2017 | 03:14 AM
02 s430
The car started at 14.2 v then it will decrease to 13.8 ,13.4 , 12.7 all the way to 9 volts . This will happen with time not in 1 one day im cheching the voltage in the ac panel were you have to hold the rest button and go to number 24 ... something is killing my batteries idk what is it all my sams seem fine i have the i carsoft scanner and nothing shows
plz help
Old Aug 6, 2017 | 02:44 PM
tusabes's Avatar
Mercedes
The navigation system and alarm siren box are two common causes of drain
have you removed the nav disc and pulled fuses ?
You can get a "remote battery disconnect " on Amazon for $49 to stop battery drain with the click of a keyfob remote until you pinpoint the issue
Old Aug 7, 2017 | 11:16 PM
02 s430
I wanna know what can be killing all these alternators and batteries.. i have no navi disc inn and pull what fuses??
