AC of light is not turning off (W220)
Old Mar 12, 2018 | 07:49 AM
asifnaveed's Avatar
Model 2002 (S500) Ford Explorer XLT 2013
hey, guys, i have MB S500 2002 model. my problem is AC off Light is not turning off and it is not letting the compressor to work. i have tried deleting the error by initiating the scan from Charcoal Filter and reset button press then i saw the error code. now if i press in the left Auto Air Button then press in the right Auto Air button and then press out left Auto Air and lastly Press out the right Auto Air button system should delete the code. but i have done it many times system is not deleting the code plz help if some one knows this problem
Old Mar 12, 2018 | 08:32 PM
tusabes's Avatar
Mercedes
did you check your refrigerant pressure ? Low AC pressure is most common reason AC turns off and cannot turn back on
Old Mar 13, 2018 | 09:36 AM
The Shoeman's Avatar
Mine 2005 S430 4Matic * Wife's 2005 S430 4Matic *
Good call. I was going to ask what turned the AC light on in the first place? Clearing the code doesn't fix the problem. If the refrigerant is still too low, you're not going to have the AC system work.
What was the error code? How many bars did the AC system show? If it is low (or empty) find out why. Must be a leak somewhere if it's really low.
Good luck and keep us posted with your progress.
Old Mar 13, 2018 | 08:02 PM
kraut56's Avatar
2009 E350 4M Avantgarde;mistress 2002 S600; wife 2014 C300 4M
If you search under my Nick here and on the other forum, I posted that problem. It required an SDS system to correct a detected software error deep inside the AC system menu by a reset (not with the usual reset).
Good luck!
Old Mar 15, 2018 | 03:22 AM
asifnaveed's Avatar
Sorry for late reply. your advice is well noted i will get it checked by today itself and keep you guys updated. just for your information i had the same issue almost a month back then i visited the MB repair shop (Not Stealer) he connected star and just erased the error and all went fine after that. but again i had this problem a week ago and i did not had the time to drive it or go to the work shop since i have another car. any how thanks for your advice again
Old Mar 15, 2018 | 03:23 AM
asifnaveed's Avatar
Sure i will get it check today
Old Mar 15, 2018 | 03:45 PM
tusabes's Avatar
Mercedes
The reset isn't fixing whatever the real problem is
and I'm guessing the real priblem
is low refrigerant , so it will just turn off again
Old Mar 15, 2018 | 11:56 PM
have you checked the 'REST' menu? Press and hold the REST button for about 10 seconds....a new menu will show up and you can arrow up or down to go through the different values of many different sensors. One of which is the level of refrigerant bars in the system. This will show (or not show) the problem with the refrigerant pressures.
Good luck.
Old Mar 16, 2018 | 10:28 AM
Welwynnick's Avatar
2006 S600
For all things regarding W220 climate control search for "ricebubbles acc" or go here:
https://www.google.co.uk/url?sa=t&rc...4fiMf2Lr10LEUo_
Old Mar 20, 2018 | 05:52 PM
asifnaveed's Avatar
i checked the refregrent it wa 8 bar then i connected the car with diagnostic computer and the error it showed was of evaporator sensor. I just cleared the code by cimputer and its working fine its been 4 days and still there is no problem.. on the other hand my question is why my car doesnt drlete the acc error by itself just like other w220s 😩
Old Mar 20, 2018 | 06:22 PM
Welwynnick's Avatar
2006 S600
W220 ACC doesn't re-set it's fault codes when the fault clears.
Very bad mistake by Mercedes.
Nick
