Ho, I have a 2001 s420 W220 which I love.
I am trying to install a back up camera but I do not have schematics. Was wondering if anyone can help me on this by showing me which pins I should use on the back of the deck to install the camera.
Thanks in advance
'00 S320 W220, '98 A160 W168/ sold in 2005 '86 260 E W124 '90 260E W124
What you need is a MMI-interface or an old analog MB-TV Tuner with an AV-Input (Cinch). A direct installation w/o any of the two mentioned components, is not possible. An other obstacle is, if you have an US-American Comand, there is no TV-key (and no TV-function) on your Comand. In that case it is more or less not possible, from my point of view. I can attach attach the pin out of the European Comand 2.5, later. If it helps, I don't know??
Pin Out Coamnd 2.5 EU
Here the European Pin Out of the Comand 2.5. However to connect a RVC you need the forementioned interface, or an analog TV tuner. For USA specs this may not work, as those Comands have no TV function. Here the solution with a KUFATEC MMI on a European Command 2.5
Thank you so much for the attachments and info. My car is American made but will steel give it a shot.
thanks again
thanks again
You can also check YouTube once was a track showing the trail to add a RVC. The guy basically dropped out, as the TV button/signal was not existing. Maybe you'll find other solutions there. Good luck
Okay! Thanks. Then everything should be set when I get the wires and C connector.
There is one more thing I wonder if I need. I see there is a wire called K-leitung coming from original car harness going into original Audio 10. This I have not connected to anything as of now, but I see on the C connector on the Comand, the same K-leitung input. What is it, and should I connect it?
I'm not exactly sure what function "K" has, but it goes from Audio 10 plug/pin A2 to the Comand 2.5 plug/pin C2. You need to change the pin size to the fitting size of the C2 plug
Hello what is the name of the connector (D) cable? I want to know the connector cable
What is rhe name of the connector (D) plz i want to know type of the connector
