LED license plate lights
Old Dec 3, 2014 | 03:20 PM
WHPH28's Avatar
Depends on the weather
I installed these LED units in about 15 minutes. They definitely are a huge improvement over the regular bulbs, especially for under 20.00. It's hard to tell the color in the pics but they are super bright.
Attached Thumbnails LED license plate lights-20141203_145717.jpg   LED license plate lights-20141203_145701.jpg
Old Dec 3, 2014 | 03:33 PM
Jason B's Avatar
W140 Mercedes S350, W221 S550 sport
You have a 07-09, correct?
Old Dec 3, 2014 | 03:36 PM
WHPH28's Avatar
Yes, 08. Back before these became standard.
Old Dec 3, 2014 | 03:46 PM
Jason B's Avatar
Cool. Yea, in 2010, the updated the bulbs to a whiter, hid look, but they are not leds, they are some kind of super white filament bulb still.
Old Dec 3, 2014 | 11:05 PM
aznevoviii's Avatar
G63 AMG
did this make your rear view camera impossible to see at night?
Old Dec 4, 2014 | 01:48 AM
Aceman1120's Avatar
2013 CLS550 4Matic
Replacing those lights on a 2010+ is a pain...a lot of stuff to take apart
Old Dec 4, 2014 | 05:51 AM
WHPH28's Avatar
I don't have the rear camera...I do plan to retrofit it though.
WHPH28's Avatar
Yeah, I had to remove everything, trunk liner, all the torx, plugs, etc..just tedious more than anything.
Old Dec 4, 2014 | 03:50 PM
Mandingo's Avatar
W222 S63 AMG
Mine makes rear view camera more effective at night by illuminating the area behind the car.
https://mbworld.org/forums/s-class-w...ml#post5906462
Old Dec 4, 2014 | 05:24 PM
Aceman1120's Avatar
2013 CLS550 4Matic
Yes, I saw a YouTube video and I am about to take on this task
Old Dec 4, 2014 | 05:44 PM
Jason B's Avatar
Report back after you do it. Like I said, 2010's have a super white bulb in them, the look led color, not yellow, but prob not as potent as true led.
Old Dec 5, 2014 | 06:16 AM
WHPH28's Avatar
I followed the youtube video by GoFastJames.
I was out last night and when I unlocked the car and saw the license plate leds light up, I was like wow, this looks so much better.
Old Feb 10, 2015 | 09:52 PM
mikos550's Avatar
s550
Do you guys know of any led/white bulbs that can be use instead of changing the complete housing/case for the license plate.
Old Feb 11, 2015 | 12:41 AM
ruflife1's Avatar
2008 S63, 2012 E550, 2005 E55, 2005 SL55, 2013 SL63, 2020 AMG GT, 1994, 1998, 1999, 2001 SL500
I'm using a T10 can bus error free bulb off of ebay for the license plate bulbs. Bought like 20 of them for $10 and used them to replace most of the bulbs in the interior also.
Old Feb 11, 2015 | 12:47 AM
jawilliams07's Avatar
S550
I admit I i thought they were crazy to charge what they did at dealer...till I did it and had to pull apart the liner and all lol but it was worth I know my trunk in and out now.
Old Feb 12, 2015 | 08:37 PM
WHPH28's Avatar
Looks good. At least you know how to do it now. If I ever have to do mine again, it'll be a lot faster since I did it once already.
Old Feb 14, 2015 | 04:55 PM
Garticus's Avatar
W221/S550
It is quite a bit to pull apart to change the license plate bulbs....but the LED upgrades are worth it.
Old Feb 14, 2015 | 10:28 PM
Jason B's Avatar
I've said this before but 07-09 license plates shine yellow/dull. 2010 is a bright white/pure white and they actually aren't led. They are like a super white kind of bulb. Don't know if most know this. I thought they were led but the looks of the color...
Old May 17, 2015 | 02:17 AM
snovvman's Avatar
I'm your huckleberry
On my 2013, the factory connectors are different from the 07-09 T10 (194/168/W5W) style connector. Clearly, the LEDs I bought won't work unless I change the connectors. See the photo below.
Old May 22, 2015 | 10:54 AM
snovvman's Avatar
The seller sent a replacement, but it still does not fit. The factory connector is more oval and the LED is more rectangular.
I believe M-B made a change some time between MY 11 and 12. the OE license light is in fact ~4500 to 5500K white and it does not have a replaceable bulb. I believe the OE is already LED.
Old May 22, 2015 | 12:54 PM
konigstiger's Avatar
'71 Pinto
License plate lamp for your MY13 should be OEM LED part 2218200856 shown here http://www.ecstuning.com/ES1793755/
Old May 22, 2015 | 01:36 PM
ECSTuning's Avatar
Former Vendor of MBWorld
2012 SLS AMG
konigstiger,
Thank you for posting the link to our site! If there is anything I can do for anyone, please let me know.
David
Old May 23, 2015 | 11:29 AM
snovvman's Avatar
konigstiger, as always, thank you. EPC confused me because, using my VIN, it listed a T10 W5W bulb (000853) with the lamp housing. It did not show the bulb as "not applicable".
Originally Posted by ECSTuning
konigstiger,
David
David, I appreciate that your website lists the OE part numbers and they are searchable.
