Key Fob for S550 2012
Check this out:
Another thing to consider is that MBs key policy requires the vehicle to be at the dealer and it's a lot easier to tell the customer to tow their car because it needs to be programmed rather than tell them they want to look at the car. Also why do you think they need the vin and why do they have to order it? If it was blank they would have stocked them.
I will say that I don't have an older car, I have a 2011 S63, replaced a key in 2014, and the dealer still had to take the car to the service department once the key arrived so I know for a fact, this procedure isn't just performed on older cars nor does it mean that all 2000+ cars are exempt because my car is several years older than a 2000 and required this procedure. The point is, I offered a different point of view because too often people give advice on these boards with certainty rather than just tell the OP in their experience this is what happened. There are several opposing scenarios and there are several times when MBUSA tells a different story depending on what representative you get so their word isn't gospel either. There are varying situations out there such as in my case and I would never present my own experience as the only way and the right answer.
However, if you and your car are in the U.K., then you might try this firm. http://www.replacementmercedeskeys.co.uk/
Also if you lose a key, the dealer will order a replacement key, and synchronize the new key with your car and resynchronize your spare key with the car. So if your old key is found it will not work with the car. Think of it this way, when you lose a garage door opener, you should resynchronize the remaining openers and synchronize the replacement one with the opener motors in the garage - very similar process. So you really need to tell the dealer whether your key stopped worked or you lost it.
Now in the earlier cars, apparently you could just point the key at the mirror, press the unlock button twice, within 30 seconds, insert the key into the ignition slot, turn to the on position and the car will synch/re-synch the key. Also one could just leave the key in the ignition for sometime (1 - 2 hours), and the car would automatically synch that key.
I searched the web and I also found this to provide additional information to clarify the discussion.
"EIS Stands For Electronic Ignition Switch. The hardware is the switch into which the key is inserted but the key is not a key in the traditional sense, it is more like a plastic Lego brick which fits into the socket in the dash board. The key has a sequential code which rolls on each time it is used so that the car cannot be stolen. every time the key is inserted the EIS, EIS checks the key and then asks the Electronic Steering Lock (ESL). If it is happy with this key if ESL is OK it then asks engine ECU if it agrees that this is the authorized key. Only if all three control units agree that it is the correct autherised key is the turn and start function allowed."
I hope this helps clarify the discussion.
Gary
Now that we are all on the same page about dealers programming keys, the synch process is very simple. Dealer places key in EIS, makes sure EIS recognizes key and it completes the handshake with other systems like DAS, keyless go etc. That's it. If the key is not recognized or does not complete synch process there is nothing the dealer can do but order another key after making sure EIS is functional.
Blanks are very hard to come by and none of the eBay keys are blanks. So yeah- paperweight sounds about right. If your key's buttons are messed up you can get an eBay one (that looks identical to yours) and you can swap internals, by that is about it.
Now, there are ways to re- program keys but let's not go there
The problem is getting the stupid thing to work. I've read every forum entry I can find, have spoken with 3 "service experts" at the dealer and at a complete loss as to how to proceed.
Have tried leaving key in EIS overhight (rotating code), have tried inserting in EIS, holding lock, removing and pressing unlock 5 times while still holding the lock button and cannot get it to work.
Dealer has told me: 1) Just use it; it's ready to go from Texas, 2) Must make a service appointment to program key.
Does anyone have first hand experience with this. Don't want to waste another trip to dealer (like I did trying to get mBrace to work).
Thanks in advance.
