Funny engine fan behaviour S550 4matic 2007
Hi all,
recently while driving in the city, totally usual conditions, fan started to blow at full speed. And it's going crazy ever since. It starts at full speed, and cuts off whenever likes, even when car is closed and locked. Usually starts at high, when after driving around 30min. Yesterday just reparked, and it started to spool up after some time, when car was shut.
Any ideas?
P.S.: and I of course will go to STAR when I will have time (usually takes couple of months) . BUT, 90% I'm always solving with clever advice, and without STAR.
Thanks.
Any ideas?
Thanks.
Head about this. What is puzzling with that idea, is that it's working high NOT all the time, but turn on and off, and also turns on, while car is locked. As far as I've read, faulty controller will make fan work on high revs all the time the car is running, which is not the case.
What do You think?
What do You think?
Hello again, it took a while, but I've got to dealership.
They have found no faults, than waited till fan will start, and checked if signal comes from AC, or ECM, found nothing there. Then, they have updated software (because driver's window didn't worked), and fan stopped fooling around, but not for long. After hour, when they have started the car to bring back to me, fan started run on high again. Since there were lots of messages about low voltage, they suggested to change aux battery. I did that, but nothing has changed.
What is interesting though is that I feel new battery again running low, because interior lights comes up and when I open the door, and turns off too quickly. And they does not turn on again, even if I push the button. Same was with old battery.
Maybe somebody is interested to dig deeper and help me to find the cause of this. I know, it's very easy just throw new parts in, but I'm interested in fixing things, not changing.
I don't know how it could be related to low voltage, but I've noticed, that fan starts every time power is used (when car is not running). For e.g. I sit in the car one hour, engine shut. If I move my seat, open window, open door, it starts up.
Any thoughts?
Any thoughts?
[QUOTE=Simonas.
Any thoughts?[/QUOTE]
If the new battery is not staying charged then you will get all sorts of electrical faults. Sounds like its not charging the new or old battery?? Alternator, wiring from alternator.
If it comes on anytime the power is used, it's related to the CAN being woken up by another module. Since you say power seats triggered it, I'd have to assume it's the body CAN, which can send a fan request because of the a/c controller on it.
You really need to see what is commanding the fan on when it comes on, there's no way it's "not the A/C or ECM". It has to be something, and if it's really nothing, then the controller is just defective internally.
i would start reading values when fan is working- if star says "fan running" then something is triggering it. if fan is running but system has no idea it is- see my previous paragraph
Today I've entered service menu. (pressing ok and answer call buttons). While engine was shut readings were 11.5V, than fan kicked in, and it has dropped to 10.5. Fan turned off, and it climbed back to 11.3. Then I've started the car and it came up to 13.5. Does that say to You anything? I don't know which battery reading it shows.
this. i have seen many controllers fail in dazzling variety of fashion- some just go dead. others go full speed. then there are the girly ones- passive aggressive - go on and off when they feel like- no rhyme or reason.
By the way, nice writing style.
Do you have a scope? Monitor the PWM signal line to the fan. This is a very common issue
Guys, I've found controller being sold separately in Germany. What do You think?
http://www.ebay.de/itm/Steuergerat-G...0AAOSwLcNZWjso
Of course I should be sure, that it's faulty before ordering.
But again, could be a number of things. I have also attached some screen shots of closed cases through mercedes.
