W221 ANDROID touchscreen...
Old Jun 19, 2021 | 05:22 PM
  #501
lli's Avatar
lli
2022 EQS 450+
Re the optical cables, I found how it should be done in this video. just after 15 min mark
Re Now the one question remains: how to use the car's gps signal by splitting it...
Or just go with the supplied GPS antenna...
Old Jun 20, 2021 | 01:56 AM
  #502
amgs63dxb's Avatar
W222, W221, W218, W211
@lli so optical part solved. Not sure if TV is any better than aux here - when you use Aux, the unit is clever enough to switch automatically to Android mode just when you select it from OE menu. I am not sure if this will be the same for TV mode - try both and see which one works best for you.
As for GPS - I don't see a reason to split it in the first place... are you going to use the old NAVI for anything? If it is not generating any beeping errors then why bother... I am using antenna provided with the unit, placed at the far end of the dashboard, just at the place where windshield meets the dashboard - no issues whatsoever. And it is not visible from behind the wheel, so why not (mine was JP specs, so can't split the GPS as it is different to begin with, but I ended up removing OE GPS antenna anyways, to avoid these idiotic hard turn alerts that were hardcoded there).
Old Jun 20, 2021 | 04:51 PM
  #503
lli's Avatar
lli
2022 EQS 450+
The optical part is solved, but also not solved. If I pry the small plug with the two optical cables from the larger Mercedes plug, and put this smaller plug going into in the new android plug , sound etc works. However the rear camera does not.
If i use the supplied optical splitter and tv box with the "most" plug, nothing works. I think the optical splitter does not work correctly. I can see red ligght coming out of one of the mercedes wires, but after I put the splitter on, this is not redirected to the next plug.
GSM and GPS work. However, my GSM connects to 3G network, not 4G. And 3G will be decommissioned end of this year in NL...
So any help on the rear view camera and the 4G network is appreciated.
I have learned form reading old posts that the TV-box has not worked for anyone. My hypothesis is that the optical splitter doe not work. But then my question remains: how did people get the stock rear view camera to work ?
On an earlier question from me, i got the impression that people had the rearv view camera working:
Originally Posted by lli
Currently my car has a stock rear view camera (option 218 at the time). As soon as I put my car in reverse, the rear view kicks in and "overrides" everything I was doing. Eg navigation, radio screen.
Suppose I change to the android replacement unit. The NTG is left intact (as so far it works), how will the rear view camera operate?
Will NTG override the android unit and display the rear view from the stock camera?
Or
Will android take care of this and display the rear view from the stock camera within the android environment? If so, is there any lag/delay?
Originally Posted by artim808
Yes, that's exactly what will happen.
Old Jun 21, 2021 | 12:58 AM
  #504
amgs63dxb's Avatar
in the factory settings (settings -> factory -> enter code) you will have to select if you are using OEM or aftermarket reverse camera... depending on the model factory settings will be accessible using different access codes (check bimmer website for examples if your vendor did not give you the code). If you have OEM camera, setting this bit to OEM is the only thing you need to do - no need to connect anything - the unit will automatically recognize when the car is in reverse mode and switch back to OE view.
Neither the optical splitter nor the most is going to work with your setup - just leave it alone - you have already achieved the original intend - which is to have sound working ;-) Camera is a secondary thing. I can't comment on the 3G setup - I don't even use it myself - I don't even know if my unit had the modem built-in and whether it was 3G or something else - all I use is Android Auto/ Carplay mode, which totally depends on my phone, not on built-in GSM module of the unit. If you need something more fancy, just use USB-based 4G dongle instead of built-in one... Or use wifi sharing...
Old Jun 21, 2021 | 01:29 AM
  #505
megacrazy's Avatar
CLK55 W209, CL63 W216
Originally Posted by amgs63dxb
Let's agree to disagree. I tried three different USB DACs and at best audio quality was equal to the directly connected unit. My conclusion is that there must be some more HW difference between units made in 2019, 2020 and 2021... Different makers, different hardware quality, different audio components...
@lli can you post a picture of the harness provided with the unit?
It looks like you got yourself a bit too many options there - if your unit has the harman logic 7, then all these optical bypasses are not necessary. Also you will not be using the MOST box if your unit has AUX in. The only thing to be done there is to take out optical wires from the main harness socket and plug it into to the extended one you got...
The internals are the same, provided you buy the same spec unit. They all use the same crappy audio processing. The difference comes in at higher volumes where you get noise if you don’t use a DAC (which is extensively documented in several spots). The sound is also much more vibrant if you use a good quality DAC that you can adjust properly.
If you’re wondering what the difference is between a 400$ unit and a 700$ unit, provided you don’t get a fake one, absolutely none. Maybe better support…maybe.
Old Jun 21, 2021 | 03:30 AM
  #506
lli's Avatar
lli
2022 EQS 450+
Thanks! The reverse camera works!
Old Jun 21, 2021 | 03:35 AM
  #507
lli's Avatar
lli
2022 EQS 450+
Originally Posted by megacrazy
In other news i finally had the chance to mess with the usb DAC and sound quality is a million times better. If you’re into music definitely install one. A ground loop isolator takes care of any and all noise out the unit.
What would you need to make this grond loop isolator work? Could I use the ground of the lightbulb in the glove compartment?
Old Jun 21, 2021 | 09:30 AM
  #508
megacrazy's Avatar
I'm using this:
Amazon.com: Ground Loop Noise Isolator for Car Audio/Home Stereo System with 3.5mm Audio Cable Amazon.com: Ground Loop Noise Isolator for Car Audio/Home Stereo System with 3.5mm Audio Cable
. Not available right now but you can find other similar ones. The ground loop isolator goes on the 3.5mm audio line coming out the headunit. No need to splice any wires.
The DAC I'm using is this:
Amazon.com: Sound BlasterX G6 Hi-Res 130dB 32bit/384kHz Gaming DAC, External USB Sound Card with Xamp Headphone Amp, Dolby Digital, 7.1 Virtual Surround Sound, Sidetone/Speaker Control for PS4, Xbox One, Nintendo: Computers & Accessories. Amazon.com: Sound BlasterX G6 Hi-Res 130dB 32bit/384kHz Gaming DAC, External USB Sound Card with Xamp Headphone Amp, Dolby Digital, 7.1 Virtual Surround Sound, Sidetone/Speaker Control for PS4, Xbox One, Nintendo: Computers & Accessories.
Old Jul 15, 2021 | 01:32 AM
  #509
MKnightMD's Avatar
2006 CLK 500, 2010 S65 AMG, 2010 S63 AMG, 2006 Navigator, 1995 Ferrari 456 GT
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image001.jpg[/img]
MekedeTech 10.25'' Android 10 8 Core 4+64G Car Radio Multimedia Player GPS Navigation for Mercedes Benz S W221 W216 CL 2005-2013 S-Class Head Unit (NTG 3.5)
https://www.amazon.com/gp/product/B08M5BYQN9/ref=ppx_yo_dt_b_asin_image_o02_s00?ie=UTF8&psc=1 https://www.amazon.com/gp/product/B08M5BYQN9/ref=ppx_yo_dt_b_asin_image_o02_s00?ie=UTF8&psc=1
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image002.jpg[/img]
16GB MicroSD included
My vehicle
2010 S65 AMG Euro version with Rear Seat Entertainment package.
Glove Box MMI (Mercedes Media Interface) port with ipod and 3.5 mm female and USB.
No RCA in glovebox
Harmon Kardon Logic 7
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image003.jpg[/img][img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image004.jpg[/img]
My active connections.
OE Fakra 4pin to LVDS box
Mic jack 3.5 to supplied mic
LVDS white connector to Android screen
White cable to supplied loudspeaker
Orange single pin to OE upper control panel connector (shows suspension raise and sport mode)
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image006.png[/img]
MOST Audio in to Audio out (from Android)
WiFi connected
GPS connected (3 way FAKRA splitter integrated to connect to OEM GPS and Android GPS)
Configurations tried
Removed orange fiberoptic OE harness and connected to MOST box via 3 way connector.
3 way connector connected to MOST box.
MOST box connected to Android harness.
OE harness (minus Orange Fiberoptic) connected to Android Female
Android Male connected to Comand
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image007.jpg[/img][img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image008.jpg[/img]
Programming
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image009.jpg[/img][img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image010.jpg[/img]
AUX position 1=2
AUX position 2=9
Note….AUX on my menu is position 9…the first position is AM/FM, not shown
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image011.jpg[/img]
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image012.jpg[/img][img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image013.jpg[/img]
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image014.jpg[/img][img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image015.jpg[/img]
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image016.jpg[/img]
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image017.jpg[/img][img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image018.jpg[/img]
AUX switch mode = Automatic
AUX auto Switching = Other
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image019.jpg[/img][img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image020.jpg[/img]
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image021.jpg[/img][img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image022.jpg[/img]
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image023.jpg[/img]
AUX Activate
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image024.jpg[/img]
Display NTG 3.5
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image025.jpg[/img]
CAN protocol 3.5
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image026.jpg[/img]
UI configuration UI_MBUX
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image027.jpg[/img]
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image028.jpg[/img]
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image030.png[/img]
I have no sound from the Android screen.
I have changed to configuration to eliminate the MOST box and eliminate the orange fiber optic 3 way by connecting fiber optic directly into the Android male plug comand with audio 3.5 out to audio 3.5 in.
I have tried audio out female to audio in 3.5 female in glovebox AMI
I have tried selecting AUX in comand
I have tried selecting Media interface in comand with AUX position 2 =6
I have tried using the 3.5 audio out.
Findings: I have Audio on the 3.5 female audio out from Android. This was tested with an external speaker. For this reason, I concluded that the MOST box and the accompanying fiberoptic could be eliminated, as that configuration did not produce any audio out.
Removed MOST box and fiber optic to simplify.
I know that this is a display unit with some apps that output via comand.
I think there is something in the configuration of the Euro with rear seat entertainment and the glovebox MMI (USB, ipod and 3.5 female audio) that somehow needs to be properly selected to direct the audio input.
[img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image031.jpg[/img]
The AUX option here is grayed out….I cannot access it. Any ideas? [img]file:////Users/markknight/Library/Group%20Containers/UBF8T346G9.Office/TemporaryItems/msohtmlclip/clip_image032.jpg[/img]
My MEDIA INTERFACE options
I have tried all the combinations, outputs and options that I can think of. I still have no audio coming from comand. I have eliminated the MOST box and connected fiberoptic directly to aftermarket harness (male). Female connected to OEM male.
Audio out 3.5 connected to audio in 3.5.
Another option may be to connect it to the OEM MMI/AMI ipod/3.5 in the glovebox via the supplied 3.5 extension.
Things to investigate…is the MMI working? Could the adapter be defective?
Are my programming settings correct?
Is the unit properly wired?
Any ideas would be appreciated.
Thanks.
File Type: pdf
Old Jul 15, 2021 | 05:18 PM
  #510
lli's Avatar
lli
2022 EQS 450+
Your links do not work for me. I only see locations on your server.
What can you succesfully connect to the female 3.5 plug in de glove compartment? Did you get sound from that eg by plugging a mail 3.5 in your mobile phone, other 3.5 in the female jack?
Old Jul 16, 2021 | 03:27 AM
  #511
Chris The Swede's Avatar
W222 S63L, ML/GLE350
No pics work.
Old Jul 16, 2021 | 11:22 AM
  #512
MKnightMD's Avatar
Chris,
Check out the PDF...download and view. The pics wouldn't upload.
Old Jul 16, 2021 | 11:23 AM
  #513
MKnightMD's Avatar
Ili,
Thanks for following up. I had the same thought. Looking for a Type C connector/adaptor for the media interface. Yes, I am that guy who went Samsung instead of Apple....lol
Old Jul 16, 2021 | 11:29 AM
  #514
MKnightMD's Avatar
GPS FAKRA splitter
Chris,
Attached are the files in PDF.
Thanks,
MK
File Type: pdf
File Type: pdf
Old Jul 16, 2021 | 06:25 PM
  #515
lli's Avatar
lli
2022 EQS 450+
When you say you connected most audio to andriod, what do you mean?
You have: Glove Box MMI (Mercedes Media Interface) port with ipod and 3.5 mm female and USB.
Can that 3.5 jack be played over the Mercedes sound system?
Then you connect a DAC to the USB from the mekede device into the femaie 3.5. A cheap but decent dac is about 30 US.
You can leave the most black box out, it does not work:
Old Jul 17, 2021 | 10:00 AM
  #516
Dhaif's Avatar
W221 s550
Help guys please
Now I cant access the factory COMMAND interface. I mean no upper bar where you can control (audio, telephone,navigation, vehicle...etc .Only A/C ( lower bar) is shown.
Old Jul 17, 2021 | 10:51 AM
  #517
Dhaif's Avatar
W221 s550
This what I mean
Old Jul 17, 2021 | 11:18 AM
  #518
MKnightMD's Avatar
Ili,
I know that my MMI works...I have a bluetooth adapter plugged there, and that relays audio from my Samsung.
I suspect the cable supplied by the vendor may be the issue...I have some thoughts on that and will be investigating further. Any recommendations on the DAC? The one that Megacrazy (not crazy by the way...lol...super smart guy) is expensive.
I will keep you posted.
Old Jul 17, 2021 | 11:19 AM
  #519
MKnightMD's Avatar
Do you have access to Star?
If not, try disconnecting battery negative for 10 mins and then allow system reset. May help.
Old Jul 18, 2021 | 08:32 AM
  #520
megacrazy's Avatar
Originally Posted by MKnightMD
Chris,
Thanks,
MK
It sounds you may have the facelift car with NTG 3.5 or have specific AUX ports in the glove box. In that case the sound connection is made behind the glovebox. Make sure the 3.5mm is connected to the smaller harness and not the larger/main harness. You should have an extension for that smaller harness that should be able to reach the glove box.
Take the dash end cap off (on the glove box side) and check what your aux ports are connected to. Unplug that and plug it into the harness coming from the android unit. That should give you audio.
Edit: make sure you have OEM amplifier selected and see if that fixes it first.
Old Jul 20, 2021 | 02:45 PM
  #521
lli's Avatar
lli
2022 EQS 450+
Ili,
I bought one with a ES9280C DAC, Just search on aliexpress an you'll find plenty.
Connect that to one of the USB from the Android screen, and to the female 3,5.
I had to put 3,5 to RCA adapter in between, but it should work.
One additional question: did you put the volume of the Android unit up! It is in Android settings, not the vehicle settings.
@Dhaif: did you tap the black region? That got me into the android screen. From there select the radio/disc button of the mercedes and you should get to the mercedes command screen.
Or did you try the on button?
Hope this helps.
Old Jul 24, 2021 | 12:37 PM
  #522
Dhaif's Avatar
W221 s550
Hope this helps.
It was the ON button
Thank you guys
Old Jul 24, 2021 | 12:56 PM
  #523
Dhaif's Avatar
W221 s550
Hope this helps.
Thank you guys
Old Jul 26, 2021 | 11:07 AM
  #524
megacrazy's Avatar
Thank you guys
Old Jul 31, 2021 | 02:08 AM
  #525
MKnightMD's Avatar
Megacrazy, lli,
Followed your suggestions and here is what I have discovered. Mega, as usual, you were right...the TV box does not work. The Audio out is a female 3.5mm jack. I ran a male to male 3.5mm and connected to the media interface AUX in the glovebox. When the system is set to AUX in comand, there is some sort of hum when the media interface (ipod + Aux 3.5 jack) is plugged in. When the male jack tip touches the collar of the 3.5 female jack there is sound from the right side. There is distorted crackling from the left side and constant whine. When the male is fully plugged in, there is no sound except the hum.
