Pulleys/Belt
Pulleys/Belt
So I am just going to replace all pulleys and the 2 belts.
Anyone else ever do this yet?
I am doing this as I have a squeaky belt/pulley if you recall I put up a video.
Since I am using Mercedes methodology, I am just replacing everything.
3 pulleys and 1 tensioner and 2 belts.
I am going to do this on ramps and go from under.
any tips?
I have all parts and wis instructions.
I will make a video for the library.
I am at 50k.
thanks
any tips?
I am at 50k.
thanks
What is the scheduled interval for this to be done? My Indy never mentioned this to me and I recently dropped my car off to him with an open checkbook.
This is not on an interval per se, when the V belt is removed for replacement idler pulleys should be inspected and replaced if noisy or spinning freely.
Generally audible noise will be generated before catastrophic failure but not always.
A replacement of all idlers is rather cheap and easy so a preventive step at 60k-100k is not a bad idea.
vinflouen (02-07-2023)
any tips?
I am at 50k.
thanks
any tips?
I am at 50k.
thanks
Some will be better from the top and some from the bottom.
I also notice that it gets louder when I give it gas, but once the car is warm it is quiet at idle.
Received 4,434 Likes
'71 Pinto
The following 4 users liked this post by konigstiger:
'71 Pinto
Yes. reply was to TIA .
vinflouen (02-08-2023)
I took the covers off today and this is a topside job for sure.
no room from underneath due to radiator and frame.
now I decide if I want to take all the ‘stuff’ on top off and do the pulleys and spark plugs….. a weekends worth of wrenching for sure.
any tips?
I am at 50k.
thanks
any tips?
I am at 50k.
thanks
