I drove a new BMW I7 and…….
Old Jun 18, 2024 | 05:05 PM
  #251
W205C43PFL's Avatar
The other advantage I can think of for following break-in procedures are to get familiar with the vehicles' engine, performance, driving characteristics before opening it up. This is especially true if that person never had an MB before or if going from MB's pedestrian model to a performance oriented model, they can have a feel and be prepared of the full potential of the vehicle. Just my opinion of course : )
Old Jun 18, 2024 | 05:06 PM
  #252
W205C43PFL's Avatar
Originally Posted by crabman
Mixed bag on break in, I say that as someone who had access to a very large database with logged engine, transmission, reduction gear, PTO, and other similar equipment, lots of data over the lifetime of these components. More interesting is that in the commercial space you are sometimes talking about multiple lifetimes; you have sleeved bores and all that, they're designed to be renewed endlessly. This means you can see the same engine operated under different parameters. It's commercial usage, but in broad strokes, I'd say it's pertinent.
With cars you've got a lot of different components with differing needs for directed break-in operation. In my opinion, based on what I know, you don't need to worry about the engine, it left the factory with enough revolutions to be largely beyond any benefit, and moderate initial loading may show an extended service life.
Probably time to be talking about moderate, and with it, duration. Should you enter into a commercial endeavor involving an engine that costs you millions; you have incentive to get it right. What right will end up looking like is a load table defining the load you're going to put on the engine over the time following the first start. You'll be hooking up to a load cell for smaller engines; these are usually nothing more than a great big toaster, tons of toaster, and the resistance is going to be your load. Bigger engines in power plants may be aligned into an array and load sharing will be used to control the load. On a boat, with main propulsion, they will pull on the dock to start, and then head out to a sea after a short time, where they will introduce load as directed during a sea trial. There is always a way, and when it's your millions, you're going to follow the procedure. This is almost invariably going to be a light load that is increased over time.
So then you've got duration; how long will this directed operation go on? This will usually be defined in hours, and it's not many, as little as a few, to around 20 for some gears, the longest I'm aware of are ring and pinions. There could be others that are more, can't say.
To go back to that engine, it has been started and stopped multiple times before you got the car. This isn't just a matter of making revolutions, its had heat cycles, that's a good thing. When it's my money, I don't baby it, but I do drive moderately in the early miles. I vary my speeds. If at all possible, I'd arrange for heat cycles in those early miles.
So why the heat cycles? That would be your diff, those gears require a mating process to reach their final service condition and that can only happen during actual use. Overloading these gears before they are ready will create excessive heat. At best it will increase gear whine, they will in any event be weaker, and your worst outcome is failure.
Lets go back to that 20 hours I mentioned. A typical car will go around 500 miles during that time. Most of you are probably too young to have changed gears on your cars. Those that have will recall that Motive, or whoever made your gears, will recommend something like 400 to 500 miles before full load operation. They will tell you to heat cycle the gears when you first install them by driving a short distance and then stopping for a time period. More or less 3 heat/cooling cycles and then you're told to vary your speeds and limit load, gradually increasing load as you get to their recommended full throttle mileage.
Anyone notice how it used to be your break-in was 500 miles, almost everywhere? That isn't an accident, that's when the longest directed break-in operation item, your ring and pinion, will be fully in service.
Why the 1000 mile thing you see nowadays? Things break more often when flogged, less often when babied. I don't think this, the data shows it to be true. Imagine you could increase profitability by simply changing a number that would have millions of owners babying their cars for an extra 500 miles.
I'm in Italy typing away in a wine bar; Mrs Crab has gone home ahead of me and I'm free to play. I apologize if I screwed that up on my phone.
Amazing perspective, agree it is a mix bag and thanks for spending the time to chime in to the topic while on a trip. Wish you a wonderful trip!
Old Jun 18, 2024 | 05:10 PM
  #253
W205C43PFL's Avatar
Originally Posted by SW20S
I know a guy who leases high end cars and prides himself on never washing them or changing the oil. His response is "why would I, its a rental car". To me even if you are leasing a high end car, you're paying a lot. Why do you want to drive around in something filthy?! I had that GLS450 loaner for 8 days...I washed it because it was filthy.
Break in periods are outdated. Personally I think AMG suggests that to add to the allure that the car is special and handbuilt etc. Its like a Lexus ES requiring premium gas lol
Huge difference. I haven't driven a 740 but I have driven the 760 back to back with the i7 several times and the i7 feels totally different and better.
Ya I don't like the idea of just because it isn't yours, you should treat it poorly. I hate that mindset, hence why I am reluctant to buy lease return vehicles or to be a person that leases vehicles because I don't want to be one of them. I only buy cars new but depending on how the industry is going, I understand if I still want features (like physical buttons) or if I need or want dislike a certain automotive trend but MB is following, a used vehicle might be my only option. Or I can check out BMW like OP of course : )
Thanks for sharing your perspective on break-in.
Thanks for sharing your perspective on the i7 vs the regular ICE.
Old Jun 18, 2024 | 05:48 PM
  #254
W205C43PFL's Avatar
Speaking of which, saw this quick short video just now on the i7 I guess the 60 version:
Old Jun 18, 2024 | 05:56 PM
  #255
SW20S's Avatar
Active Streak: 30 Days
2024 S580
Thats the M70, the high performance version
  #256
W205C43PFL's Avatar
Oops.
Old Jun 24, 2024 | 03:17 PM
  #257
Quietride's Avatar
That really speaks volumes about a person’s character. Unfortunately this is seen a lot in the EV world, especially among owners of certain brands like Audi. Owners will charge the vehicles to 100% at all times and let them sit, in direct opposition to the manuals and on-screen guidance.
“I paid off 100% of the car, and I won’t have it in a couple years.”
Can you imagine if someone bragged about not changing oil on their S-Class or 911?
Old Jun 24, 2024 | 03:23 PM
  #258
SW20S's Avatar
2024 S580
I know people who do exactly that!
Old Jun 24, 2024 | 04:46 PM
  #259
W205C43PFL's Avatar
Um sounds awfully close to the "I paid for the full tachometer and speedometer, I am going to use the whole tachometer and speedometer"
I can't imagine, that sounds like torture to a car
Old Jul 8, 2024 | 08:11 PM
  #260
Streamliner's Avatar
Well, the title of this thread is “I drove a BMW I7 and…….,” I’m pleased to report that after sitting “At The Port” for almost three weeks, my I7 is finally on a ship, headed my way. The dealer says “about August 12th” for delivery. I can’t wait to do a thorough comparison with my departed S580.
Old Jul 8, 2024 | 08:31 PM
  #261
W205C43PFL's Avatar
Sweet! Looking forward to hearing about it : )
Old Jul 8, 2024 | 09:47 PM
  #262
docsout's Avatar
2023 S Class 2013 SL
Stream, y’all alright over there? Saw the news about fires, and yikes, concerned about you and family.
Old Jul 8, 2024 | 09:55 PM
  #263
S_W222's Avatar
Current/Last 5-years:GLS;G70;Alpina B8;X7;Accord. Sold:X7,TeslaS;S560;S550,X5;530e;L.Navigator;LS460
Great news!. Am very excited (and interested) in seeing your thread comparing the two.
Old Jul 8, 2024 | 10:18 PM
  #264
SW20S's Avatar
2024 S580
Congrats!
I’ll save you all the wait, he hates the S580 and the i7 is much better lol
Old Jul 8, 2024 | 10:39 PM
  #265
Thank you, but we live a bit less than a mile from the ocean, nowhere even remotely near the fire areas. It was 74 degrees here today.
Old Jul 8, 2024 | 11:46 PM
  #266
S_W222's Avatar
Congrats!
Well, not necessarily, but we shall see. His comments about the W223 were all logical, so he might as well find similar issues with the i7 and save some of us the hassle as am too hesitant already and not that excited for it. I'd expect he will love the i7 only because it's an EV, and the drivetrain and driving experience in that sense would be superior, but that's not what am interested in as I already know that. Everything other than the driving experience is what am curious to hear about.
Old Jul 8, 2024 | 11:53 PM
  #267
SW20S's Avatar
2024 S580
I think he's going to like the i7, source of frustration will be iDrive and the menus.
Unless there is a huge difference between a 22 and my 24, I think if he had not gotten the eABC he would have liked the car better. The ride is incredible, better than the W222 (I did not have MBC). The car is also incredibly silent and the transmission shifts great. Its silent up past 90...95 where on the W222 some wind noise would set in. The i7 also rides great, but it doesn't ride "better" than this, its very similar. The only thing I find irritating are the door handles. They are really dumb...BMW's design is much better. Seats are better in the 7 for sure.
Old Jul 9, 2024 | 11:58 AM
  #268
W205C43PFL's Avatar
Congrats!
Ya, the waiting kills : ( it is still over a month before he gets it.
Old Jul 9, 2024 | 12:21 PM
  #269
Good things come to those who wait.
I’m actually waiting on something else that is very related, but I can’t tell you what it is yet.
Old Jul 9, 2024 | 12:27 PM
  #270
W205C43PFL's Avatar
I wouldn't be able to sleep tonight then
Old Aug 2, 2024 | 08:44 PM
  #271
MBS63AMG's Avatar
2019 S560, 2022 Audi S8
I've been in Billings Montana this week and as I was headed out to my car, a man and his wife were walking away from their BMW 760i headed to the doors of the hotel. I asked him how he liked it and he said he loves it. I told him that I felt that the BMW 7 is the king of the luxo-barges right now and that MB is in trouble. I told him how I had several S classes in my past 30 years and that I thought the last best Benz was the W222. He agreed. He said he had 3 W222s and never had a problem at all. He then told me that he had a 2022 W223 and said it was "a piece of junk" and was in the shop more than out of it and that they had to buy it back. He said he was shocked at how many problems he had with it including door handle issues, constant suspension issues and electrical gremlins. I did not lead him to say any of this....he said it as a flow of the conversation.
Old Aug 2, 2024 | 08:57 PM
  #272
W205C43PFL's Avatar
Sounds like you met forum member streamliner in real life
Old Aug 2, 2024 | 09:30 PM
  #273
S_W222's Avatar
Obviously he is not the only one. Forums like these are great to spread out the message and enlighten future potential buyers. W223 is definitely on my must-avoid list unless the facelift brings the S-class back to the competition. I still think I’ll try the facelift regardless. Right now there I see no german large luxury sedan that makes sense other than the 7 series.
Old Aug 2, 2024 | 09:32 PM
  #274
S_W222's Avatar
haha lol… I thought the same the first time I read this…. You know, it’s very possible lol.
Old Aug 2, 2024 | 09:47 PM
  #275
Other than the fact that I have never set foot in the BIG SKY state.
