Nitrogen Filled Tires
Old Oct 15, 2010 | 04:46 PM
Corsa9000's Avatar
2004 S55 ///AMG, 2007 E350
As you know many tire shops are filling up tires with nitrogen. Claimed benefits are nitrogen molecules are larger so less leakage, less corrosion damage inside the tire due to lower moisture content, etc. All race cars and aircraft tires have used nitrogen for a long time.
What do you think of the benefits of nitrogen, worth it or not?
Old Oct 15, 2010 | 07:55 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
If its free
Otherwise its up to you. If you read how they fill them you'll see that they only go to 95%. Std air is ~ 80%.
Old Oct 16, 2010 | 01:05 AM
Corsa9000's Avatar
True, that is a good point and if you have to add air on your own a few times then it gets even more diluted and almost like air.
The fact that race cars and aircraft tires use nitrogen though still intrigues me.
Old Oct 16, 2010 | 07:11 AM
MRAMG1's Avatar
S600, GL450, GLC 43
Waste of money.
I have went into a lot of detail about this in other threads, and let me just say it one more time.
PV=NRT.
So no matter what gas you use, helium, acetylene, nitrogen, argon, air, etc. They will ALL expand when they heat up.
One of the guys on the C63 road raced his nitrogen filled car, and was surprised that his pressure when up after lapping
I reminded him of the obvious.
As far as water damage. I guess if you left your tires on for 4-5 years maybe, emphasis maybe.
Bottom line, SAVE YOUR MONEY
Old Oct 17, 2010 | 07:59 AM
carlosfernandez's Avatar
SL500 2003 previous/ E350 2007 actually
Nitrógen, that's new to me!!!
Old Oct 17, 2010 | 09:22 AM
MBtech1098's Avatar
10 speed bicycle
Waste of money, not to mention it is not recommended by MB.
Originally Posted by amdeutsch
If its free
Race cars and aircrafts are filled with pure nitrogen, that comes from a gas supply company. The equipment used in the auto repair field only filters atmosphere...and truthfully of the machines I've seen, they only reach a purity of 92-95%. If there is even 1% of atmosphere in the mixture, it completely negates the advantages.
They also claim you do not have to maintain tire pressure...I have yet to see a car filled with nitrogen not be low on pressure in between services. If you read the spec sheet below, it even states that it only filters to 95-98% purity.
File Type: pdf
File Type: pdf
Old Oct 17, 2010 | 10:39 PM
Corsa9000's Avatar
As to MB not recommending nitrogen, my local MB Dealer recommends Nitrogen, in fact they advertise taking you car there for nitrogen replacement for $60. For all new tires they sell and install, they fill with nitrogen as well.
My Sunday AM routine is to check all three cars: oil level, coolant, brake fluid, power steering and tire pressure. Two cars are typically low 2 PSI every 2-3 weeks, the nitrogen filled car gets low every 8 months. Coincidence or .......
Old Oct 18, 2010 | 05:33 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Don't confuse a stealer's recommendation with MBUSA's. For $60 its not worth it IMHO.
Old Oct 18, 2010 | 06:10 AM
Jon2007E63P30's Avatar
2007 E63 w/P30 and Eurotech CF Diffuser
There have been college PHD disertations about this posted on the web site.
IMHO, get rid of the moisture and you eliminate 99.9% of anything that will bother you on the road. If you are a SLS AMG GT3 trying to get the last 10nth out of the Nurburing, then use N2.
