W220 s65 motor mounts DIY-does it exist?
Old Feb 18, 2014 | 03:44 AM
iansilv's Avatar
2010 ML350 W164
Does anyone have a guide or description on how to replace the motor mounts on an s65 w220 specific to this vehicle?
Old Feb 18, 2014 | 01:31 PM
Welwynnick's Avatar
2006 S600
How good are you with spanners?
Nick ;-)
Old Feb 18, 2014 | 01:35 PM
iansilv's Avatar
2010 ML350 W164
Getting better...
But seriously- can this be done with the right engine hoist?
Old Feb 18, 2014 | 01:48 PM
Welwynnick's Avatar
2006 S600
Yes it can, but you don't need to remove the engine, just raise it slightly.
Here are the best motor mount threads:
https://mbworld.org/forums/sl55-amg-...sl-models.html
https://mbworld.org/forums/cl55-amg-...ml#post5759593
https://mbworld.org/forums/s55-amg-s...-job-done.html
https://mbworld.org/forums/s55-amg-s...ml#post5856300
Good luck, and let us know how you get on!
Nick
Old Feb 19, 2014 | 02:28 AM
benz_addict's Avatar
V12TT
Just did it last week. Motor had to be raised enough for access. Damn engine mount shield and cooling lines for the turbo are in the way to wrench around for the driver's, however the bolts can be accessed. Complete removal is not necessary. Dropping the exhaust out of the way helped alot, plus gave me a chance to install my downpipes. Don't forget to pop in a new transmission mount as well and check out the flex disc attached to the transmission and center bearing.
