Replacing the MAF sensor - S55
Old Mar 4, 2017 | 10:50 PM
cmpcpro's Avatar
2004 CLK 500
Hey guys I haven't checked under the hood yet but l know it's in the back. Does anyone know how hard/the best way to swap out the MAF? Is it just a simple swap? I bought the OE Bosch, but I've heard someone mention Star could be needed for programming. If so it's not an issue my new Star setup has already arrived but I haven't used it yet.
I tried searching but there is nothing so this will be good to add to the board. Also the sensor is over $300 at dealers and $130 on Amazon, both with the same exact part number stamped on the side of it.
Old Mar 7, 2017 | 04:46 PM
cm60k's Avatar
I don't think you have MAF sensor..!,
i believe you mean MAP sensor, isn't..!?!?
-;ZAYED;-
Old Mar 7, 2017 | 05:25 PM
cmpcpro's Avatar
2004 CLK 500
No it's a MAF. I have it already just need to install it with the new plugs and wires.
Old Mar 7, 2017 | 06:33 PM
cm60k's Avatar
You have M113K Engine, isn't..?
-;ZAYED;-
Old Mar 7, 2017 | 06:59 PM
compaddict's Avatar
2016 S63, 2013 SL63
My 2005 didn't have one.
Old Mar 7, 2017 | 07:08 PM
cm60k's Avatar
Yeah, as i know;
*S55 from "oct/2001 tell 2/2003" comes with N/A Engines, MAF,,
*S55 from "Apr/2003 tell Nov/2006" comes" with Kompressor Engines, without MAF, only MAP..!!
-;ZAYED;-
Old Mar 7, 2017 | 07:13 PM
cmpcpro's Avatar
2004 CLK 500
Sorry guys this is what I bought. Definitely for the S55.
Amazon Amazon
Old Mar 7, 2017 | 07:21 PM
cm60k's Avatar
Chris,
Are you sure you have this MAF on your Engine....??
-;ZAYED;-
Old Mar 7, 2017 | 07:26 PM
compaddict's Avatar
2016 S63, 2013 SL63
I bought one to! Had to return it to Amazon.
Old Mar 7, 2017 | 07:59 PM
pumpedTSI's Avatar
BMW E31 Dinan Stage 3 TT 625Hp on 93 pump............. 00 BMW E38 750iL.....03 S55 Alabaster white
Zayed is correct.......2003+ Kompressor is MAP not MAF......
Old Mar 7, 2017 | 11:40 PM
cmpcpro's Avatar
2004 CLK 500
Hmm the dealer showed the same part number I bought on Amazon for my car by the vin number.
Wl l something very weird is up with this. The dealer must have screwed their system up.
Old Mar 10, 2017 | 10:49 PM
PillDrive's Avatar
2003 S55 (SOLD) , 2012 S550
I had to do my map a while back...its a map not a maf in the supercharged engines since you cannot measure the air correctly if it gets compressed. Its a little B$%^# to get out.... i ended up making a tool out of a long screwdriver and welded a shortened socket onto it to get to the second screw. If you are in front of the car its on the left side below the supercharger.
Have Fun doing it
