S63 AMG, S63 AMG 4Matic, S65 AMG (W222, V222) 2014 -2021
Resonator or Cat Delete on 17 S63 Sedan
Old Jul 18, 2019 | 03:07 PM
KevinDn's Avatar
2020 C300
Thumbs up Resonator or Cat Delete on 17 S63 Sedan
Hey Folks,
I have a 17 S63 Sedan and looking to get some exhaust work done. I know I can get real performance exhaust for $4k+, but im only into it for the sound at the moment. Just want a deeper sounds for now.
Any one have experience removing Resonator or Cat on S63 exhaust? Should I even touch it? Im not going to touch the muffle, thats for sure.
Im sure there might be some back pressure lost, but its okay. I don't mind losing some hp, got plenty more!!!
Any comments would be appreciated!!!!
Old Jul 20, 2019 | 01:59 AM
S63AMG888's Avatar
MY17 S63AMG - MBUSA Buyback. MY16 SL63 - Sold MY19 W213 E63s. 2020 W213 E63s Wagon
There are plenty of W212 AMG E63s AWD guys doing it. You and I ( 2017 ) have the same M157 and transmission as them if all your after is better exhaust sound. Good luck.
Old Jul 21, 2019 | 10:44 AM
Manofsteelpt's Avatar
Veteran: Army
S63
Mine is deleted. Sounds amazing.
Old Jul 22, 2019 | 09:59 AM
KevinDn's Avatar
2020 C300
Cat or Res delete? or both? Any drone on highway. Also wanted to know if it is still quiet and discreet when in comfort mode.
Thanks for your help
Old Jul 25, 2019 | 07:56 AM
Veteran: Army
S63
Just the res, no drone, still quiet in C mode (though I only drive C in snowy weather). Best $160 I spent on any of my AMGs.
Old Jul 25, 2019 | 10:16 AM
KevinDn's Avatar
2020 C300
Update: I did the res delete. Sounds amazing!! Just enough loudness, nothing crazy in comfort. But when in sport.... Its a monster.
New pipes still need to break in. The guy told me 2 weeks before it settles in. Should get a bit louder and deeper.
No drone what so ever. The best part is, the exhaust pops and bangs more on higher rpm downshifts and tapping the throttle at mid- high rpm. Not like a ecu with burble tune. But just enough where its a noticeable difference and I love it.
I not doing anything else to the exhaust as this is all I needed. I have pics of the exhaust before and after in case anyone needs a reference.
Old Jul 25, 2019 | 10:29 AM
hyperion667's Avatar
2012 CLS63
How about both?
Old Jul 25, 2019 | 12:31 PM
KevinDn's Avatar
2020 C300
I could for more of a aggressive sound, but im good with this for now lol.
Here are pics of before and after the res delete. The resonator are the two small cylinders. I replaced it with just straight pipes.
The front of the car is on the far side
Two Resonators
Mufflers with Electronic actuators
In sport, the bigger pipe opens up.
After.
Old Jul 25, 2019 | 05:42 PM
phatisfy's Avatar
S-class
Two Resonators
After.
Looks good. Any sound clips by any chance?
Old Aug 7, 2019 | 05:57 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Just do the resonator and see how you like it. If you need more, then I would add down pipes before doing any hacking on the oem front pipes. Always good to keep those for trade in or resale.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Aug 8, 2019 | 12:14 PM
KevinDn's Avatar
2020 C300
Yeah, I did the resonators and it exactly how I want it. Pops a couple times when downshifting, but nothing crazy like burble tunes.
I do want downpipes but they're costing $4k-$5k+. Eventually Ill get downpipes and a tune and thats all this car really needs.
Old Jan 28, 2020 | 02:55 PM
Bijan Kohan's Avatar
2016 GTS; 2021 G63; 2015 Range Rover Supercharged
I have a ‘15 S63 sedan and did the resonator delete. Made absolutely ZERO difference for me.
I was thinking of doing bolt on catless downpipes but they’re too expensive. Plus you need to get a tune or else the CEL light will be on all the time.
I have never done a muffler delete but today, I took my car to the local muffler shop to get it done.
I will write about it once I get the car back and get a few minutes.
Old Jan 31, 2020 | 01:37 PM
just deleted both mufflers. Sounds very nice IMO. Sounds raw and hear The turbos better. My only complaint is some vibration inside the car at WOT.
Old Feb 13, 2020 | 01:06 PM
KevinDn's Avatar
2020 C300
Hey, thanks for the insights. Yea i figured muffler deletes would make a lot of drone... Did they cut the mufflers before the electronic actuators? Its mechanism/flaps where if you put it in sport mode, exhaust exits open up more and sounds louder, in case you didn't know.
Old Feb 13, 2020 | 01:09 PM
Yes I’m aware of the actuators but they cut it all off. I would always put it in sport mode anyways and the flaps were always open so didn’t make a difference. There is a little drone but I don’t mind at all.
Old Mar 20, 2021 | 12:27 PM
Supersika's Avatar
2015 S63 AMG
Any Drone Highway speed ?
Any drone Highway Speed??
Old Mar 22, 2021 | 02:05 AM
S63AMG888's Avatar
I did the Resonator delete and added the Renntech EVM, couldn’t be more happier with the sound even in Comfort mode.
Old Mar 29, 2021 | 09:06 PM
ML63 AMG's Avatar
CL63 AMG
Looks like resonator delete is what I will be doing on my new S63 cabrio (which I get to enjoy the sound even more, The question is what about X-pipe? Would it mellow out the sound too much or make it sound better?
x-pipe on my old 5.5L sounded amazing but now sure how putting in on a 5.5L 4-valve would work (sounds amazing on the old 3-valve M113. Anyone tried X-pipes too?
Old Apr 6, 2021 | 07:55 PM
mercshepherd's Avatar
2012 Mercedes CLS550 4Matic, 2014 ML550 Diamond White, 2015 SL550 Diamond White
X Pipe is similar to H pipe in exhaust
There is an H Pipe in the S63 exhaust which joins the left and right exhaust pipes right behind the transmission pan (see photos in precedeing posts of underbody of S63). The H pipe is similar to an X pipe where the exhaust streams and pressures from the left and right banks of the V8 engine meet and equalize in pressure which I believe is important so that neither left or right engine bank is working harder to overcome a different exhaust back pressure. I dont know if any sound will be gained in replacing this H pipe with an X pipe, and it may not be worth the trouble.
I did straight pipe the mufflers on my 2012 CLS550 which gave it a lot more aggressive sound. I left the resonators in place as they take out drone. I also left the X pipe on the CLS untouched
See this link for pics and text
https://mbworld.org/forums/cls-coupe...shop-ohio.html
Old Apr 6, 2021 | 11:41 PM
ML63 AMG's Avatar
CL63 AMG
Yes but X & H sound very different and X pipe does make more power, H makes no difference win power so they are different in both sound & power
thinking I will just do straight pipes, likely the easiest solution
Old Apr 7, 2021 | 03:52 AM
https://www.autoanything.com/resourc...xhaust-system/
"The two biggest differences between an X- and an H-pipe are sound and power. Generally, the X-pipe will deliver a more high-pitched exhaust note, making a car sound more exotic, whereas an H-pipe gives a deeper tone with more of a traditional hot rod sound," says George Rumore of Stainless Works. "X-pipe: Mid-pipes built with a crossover, or "X" shaped design, purposely cross exhaust streams to even out flow and streamline exhaust gasses through the rest of the system. X-pipes are generally raspier and louder than H or Y-pipes and have been shown to provide slightly more power than their counterparts. You are likely to see most of the power gains higher in the rpm band with an X-pipe.
H-Pipe: An H-pipe is better at balancing sound and produces a more consistent, classic muscle car growl. It does less than an X-pipe in the way of balancing exhaust gasses but still flows quite well. H-pipes maintain the back-pressure necessary for torque gains earlier in the rpm band, as opposed to the top-end power seen from an X-pipe."
https://www.americanmuscle.com/musta...s-x-pipes.html
Old Dec 11, 2023 | 02:51 AM
The Truth's Avatar
2015 S63 & 2014 ML350
Were you able to get any sound clips of this? Only a few on YT.
Old Dec 12, 2023 | 12:00 PM
barryrobinson19's Avatar
2016 Mercedes S63 4matic sedan
This is a 2016 S63 4matic sedan. Many mods, however, the exhaust consists of Redstar cat less down pipes, Renntech sport mufflers with electronic valves. I have done all work myself. I feel the car is not too loud and not to quiet. Runs very strong.
Old Dec 12, 2023 | 12:47 PM
phatisfy's Avatar
S-class
https://www.youtube.com/shorts/o4ABRJ2d0L8
Is it me or the exhaust/setup sounds quiet? All I’ve done to mine was a resonator delete and fully opened up the exhaust flaps with a module and it sounds so much louder?
Do you get a CEL with those cat-less DP?
Old Dec 12, 2023 | 12:50 PM
phatisfy's Avatar
S-class
