R-Class (W251) Produced 2006-2013: R320CDI, R350, R420CDI, R500
Where is the satellite radio control module??
Old 04-19-2016, 05:48 PM
jsnowden's Avatar
2009 R350, 2002 E320 Wagon
I have been driving my car around for years with only FM 1 station working. I can connect my phone and play music with iTunes. Navigation works. Originally, I got the "Device Unavailable" message after a battery drain. Dealer wants $3000 to replace system. I have seen the thread under the ML model that said others had this issue and were able to resolve it by unplugging the control module for a few minutes to reset it. I want to find my control module to unplug it and see if that works but I cannot locate it. Does anyone know where it is on a 2009 R350??
Old 04-19-2016, 06:15 PM
marc hanna's Avatar
2008 R320 CDI, 1987 560SL
It sounds like your head unit is defective. There isn't a separate control unit for the radio, it's all integrated. You can try pulling out your head unit and leaving it unplugged for a few minutes.
jsnowden (04-19-2016)
Old 04-19-2016, 06:44 PM
AsianR350's Avatar
08 R350, 07 Acura RL, 1989 Honda Shadow VLX600 (10K miles)
How about remove and plug back the fuse #F25(30AMP) for the COMMAND/DISPLAY in the rear trunk.(spare tire) to reset it.
https://mbworld.org/forums/r-class-w...play-fuse.html
There is an antenna splitter for radio and NAV behind the driver seat and under the carpet. I am not sure it has something to do with it.
Mine did not come with the NAV, so I installed the NAV, I had to buy the antenna splitter to split between radio and NAV.
The following 2 users liked this post by AsianR350:
jsnowden (04-19-2016), marc hanna (04-19-2016)
Old 04-19-2016, 06:49 PM
marc hanna's Avatar
That makes even more sense.
Old 04-19-2016, 07:29 PM
jsnowden's Avatar
"There is an antenna splitter for radio and NAV behind and under the carpet."---where exactly??
Old 04-19-2016, 07:32 PM
jsnowden's Avatar
https://mbworld.org/forums/m-class-w...available.html
This thread is what I was reading regarding the control module, which I cannot locate on my r350. Frustrated!
Thanks for any help!!
Old 04-19-2016, 07:45 PM
marc hanna's Avatar
Deleted post
Old 04-19-2016, 08:10 PM
marc hanna's Avatar
I'm thinking here or here:
jsnowden (04-20-2016)
Old 04-19-2016, 08:17 PM
marc hanna's Avatar
It's actually the Tele-Aid module
Part #'s
1669003400; 2218700826; 2218700926; 2218708726; 2218205226; 2048202085
The location:
http://www.justanswer.com/mercedes/4...isconnect.html
Old 11-26-2016, 12:49 AM
mk2tmr2's Avatar
C32
jsnowden - Any resolution on this? My wife's 2010 R350 just started displaying "Device Unavailable" for Radio, Sat Radio, etc. The only audio we can get is from the CD player. I found the same ML thread as you and was hoping the same un-plug procedure would work for us.
Old 01-10-2017, 12:03 PM
David Ginsberg's Avatar
r350 blutec
hi - anyone have a solution for this? Same thing just happened to me on my 2010 r350 blutec. MB is no help over the phone.
Old 03-13-2017, 01:32 PM
danbokem's Avatar
2009 r320 cdi bluetec
Add me to this as well! 2009 r320 bluetec...battery died and had to get a jump start
everything works but radio "Device Unavailable" I also read the other threads and
now I'm look where I can find the "box" to unplug and re plug all the fiber optic wires mentioned... If anyone can help out with a step by step guidance ...it would be greatly appreciated!
Old 07-04-2017, 06:48 PM
mk2tmr2's Avatar
C32
Jumping in on this, too. Wife's 2010 R350 just started with the same Device Unavailable symptom on radio, etc. The only thing that works is the CD player.
Looking for answers.
Old 12-13-2017, 01:52 PM
R350NYC's Avatar
2008 R350
On that last picture, it says left rear footwell which to me means behind the drivers seat. However, the picture looks like its behind the passenger seat. Can anyone confirm? Also, did this fix your problem?
Old 12-12-2022, 12:44 AM
BramR350's Avatar
2012 R350
Looking for modules on 2012 R350.
Was anyone able to find the modules on 2010 to 2012 R350 bluetech. I m looking for them now after 5 years of this thread being created. Hopefully someone will reply. I still haven't found it documented anywhere. There are videos for.the older 2006 but nothing for newer models.
Can someone help and let me know where the amplifier, sirius and emergency telephone etc is located. I have absolutely no sound and have bought Fibre option loop bypass cables to test each component if I can find them.
Why did mercedes eng made everything so complicated. Battery under the seat, electronics under the carpet.
Quick Reply: Where is the satellite radio control module??
