Old Aug 20, 2017 | 12:03 PM
  #451
Kobzarhomes's Avatar
2011 Mercedes E550 Sport
Yeh, Im leaning towards having it in the bumper, near the plate...
Old Aug 22, 2017 | 02:17 AM
  #452
New wiper rod washers, nuts, seals, covers .
Some sounds deadening at footwell.
Old Aug 22, 2017 | 02:03 PM
  #453
CG 270cdi's Avatar
G 270 cdi
I highly recommend the bumper as a camera location. Of course it depends on your camera but I think this perch has the best visibility.
Old Aug 23, 2017 | 12:10 AM
  #454
Installed passenger side door locks and door caps (not pictured since it looks the same as on the driver side)
installed driver side front and rear glass.
New window channels, new window scrapers, new glass.
Old Aug 23, 2017 | 06:46 PM
  #455
Triplo3950's Avatar
2016 C Coupe 220d Premium Plus
Just finished reading the whole thread. Great job, enough said.
Can't wait to see it finished, congratulations on your passion, it's perceivable by looking at the attention to the smallest detail that no one will ever see.
Old Aug 23, 2017 | 09:14 PM
  #456
Thank you, thank you 👍
Old Aug 23, 2017 | 09:18 PM
  #457
Front passenger side glass install.
Window scraper clips are new for all the doors.
All new stainless steel screws for all window channels.
Old Aug 25, 2017 | 12:33 AM
  #458
Old Aug 25, 2017 | 01:14 AM
  #459
Went to visit Ebay seller "slava81" today from Portland Oregon that has lots of G500, G550, G63 parts. He just parted out 2015 G63 and I had to go and buy some parts from him
I purchased parts from him before, but this time I went in person and got just a some random parts and miscellaneous clips and plugs that are a headache getting from the dealer and some are just not in a catalog.
Anyone looking for parts at good price, should definitely check him out. His eBay page is: https://www.ebay.com/sch/m.html?_ssn...w=w463&_sop=12
**I promise you, he did not ask me to post this about him. He doesn't even know I am, but I think he could be such a big help to allot of the G-Wagon owners that are looking for parts.
Old Aug 27, 2017 | 10:05 PM
  #460
Since all the door glass is new, the rear glass came without that window regulator bracket so I relocated the bracket from the old glass to the new glass using new rubber seals.
Old Aug 31, 2017 | 10:46 PM
  #461
Installed new window regulator and refurbished door wiring on the driver side door.
Old Sep 1, 2017 | 10:31 PM
  #462
I can confirm that this newer switch that was re-wired for me by a guy in Russia works on my 2002 G500 👍👍
Old Sep 1, 2017 | 10:33 PM
  #463
Working on the front passenger side.
Old Sep 4, 2017 | 09:00 PM
  #464
Window regulators and door wiring installed.
Old Sep 12, 2017 | 01:47 PM
  #465
megardt's Avatar
G300d -82, G300TD -94
Hi!
I felt the need to register an account just to say thanks for sharing
Great to see such attention to detail!
Mats
Old Sep 12, 2017 | 03:05 PM
  #466
Thank you 😊👍
Old Sep 14, 2017 | 12:37 AM
  #467
Sprayed the inside bottom of each door with 3M cavity wax spray. Once it dries it becomes transparent (not so milky). Did it carefully to make sure not to get it on the internal parts or sound deadning.
Old Sep 14, 2017 | 01:45 AM
  #468
aerG500's Avatar
Just curious, what is the purpose of the Cavity Wax?
Old Sep 14, 2017 | 01:51 AM
  #469
All cars from factory come with cavity wax sprayed inside doors, and in the cavities all over the body. Its oil/wax based substance that protects areas that could get moisture in them from rusting.
I will be spraying it in other places, inside sides sills, inside the frame, etc...
Old Sep 14, 2017 | 09:34 PM
  #470
Tackling some pre-upholstery prep.
The original leather did not want to come off from the back of the headrest cover. Had to grind it off slowly. Messy job for sure .
here is a picture of before and after .
Old Sep 25, 2017 | 10:38 AM
  #471
Caskieatl's Avatar
G550
Late question, but do you have any concern that all of the extra insulation will cause any mis-alignment of the window lift parts? Or is the tolerance big enough to not be a problem?
Old Sep 25, 2017 | 11:05 AM
  #472
Hello
No, there is no issue with the window regulators. Sound deadening fits just right and nothing is in the way of the window regulators. If I went any thicker, then it would start touching the front regulator.
Old Sep 26, 2017 | 12:28 PM
  #473
YCHU's Avatar
2008 S550, 2004 G500, 2020 Cayenne
In Korea, it's not really uncommon practice, not only just for sound deadening but also to reduce wind noise as well as the noise from ground. They are paying a fortune even on a new, high end cars like Mercedes and Bentley.
Here is one of example, although you can't read Korean, but "m sure you can see the whole thing in photos.
http://blog.naver.com/PostView.nhn?b...&redirect=Dlog
Old Sep 28, 2017 | 12:05 PM
  #474
CG 270cdi's Avatar
G 270 cdi
Are you replacing any door control modules or other control modules?
What is your plan regarding programming? Have you looked into the need to reprogram some of these items so that they work?
I'm asking because an MB Tech told me that I should not replace my door control modules myself but need to take it to the dealer so that they can program them.
I'm curious to know what you think about this considering all your work on these electronic components.
Old Sep 28, 2017 | 12:10 PM
  #475
No, I'm not replacing any modules, I make the new equipment work with original modules.
If modules are replaced, they might need to be programmed, or maybe not. Could all depend on which module you're replacing.
