differential fluid replacement schedule
2016 GLC 250d AMG pack, 2017 GLC Coupe 250d AMG pack , 2002 BMW 330Ci convertible, 2021 BMX X1 sD20i
In Australia, based on annual 12 month or 25,000km service schedule, MBAu have year 5 as the first time for Auto and differential oil change.
Not a cheap service as the auto filter is part of the auto casing and that part needs replacing along with new bolts. So 5 years or 125,000km, whichever comes first. We have a 9 speed box and 4Matic.
Received 3,864 Likes
2017 GLE350 4MATIC
If you plan to own the vehicle to high mileage, replace the oil per MBAG’s schedule. Where no schedule is provided (axles), change the oil before 100k miles. Expect dealers to have no clue which axle oil should be used, because MB doesn’t specify changing it. Use the bevo site, WIS and this forum to select the oil.
2016 S550 sport, 2018 GLC300, M3, Zo7, 2021 Sierra Denali
I did my 2018 GLC300 RWD at 35,000 miles. The diff fluid was in really good condition and not burnt up at all. I did my S550 diff at 30K and it was like new coming out. I have not found this on all cars but Mercedes rear diffs must be polished or set up differently. So there is no rush, but a 50k change of the diff fluid would be good maintenance.
chassis (11-06-2021)
Here is data from my invoice re 5 years auto and transfer case service.
I hope this helps you.
Cheers
Cheers
2017 GLE350 4MATIC
With the GLC as with C- E- and S-, the transfer case and transmission share fluid. So a transmission service = transfer case fluid change, they are one and the same. Not the case with GLE/GLS/G, which used separately sealed transfer cases.
mikapen (11-08-2021)
Received 1,548 Likes
chassis (11-08-2021)
No damage. Sump has to be replaced as MB designed it with filter embedded in it, so new base every 5 years when filter changed, hence the price too.
No damage to vehicle, so I guess all parts replaced are part of the normal requirement.
I might buy the part next time and save 10-15% trade from spares and have service dept fit it during service. Savings all add up as normally no parts discount if Service Dept invoice me as part of service. I did same with brakes and discs and saved close to $500 or 20%.
Again you need to provide your veh VIN to ensure all parts supplied are correct for your build state if you go down that path.
Get approx quote first from Dealer for this work.
chassis (11-13-2021)
Just had my GLC 250d done @ 120 000km (+/- 75 000 miles) And as said above, sump needed replacement. I had the opportunity to see the 'old' fluid, filter as well as the magnetic strip to catch metal filings and it was uncannily clean, to my untrained eye it looked just the same as the new fluid put in. Cost me about ZAR 7 800 (US$ 507) at an independent Merc specialist in South Africa.
is this for sure? as according to the WIS it's not and required a different fluid vs tranny oil.
ninobrn99 (05-02-2024)
Rear and front differential must use the same oil. 253.15 /235 7 spec 75w85. I used Redline 75w85 gear oil. But most synthetic 75w90 are also useful.
Rear diff. Drained 800ml. At 120k km odo.
Not bad.
Easy to refill thru the side fill plug.
Front diff. Drained 500ml. At 200k km odo.
Not bad. Red wine color. I could go 300k km easy.
The side fill plug has no room for 14mm hex socket space. The top black cap was not easy for filling. So i used Mytyvac to pump 550ml oil to the drain plug hole thru a plastic fitting and silicone plumber tape, then quickly replace the drain plug with some spill.
I believe most owners can call them lifetime oil.
or
replace at around 300k km(200k miles) if you drive a lot or you are bored.
The following 2 users liked this post by sn202020:
BlackML550 (04-21-2023),
FreeWoRLD (06-20-2023)
But still I don't want to replace T.C. gear oil utill I drive more than 300K km, because i saw the rear and front diff. gear oil condition that was not bad at 200K km oil replacement.
Document AR33.25-P-0300-01LWX Drain/pour in front axle gear oil
referencing the sheet BB00.40-P-0235-07A which is
MB 235.7/ 235.74 FE-Hypoidgetriebeöl
001 989 33 03 12
75W-85
Document
AR35.31-P-0523LW Drain/fill rear axle gear oil
referencing the sheet BB00.40-P-0239-71A which is MB 239.71 hypoid gear oil
A 001 989 88 03
75W-85
Transfer case uses MB 235.15 spec document BB00.40-P-0235-15A
I have all docs attached. I might missing something, please let me know.
Dave Backmarker (12-07-2023)
Hello, thank you for posting this, but I have to disagree to the specs, my reasons are attached.
001 989 33 03 12
75W-85
Document
A 001 989 88 03
75W-85
001 989 33 03 12
75W-85
Document
A 001 989 88 03
75W-85
but the Redline gear oil has all the MB specs.
https://www.redlineoil.com/75w85-gl-5-gear-oil
click tab of OEM Compatible. then see.
MB 231.1
MB 235.15
MB 235.62
MB 235.7
MB 235.74
MB 239.71
MB 239.72
MB A 000 989 73 04
MB A 000 989 88 03
MB A 001 989 59 03
MB A 0012 989 33 03
MB A 002 989 02 03
so, I will put Redline into all 3 locations of MB 235.15
MB 235.62
MB 235.7
MB 235.74
MB 239.71
MB 239.72
MB A 000 989 73 04
MB A 000 989 88 03
MB A 001 989 59 03
MB A 0012 989 33 03
MB A 002 989 02 03
Front Dif/ Rear Diff/ Transfer Case.
Also I read 75W85 is mainly for the mileage efficiency of the old 75W90.
So i won't hesitate to put generic 75W90 synthetic instead of 75W85.
Anyway, you can still buy all the different OEM bottles from the MB dealership,
but I am a cheap guy, I do not waste money for the MB OEM oils.
Yes, You must be right,
MB 231.1
MB 235.15
MB 235.62
MB 235.7
MB 235.74
MB 239.71
MB 239.72
MB A 000 989 73 04
MB A 000 989 88 03
MB A 001 989 59 03
MB A 0012 989 33 03
MB A 002 989 02 03
so, I will put Redline into all 3 locations ofMB 235.15
MB 235.62
MB 235.7
MB 235.74
MB 239.71
MB 239.72
MB A 000 989 73 04
MB A 000 989 88 03
MB A 001 989 59 03
MB A 0012 989 33 03
MB A 002 989 02 03
Ravenol, Liqui Moly, Pennzoil and Castrol are my preferences (and what is on sale)
Get this, now I found another document BB00.40-P-0231-01A in which MB recommends to use
Rear Diff spec 239.71 and Front Diff Spec 239.72 (75W-85) for Model 253 (2016 - 2019)
So Redline should work just fine, thank you for the link.
Still don't know why different specs in all documents, very confusing.
2010 ML550 VIN WDC1641722A564750, 2010 B180
Still don't know why different specs in all documents, very confusing.[/QUOTE]
I believe that the change in the front diff oil spec was driven by wearing components in the front diffs between 2006 and approx 2010. Many W164s had this problem which is expensive to repair and the updated spec was part of the solution.
see this post for more https://mbworld.org/forums/m-class-w...ilure-fix.html
2017 GLE350 4MATIC
For posterity's sake, please use the operating fluids (formerly bevo) site for fluid specs: https://operatingfluids.mercedes-benz.com/
BlackML550 (04-22-2023)
Finally I got time to replace fluid in transfer case, frond and rear diffs at 39K miles.
TC has similar concept as trany, there is a little tube you have to pull in order to drain the fluid, and use pump to get oil up in the case. Could be easier but not bad. Diffs are simple, except front I couldn't get H14 with socket, had to kick out the bit and user it without socket using wrench.
Old fluids:
Transfer Case
Rear diff
Front diff
In TC and rear used Ravenol, simply because I had 2L of it and it meets the spec
Front diff, one dealer told me to use MB 235.7/ 235.74 another 239.72.
I would use Ravenol as it has almost all specs, but 239.72 but has 239.72
So I used Red Line as it covers them all.
Ravenol stinks so bad vs Red line ))
Old fluids:
Transfer Case
Rear diff
Front diff
mikapen (05-07-2023)
$500 US at MB Dealer
I paid $500 for my transmission fluid and filter tray to be flushed and replaced by MB dealership local to me in SC. I've had this service done on both my ML350 as well as my GLE400 by them. I usually add it on to other things like brake flush, coolant flush and oil change just to get all my fluid refreshed in one big fat expensive B service that's like $2800 all together.
Alternatively, this guy shows you how to do it with FCP Euro parts at 21:55 in this video. If I had a lift like he does, I'd probably do more of this stuff myself as well
Take care
Joel
Take care
Joel
https://www.youtube.com/watch?v=3TtYJuJDbks
Take care
Joel
Take care
Joel
chassis (05-02-2024)
