SL-Class (R129) 1990-2002: SL 280, SL 300, SL 320, SL 500, SL 600, SL 60 AMG
SL/R129: Crankshaft Position Sensor Location
Old 04-08-2015, 11:02 AM
OCBroker's Avatar
SL 320
Please Help. I can not locate the cps on my 1994 SL320. It is not over/under/near starter.
Old 04-08-2015, 10:05 PM
cliffyk's Avatar
1998 SL500
It is at the top of the engine, to the rear of the intake manifold:
Old 04-08-2015, 11:11 PM
OCBroker's Avatar
SL 320
Thank you very much
Old 04-09-2015, 12:15 AM
cliffyk's Avatar
1998 SL500
You are quite welcome...
Old 04-09-2015, 12:18 PM
OCBroker's Avatar
SL 320
I still can not find it. Do I have to remove any covers?
Old 04-09-2015, 12:43 PM
cliffyk's Avatar
1998 SL500
I am sorry I just realised you have an SL320. It should be one of these:
Old 04-11-2015, 12:12 PM
OCBroker's Avatar
SL 320
Please help! My 1994 sl320 . I have replaced wire harness, fuel actuator, spark plugs, fuel filter, voltage regulator, MAF, o2 sensors, cam sensor, crankshaft sensor and checked vacuum lines as best I could. All to no avail. The car starts fine but idles between 1200 and 1500 (oscillating) when I give it gas it dies.
Old 04-29-2015, 01:08 AM
landcrabmech's Avatar
95 500SL
I am dealing with the same issue on a 95 SL500, I am leaning toward the Cats being clogged. I am going to check it this weekend and will get back to you.
I just posted SL500 stalling issues.
landcrabmech
Certified HD, CT, Auto technician
Vancouver Canada
Old 05-02-2015, 12:31 PM
OCBroker's Avatar
SL 320
I do not think it is your cats. I just installed a re-wired and tested Throttle body. The car runs great. The first place I sent it did not bench test it after rewire. BBA-Reman fixed a broken wire in unit and returned it in three days.
Old 05-03-2015, 02:03 AM
lynns's Avatar
2000 SL500
Originally Posted by OCBroker
Please help! My 1994 sl320 . The car starts fine but idles between 1200 and 1500 (oscillating) when I give it gas it dies.
It sounds like you should pay to have your car checked with a MB Star Diagnostic Scanner (SDS) for Diagnostic Trouble Codes (DTC's) before you go any farther. I don't believe your problem is with your CPS. Your car would exhibit a different problem than what you have detailed. It would stop running when hot and restart when it has cooled down. One way to test a CPS is to pour cool water over the CPS and see if the car restarts.
Quick Reply: SL/R129: Crankshaft Position Sensor Location
