SL/R230: Roof opens until trunk lid straight up windows 1 3rd open B1010 Event Code Please hel
Hi Guys:
I hope u r well. Can u help me fix my2004 SL500 AMG vario roof opening intermittent problem please? The opening cycle operates until the trunk lid is open straight up, then the windows open about one third of the way down. The pump is still running while I hold the center console switch open. If I release the switch, and hold it open again, the windows roll down a bit more. A few days ago the roof opened and shut normally. Weeks earlier I had the current problem again.
See the attached pdf file VarioRoofDiagnosticAid pages 14 and 19 of 23. The pictures may indicate S92 & S93 Shorted/Sticking, or S119 Open. However, neither picture shows the windows partially rolled down that I can see. I hope someone had the windows partially down symptom.
I switched S119 with a seemingly good switch from another car. (That roof does not work. So the switch may not be reliable. However, both switches click when opened to the right height.)
The S92&S93 and wiring are behind the closed roof headliner trims. I repaired a shorted wire on my SLK230. Can that be the problem?
I doubt the B1010 voltage event is the problem.
I get actual values not recognized – 320 implausible… switches…, and 491 roof open in end position
I had some fault codes earlier; but not now.
For example, with the trunk straight up, S119 should be recognized (trunk up) S69/2 & S69/3 should be not recognized (roof not locked to windshield). You don't need to see the switches or wiring to know what the controller is seeing. If the status is inconsistent with reality, then you need to dig further. For example, if your S69/2-3 is showing recognized, but you know they are not locked you probably have a shorted wire (could be sticking switches, but they are in series so both would have to stick).
You didn't mention if the flaps are deploying. If they deploy, S119 was recognized. Note that shorts during roof movement or switches losing/gaining contact can cause some scenarios not depicted in the guide. It assumes the problem exists at the beginning of the cycle.
The roof decided to open again. Does the rear right roof pillar headliner trim pull straight off to expose the wiring? I will check the wiring for abrasion.
Someone attached a pipe where the post was to the right roof close mechanism. See pictures. Can this be causing intermittent WRONG status roof open or closed signals? How do I fix it?
The wiring is on the left rear roof pillar. I guess this could be pinched at a fold. I think this is from the S92&3. Could that be the source for shorted or sticking switches signal?
A shorted/sticking issue with S69/2&3 would mostly likely be a short between the two wires or a short to ground along the frame. Switches are wired in series, so both would have to stick to be 'stuck', highly unlikely.
Can someone read the actual data below when the roof was stuck, and say why it was stuck please? I think the 1 of 3 Frame indicates switch functionalities. For instance:
372 Vario roof OPEN NOT RECOGNIZED
373 Vario roof CLOSED RECOGNIZED
374 Vario roof INTERLOCKED NOT RECOGNIZED
Does this mean S91says the roof is closed, and not locked in closed position; and switch 91 is not working, sticking, or shorted? … very confusing… What can I do?
Roof stuck, pump running, trunk lid straight up, windows 1/3rd down:
---------------------1 of 7 Frame---------------------
318 Open vario roof using NO
control switch or infrared.
319 Close vario roof using NO
317 Vario roof position In valid intermediate position
320 Implausible status of the NOT RECOGNIZED
vario roof limit switches
321 Abort conditions for vario NOT RECOGNIZED
roof limit switches
322 Vario roof in stop mode YES
323 Vario roof subsequently NO
locked
324 Vario roof in emergency mode NO
---------------------1 of 3 Frame---------------------
360 All windows open NOT RECOGNIZED
370 Rollover bar lowered RECOGNIZED
371 Rollover bar raised NOT RECOGNIZED
375 Loading assist UP RECOGNIZED
376 Loading assist DOWN NOT RECOGNIZED
377 Side flaps FOLDED IN RECOGNIZED
378 Side flaps FOLDED OPEN NOT RECOGNIZED
379 Tubular frame OPEN RECOGNIZED
380 Tubular frame CLOSED, LOCKED NOT RECOGNIZED
381 Luggage compartment division RECOGNIZED
CLOSED
382 Trunk lid OPEN NOT RECOGNIZED
383 Trunk lid CLOSED (Locking RECOGNIZED
pawl opened)
384 Trunk lid CLOSED (Rotary RECOGNIZED
tumbler closed)
---------------------1 of 10 Frame---------------------
420 Pump temperature 15°C
430 Status Pump temperature Temperature < 85°C
431 Rate of rise of pump NO temperature is too high.
493 Hydraulic unit o.k. YES
---------------------1 of 4 Frame---------------------
440 Actuation : Open side flaps NOT RECOGNIZED
of rear shelf.
457 Actuation : Hydraulic pump NOT RECOGNIZED
452 Actuation : Main valve NOT RECOGNIZED
455 Actuation : Open tubular RECOGNIZED
frame and locks.
456 Actuation : Lower load NOT RECOGNIZED
assist.
453 Actuation : Close vario RECOGNIZED
roof.
454 Actuation : Open vario roof. RECOGNIZED
450 Actuation : Fold in side NOT RECOGNIZED
flaps.
451 Actuation : Raise rollover NOT RECOGNIZED
bar.
458 Actuation : Backup RECOGNIZED
transistor
I was a little confused with the 453/454 both being recognized, but I think that is because it is in stop mode.
When the roof gets stuck, I see the 2 front windows have just come down/open about 1 3rd. I have not noted the rear window positions.
I was waiting to move the roof until I have analyzed and tried all I can. Then with the top up, I’ll check for windows going to short stroke position.
How do I fix it? I disconnected both batteries, pulled the 40 amp fuse in the engine compartment on the right. It seems odd that it worked intermittently, and won’t work at all now.
Does anyone have the 2004 fuse chart A2305450200?
Maybe you can tell something from the actual values below.
Trunk straight Up Windows 1/3rd open pump running
---------------------1 of 2 Frame---------------------
300 Ignition ON YES
310 Voltage supply o.k. YES
311 Pump temperature OK YES
312 Vehicle speed below shutoff YES
threshold
313 Solenoid valve and pump YES
outputs OK
314 Position and function of YES
limit switch are ok
315 Activation of rollover bar YES
NOT ACTIVE
316 Actuations using diagnosis YES
NOT ACTIVE
480 Power supply Loading assist YES
490 Solenoid valve and pump RECOGNIZED
outputs OK
491 Vario roof is open and in NOT RECOGNIZED
the end position, trunk lid is
open
492 Switch N72s17 (Rollover bar RECOGNIZED
switch) not operated
494 Activation of rollover bar NOT ACTIVE
495 Actuations using diagnosis YES
NOT ACTIVE
496 Vehicle speed with ignition YES
switched on below threshold value
497 Load assist switch NOT OPERATED
intermediate
position
roof limit switches
locked
CLOSED
pawl opened)
tumbler closed)
85°C
of rear shelf.
455 Actuation : Open tubular NOT RECOGNIZED
frame and locks.
assist.
453 Actuation : Close vario NOT RECOGNIZED
roof.
454 Actuation : Open vario roof. NOT RECOGNIZED
flaps.
bar.
458 Actuation : Backup NOT RECOGNIZED
transistor
of rear shelf.
frame and locks.
assist.
roof.
flaps.
bar.
transistor
SL Diaglink 02262023 Window left side rear not working
130 Manual opening NOT REQUESTED
140 Manual closing NOT REQUESTED
141 Automatic opening NOT REQUESTED
142 Power window blocking NOT REQUESTED
143 Lowering in the case of NOT REQUESTED
vario roof operation
144 Raising in the case of vario NOT REQUESTED
roof operation
147 Closing relay NOT REQUESTED
148 Opening relay NOT REQUESTED
075 Voltage supply of Hall YES
sensors
080 Hall sensor signal YES
151 Supply voltage of Hall 11.2 V
sensors ( Left rear )
081 Direction of rotation of YES
power windows
076 Short stroke function ACTIVE
073 Window in short stroke NO
position
030 Window prompter position 1 61
left (default setting 64)
032 Window prompter position 2 40
110 Short stroke function : NO
Closing blocked
074 Power window NORMALIZED
072 Blocking RECOGNIZED
077 Window open ( Left rear ) RECOGNIZED
078 Window closed NOT RECOGNIZED
079 Window below AAC position NOT RECOGNIZED
071 Closing relay NOT ACTUATED
070 Opening relay NOT ACTUATED
149 Closing relay NOT SWITCHED
150 Opening relay NOT SWITCHED
060 Window position on left 0
082 Current consumption of power 0.0 A
window motor ( Left rear )
just worked on a front passenger window on an '09 yesterday that was doing pretty much the same thing. It was a bad door module.
I want to pull the left side rear window while the top is up. Is this a big problem? Will I be able to pull the large formed plastic cover, much less the window and motor assembly? Must I detach the window from the assembly? Can I activate the window down sensor to lower the top first? Where is that sensor? Can I do anything with the wiring like power up the motor or sensor?
When I get the motor assembly out or before removal, how do I make certain I have a bad motor to replace?
See pictures.
See this utube video for removal procedure with top down.
Can I power up wires in the installed wire bundle to test that motor? Would it be necessary to disconnect the car’s batteries first?
Can I power up the hall sensor to make the car think the window is down; and lower the roof?
The window motor was faulty. I removed the electrical connector at the motor, and connected it to the new motor assembly. This allowed me to lower the roof. I removed the last sheet metal above the assembly, the formed plastic piece, and (2) 13mm nuts to allow the motor assembly with window attached to easily lift out. The electrical connector clips were broken on at least 1 side. I used a fireplace poker hook to pull the connector up on the far side. I pried up with a long screwdriver on the other side. Then I pulled the wire bundle up to slide the connector apart.
