SL55/63/65/R230 AMG: KLEEMANN Bi-Turbo ECU SPECIAL!
Old 01-22-2009, 11:52 PM
  #51
JackStraw's Avatar
2005 SL600, 2011 Honda Odyssey Touring Elite
I found this list of weight-reducing tips and tricks for improved drag-racing performance, most of which make switching to lightweight wheels seem downright sensible.
http://www.dragstuff.com/techarticle...reduction.html
I wasn't able to find any resources that I considered reputable that could help me understand how to quantify the effect of lighter weight rims on 1/4 mile times, but am sure that there must be some effect.
I wish you continued success.
Old 01-23-2009, 02:38 PM
  #52
TMC M5's Avatar
'14 E63S & '14 Audi SQ5
Originally Posted by bigmike32172
From what I was told there is a 100 octane tune, a 93 and a 91 tune. They can not be changed by the customer with a switch, etc. You get the tune and that's what you're stuck with unless you bring it back to the programmer to reflash the computer for a different octane tune. Whatever octane tune you get, don't ever put a lesser octane in it, but you can put a higher octane in it within reason without problems.
I spoke to Cory at Kleemann. There are only two tunes they offer: #1 a regular tune set for 91 octane gas and #2 a tune specifically made for 100 octane gas (and only recommended for full time use with 100 octane).
Tom
Old 01-23-2009, 04:08 PM
  #53
Former Vendor of MBWorld
GMP Performance's Avatar
W211 E500 Estate
last time I checked there was a 93 tune as well.
Old 01-23-2009, 05:05 PM
  #54
Busa196's Avatar
2018 S63, lowered
That was my understanding after speaking with Brandon as well.
Old 01-23-2009, 05:21 PM
  #55
racinghart's Avatar
sl600 05 cls55 06
Wow, I finally got my tcu out this morning, my both arms and shoulders are all tired up now. Getting out the tcu is just an hassle. Took me like an hour.
IWell, t is on the way to Cory now and let see if it is a real deal for this tuning special. I have been waiting for some change since I get a little used to the power of 600 for two years. Time for her to step up. Will post up some result and dyno graph soon.....
Old 01-23-2009, 05:28 PM
  #56
TMC M5's Avatar
Per my conversation with Cory, they found no significant difference between 91 octane and 93 octane to allow more aggressive boost or ignition maps. The ECU is adaptive and will always run as much boost and ignition as it can based on ambient conditions (temp, humidity, etc.). That is why they do not have separate 91 and 93 octane tunes. The 100 octane gas with a much different density and burn characteristics would allow a significant change in boost or ignition maps.
Not sure why there are two different messages...
Tom
Old 01-23-2009, 05:34 PM
  #57
Carl Lassiter's Avatar
'08 M5, '10 Land Cruiser
Tom
Seems odd it there would be no difference. Out here in Cali we definitely make less power stock with our 91 than the East Coasts guys and their 93. It says on the gas cap minimum 95RON which is what 91AKI equates to and recommended is 97/98/99 RON which is 93AKI. I'd say we're losing about 10hp, but that's just off the top of my head.
I'm a simple man so I'll put it simply- Cali gas is pig swill.
Old 01-23-2009, 05:35 PM
  #58
W211 E500 Estate
Because 91 octane us not available in most places on the east coast
Old 01-23-2009, 05:38 PM
  #59
W211 E500 Estate
I agree, we are a master distributor for APR software for VW AUDI AND Pcars, and they give us different tunes and different power numbers to quote customers for 91, 93, and 100. Not try to compare teh two companies but most vw and audi are forced inducted motors and Porsche obviously has their turbo cars.
But unless I'm mistaken Kleemann has been sending us ECU's back with 93 octane tunes.
Cory can you step in here and help get to the bottom of this?
Old 01-23-2009, 05:51 PM
  #60
TMC M5's Avatar
Carl:
You crack me up!
Over here on the East Coast we used to be able to get Ultra 94 octane at every Sunoco station... they stopped that as most states outlawed the octane boosting additive in the Ultra 94 because it was dangerous if it ever got into the water supply...
+1
Tom
Old 01-23-2009, 05:59 PM
  #61
W211 E500 Estate
Yeah I remember good old 94. lol, I always wondered why i couldn't get it anymore.
I have 100 octane almost readily available in many spots within a 20 miles radius of my home
Old 01-23-2009, 06:08 PM
  #62
TMC M5's Avatar
The closest 100 octane racing gas at the pump is about 40 miles away from me. A couple of months back I did two full tanks (literally pulled up on fumes each time) in two weeks at $400+ dollars. I realized that was spending more to feed my car than my g/f...
Tom
Old 01-23-2009, 10:34 PM
  #63
Thericker's Avatar
V12-Biturbo
+3 when I spoke w/Cory & others w/Kleemann V12 tt tunes they all said they were set for 93 octane, Cory said ONLY if the customer can't get 93 regularly will they get 91 ECU tune....
I hate CA tree hugger ***** 91, I routinely spike it w/Torco from what I've heard it is basically 87 octane that's treated w/boosting agents like Toloune (sp) etc..to bump it up to massive 91
Also multiple tuners have told me it is horrible low-grade gas, giving sub-par perf esp on boosted app's..
Old 01-24-2009, 12:59 AM
  #64
Marcus Frost's Avatar
Real Cars
You guys might think it's crazy, but if I was living in CA I'd install a pump at my house. Here in IL back in the day you could buy race gas by the 55 gallon drum. All you'd need then is a pump, and a safe place to store the drum. It's not cheap, but it's MUCH better than running that 91 **** water they serve you at your station.
Fortunately we still have good ol' 93 round these parts... not to mention plenty of stations that pump 100.
-m
Old 01-24-2009, 03:49 AM
  #65
Thericker's Avatar
V12-Biturbo
-m
Hell I just drive around w/case of Torco in my trunk I'm so jealous you guys get 93 arghhh CA is lame.... We do have a handfull of stations in LA (1 1/2 hrs away from me) that serve 100 oct though...
Old 01-26-2009, 11:36 AM
  #66
W211 E500 Estate
100 octane is the shiznit!, I'm able to switch programs via my cruise control switch in my new GTI. Ran the 100 at CMP in south carolina and man was it a blast. By my 5th session the back of the car and my tips were all black lol.
Old 01-26-2009, 02:55 PM
  #67
TimsSL65's Avatar
09' Ferrari Scuderia 16M Spider, 11' Mercedes SL63 AMG, 09' Mercedes S550
I finally got around to sending my SL65 chip to Kleemann for the $2500 special. After installation (Friday), I'll be certain to post some seat-of-pants feedback.
Tim
Old 01-26-2009, 06:27 PM
  #68
BoatRacer's Avatar
SL65 - ML63
Tim
Hi Tim - I'm new to this forum but would like to hear of your satisfaction with the Kleemann ECU upgrade as soon as possible.
Thanks in advance,
Dave
Old 01-26-2009, 08:00 PM
  #69
TimsSL65's Avatar
Thanks in advance,
Dave
I'll post some feedback over the weekend.
Tim
Old 01-26-2009, 10:12 PM
  #70
bigmike32172's Avatar
SL65
Way to go Tim! Can't wait to hear the feedback from ya
Old 02-02-2009, 08:41 PM
  #71
staffcurtis's Avatar
2005 SL600
I just put my order in for the Kleeman special....Don't even have the car yet, but the SL65 should be here on Thursday.
I can't wait!!!
Old 02-02-2009, 09:04 PM
  #72
TimsSL65's Avatar
I can't wait!!!
I had my Kleemann ecu installed last week...I love it!
Tim
Old 02-03-2009, 10:17 AM
  #73
W211 E500 Estate
I can't wait!!!
Thanks for the biz. Staff, you need to come down to charlottte when you get it!!!
Old 02-22-2009, 12:02 PM
  #74
RNSL65's Avatar
SL65 AMG, X5-4.8i M-Sport, 530D, 528i
@ Cory
I’ve got an SL65-AMG and I’m very interested in your ECU tune. I know you have explained some of the details above in this thread, but would like to have a little more details on these to questions:
We have 99RON (octane) available allover in Denmark where I’m from, how will this affect the ECU tune?
As I’ve read in this forum Kleemann supposedly have a 100 octane tune – will this work or not?
I’ve read your commend on the TCU tune, that it is mostly recommended on SL600 – what exactly will I benefit from this or is it not necessary. (I’m not doing drag racing)?
Old 02-23-2009, 11:07 AM
  #75
W211 E500 Estate
One way or another, I think the software tune you need for 99RON is available but the TCU tune for the AMG 65 is not much of an upgrade. The 600's benefit it more because it allows it to shift like the AMG cars (much quicker) which means faster acceleration times.
You have already rated this thread Rating: Thread Rating: 1 votes, 3.00 average.
Quick Reply: SL55/63/65/R230 AMG: KLEEMANN Bi-Turbo ECU SPECIAL!
