SL55/63/65/R230 AMG: SL55 Performance Upgrade Packages Compared
Old Feb 14, 2012 | 02:00 AM
edin_sl55's Avatar
2003 Mercedes SL55
Exclamation SL55 Performance Upgrade Packages Compared
I have searched the forum and was not able to find a competitive listing as far as horsepower vs cost goes for Performance Upgrades. With that in mind, I'm in the market for a stage 1 performance kit but I'm having a hard time choosing the performance package.
To help others as well as myself it would be nice if we could use this thread to centralize this information.
The format for the comments can be as simple as:
- List of performance upgrades
- Dyno Sheet
- Track Times
- Etc
*Please do not post upgrades or suggestions if there is no data to backup the claim of 50,60,...,100+ hp gains. I have discovered that the hp numbers are being thrown out there without significant data to prove that the upgrade significantly increased the performance of the SL55. The idea would be to see the power curves and compare vs. stock.
I hope that distributors can pitch in and help us populate this centralized thread with information necessary to make the right decision the first time around when choosing performance upgrades...
Old Feb 14, 2012 | 02:05 AM
edin_sl55's Avatar
2003 Mercedes SL55
Evosport Evo1+ Power Package
evosport - evo1+ Power Package - All 55 AMG Kompressors (M113 5.5L V8 Kompressor)
evo1+ Power Package
- evosport fully dampened overdrive crankshaft pulley
- evosport black anodized billet aluminum underdrive pulley kit (water pump, alternator & power steering, belt)
- Powerchip/evosport custom-tuned software
Power Gains (CA 91 Octane)*:
- +4 lbs Boost (0.3 bar)
-Gains: 45+ HP, 55 ft-lbs.
- 550 HP, 613 ft-lbs.
For more information click here to visit Evosport detailed product page
Wheel Horsepower / Torque curves below as indicated on Evosport's webpage
Old Feb 14, 2012 | 09:27 AM
euphoriaDSM's Avatar
SL65 AMG
Is that whp? I ask cause you can make a dyno read what ever you want.
Old Feb 14, 2012 | 01:01 PM
kustom2k1's Avatar
03SL55
- Dyno Sheet
- Track Times
- Etc
Your splitting hairs. This platform has been around for a decade. Pick one of the top parts guys and a great tuner...your good to go. Not flaming just a heads up. Larger pulley (168/172) headers and good tune is good for 60 to 100 horse gain in some cases.
Old Feb 16, 2012 | 09:36 AM
edin_sl55's Avatar
2003 Mercedes SL55
I understand but within the last decade there is no real answer as to what kit will provide the best bang for the buck. Each kit is slightly different, one "top parts guy" provides a tune that will get 40hp and then another provides a kit with pulley and tune that gets 50-60hp. My goal is to simplify the process and with the help of all of the experts on this forum and the "top parts guys" I believe it can be done. We just have to work together and build some centralized point which contains it all.
Old Feb 16, 2012 | 05:46 PM
Maverick1975's Avatar
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
I think if you spend a bit of time collecting the names of vendors of upgrade packages and then checking their wbsites or looking at old posts you will get a good idea. Search function is your friend here!
Old Feb 21, 2012 | 03:36 PM
Exotic-metal55's Avatar
PLATINUM SPONSOR
2003 CL55
Find the best deal on a 180mm kit, tune and coolling mods and you have a solid stage one package under 1500.00. Deals all over the place for stage one aprts and tunes and most all make the same power now at the stage one level.
__________________
www.ultimatepd.com
instagram @ultimate_pd
facebook.com/ultimatepd
Old Feb 23, 2012 | 01:17 AM
edin_sl55's Avatar
2003 Mercedes SL55
I have searched and a stage 1 kit with 180mm pulley and tune is well over 1.5k.
I understand that we can all search for the information but wouldn't it bring more sales to the suppliers if all of the facts were just laid out and available in one spot?
Old Feb 25, 2012 | 01:29 PM
kingnash's Avatar
03 SL55
+1
Old May 17, 2020 | 12:31 PM
cruzmisl's Avatar
2019 Mercedes Benz E63S
Oops wrong thread​
