SL55/63/65/R230 AMG: ECU tuning input
Old Feb 28, 2019 | 04:56 AM
03sl55amgmjd's Avatar
2003 SL55 AMG GT , 2000 BMW 323I coupe
ECU tuning input
I purchased the 83mm clutched SC pulley and am considering using Presser Tech in GA. to perform a stage 2 tune.
Has anyone used them, heard of good or bad things about them?
The tuner I'm communicating with has the same SL 55 AMG as me and has tuned his own car. They specialize in MB tunes and are telling me they'll return my ECU that will have my car putting out 580HP with 612TQ.
Are those numbers realistic?
Any feedback would be helpful.
Old Feb 28, 2019 | 09:00 AM
meadows222's Avatar
'05 SL55 AMG, '00 SL500, ‘99 SL600, '83 380SL, '15 S550 Coupe
Old Feb 28, 2019 | 10:38 AM
57staff's Avatar
2008 CL550
I went with RaceIQ tune after getting my pulley changed. About 520 HP and almost 600 TQ. Has been very reliable. Make sure you swap out your IC pump for the newer version Bosch unit.
Old Feb 28, 2019 | 03:05 PM
57staff,
Thanks for the info and actual results after the tune.
Does 580 HP and 608 TQ sound unachievable? That's what I'm being told will be my new numbers after they do a stage 2 tune. My only mod is an 83mm pulley install.
Is it mandatory to install the updated Bosch water pump or is it suggested?
I'm not an aggressive type driver constantly, but I certainly don't want to damage internals due to neglecting to update the pump.
Thanks for your help,
Mark
Old Feb 28, 2019 | 03:30 PM
soloz123's Avatar
2014 GL450
Just do a before and after dyno! My car with the 83 and headers made 485 WHP and 540 FTLBS. It was a beast! It was also dyno tuned by eurocharged!
Old Feb 28, 2019 | 04:27 PM
57staff's Avatar
2008 CL550
The thing I have heard about Presser Tech stage 2 tune is they get pretty aggressive with the A/F mixture. The Stage 1 tune is very similar to the RaceIQ tune with similar numbers.
You are not in danger of hurting the engine by not replacing the pump. It will be just that your S/C will become heat soaked and you'll loose power. The replacement Bosch pump is much more capable and durable. As you push power beyond a stage 1 tune improving the IC capacity becomes paramount.
Old Feb 28, 2019 | 04:56 PM
Thanks for the feedback, everyone.
Regarding the updated Bosch IC pump, is that a relatively easy swap-out or is it a dealer expense?
If the pump is hard to get to and a lot of other parts need to be removed to do this job, I'd rather pay the experts.
Anybody put that pump in themselves?
Old Mar 1, 2019 | 06:44 AM
smithwn55's Avatar
SL 55 AMG, BMW M Roadster, Holden Commodore SSV
Originally Posted by 03sl55amgmjd
57staff,
Mark
As has been said before by others way more knowledgeable than me, the absolute dyno numbers don't really matter as results can differ greatly. What does matter is the relative change in hp and tq pre and post tune/mods. Make sure you test on same dyno in as similar weather as possible.
Bill
Old Mar 1, 2019 | 02:50 PM
Nor Cal SL55's Avatar
2012 E63 AMG
It's and easy plug and play and accessible from under the car. You may have to take the pan/cover off (don't remember). The pump is located behind the bumper in front of the passenger side (US) front tire. The part is about $120.00 If you look at the part and see part number 0392022010, then the pump may have already been replaced. The old pump number ended in a 03.
Old Mar 1, 2019 | 03:22 PM
2012 E63 AMG
Here's a good DIY video
https://mbworld.org/forums/w211-amg/...-pump-diy.html
There is also a rubber tube on the rear of the old style pump. The new pumps have a place to land this rubber hose, but is not drilled out. I don't have an older model SL55, so I don't know the significance of this rubber hose on earlier models. FYI
Old Mar 3, 2019 | 10:20 PM
Das Geld 2's Avatar
SL55, S500
580 sounds too high.
Pump is 15 minute swap
