SLK/R171: Anyone else noticed engine whine?
I don't think it's related to high revs, because I've heard it as low as 2500. But, of course, I also tend to hear it mostly when there is something nearby for the sound to reflect back from (buildings, parked cars, etc). So it may just be that I started noticing it, but I'd also felt I should ask in case a problem is developing...
I think the noise from the engine compartment really makes the car sound cheap.
-- I'm hearing it a lot.Maybe they'll tell me it's normal, but I'd rather have it checked to be sure. After all, they'll be the ones doing any warranty repair.
FAULTY, NOISY IDLER BELT PULLY BEARING
RUN ENGINE. VERIFY WHINE NOISE FROM ENGINE.. RACK VEHICLE. R&R GRAVEL SHIELDS. NOISE FROM FRONT OF ENGINE. TO ACCESS, R&R RADIATOR ELECTRIC FAN. USING STETHESCOPE, LISTEN TO WATER PUMP, ALT, POWER STEERING PUMP BEARINGS. NOISE FROM ONE OF THE IDLER PULLYS. R&R POLY DRIVEBELT. SPIN PULLYS. CANNOT DETERMINE NOISE. R&R IDLER PULLYS. SPIN BY HAND. UPPER IDLER HAS SLIGHT ROUGHNESS WHILE SPINNING. REPLACE IDLER PULLY. REINSTALL BELT. START ENGINE, NOISE GONE. REINSTAL RAD FAN. ROAD TEST.
But having this resolved in just one trip (and less than a day!).... priceless!
