SLK55 (R171) 2004 - 2010: SLK200K, SLK280, SLK350, SLK55, SLK55 Black Series
Blue smoke?
Old Feb 2, 2005 | 11:39 AM
Marky-Mark's Avatar
SLK55 AMG
Question Blue smoke?
Hi Folks
As you may recall my (UK) car arrived early, just before Christmas. Last week the car was delivered to my home but as yet I have not registered it (as I await the new/next UK registration on 1st March) so the best I can do is familiarise myself with the controls and shuffle the car around on my driveway - torture!
I am absolutely delighted with the car so far, however, I have noticed that on a couple of occasions I have started the engine (from cold) for there to be an emission of blue smoke from the exhausts? I have never owned a serious performance car before therefore I just wanted to get some thoughts from yourselves as to whether this might be of concern.
The smoke stops as soon as the engine is running. I was guessing that the blue smoke may be oil with the engine still being new and the car having only done a total of 31 miles. My previous car was an SLK320 but the engine in that car hardly consumed any oil in the 3 years I owned it.
I have attached some further photos of the car for you to take a look at.
Best regards
Marky-Mark
Attached Thumbnails Blue smoke?-dscf0026.jpg   Blue smoke?-dscf0028.jpg   Blue smoke?-dscf0030.jpg   Blue smoke?-dscf0032.jpg
Old Feb 2, 2005 | 12:21 PM
fredfromny's Avatar
SLK55
Thats one hell of a sweet looking car! Good luck!
Old Feb 2, 2005 | 01:20 PM
lisamcgu's Avatar
Gorgeous! I can't believe you can wait until March 1st! Wait until you see the looks you get from more than the neighbors. It will double in memory the torture you went thru not being able to drive it all that time :p
Old Feb 2, 2005 | 02:08 PM
Yellow R1's Avatar
'93 RX-7, SLK55
Originally Posted by Marky-Mark
Hi Folks
Best regards
Marky-Mark
Marky, its residual oil & its burned off immediately. This is normal & not a "bad" thing (it means your motor is getting lubricated while its cold where most engine damage occurs due to a lack of lubrication). These engines are hand built & have an excellent oil supply which helps to minimize engine wear, even at start up as you have witnessed yourself.
Enjoy the car!
-Matt
Old Feb 2, 2005 | 03:13 PM
hang_man1's Avatar
Hi sweet car if u dont mind how much did u get it for it looks pretty loaded?
Old Feb 2, 2005 | 04:21 PM
hang_man1's Avatar
did u manage to get a discount/good deal?
Old Feb 2, 2005 | 05:20 PM
sjcrash's Avatar
2005 slk55
I had alot of blue smoke for the first few days of ownership, it seem to have becoming just a whisp now. The biggest thing I'm still getting used to is the short up-reve right when you turn on the ignition and the sound of the V8.
There seems to be a problem with the '55 AMG and a short vaccume hose, so if your engine light comes on it might be that. Also check the soft rubber seal around the windows to make sure it's seated correctly and not crimped by the window. Be careful not to hit the shift buttons on the back of the stering wheel when you turn; it was a problem for me the first few days.
Have fun, I just crossed my 1000 mile mark earlier this week :-).
-Andrew
Old Feb 2, 2005 | 07:30 PM
CP1's Avatar
CP1
SLK 55 AMG
I still don't understand why they keep putting the steering wheel on the wrong side of the car. Or are the pics reversed? :p
Old Feb 3, 2005 | 06:20 AM
Marky-Mark's Avatar
SLK55 AMG
Thanks for the assurances, folks. I was guessing that the blue smoke might have been something along the lines of lubrication when cold.
I paid ~£56,500 (~$106,750) for my car and yes it is pretty much fully loaded.
My only other grumble was about my dealer who filled the car with cheap petrol (RON 95) when the manufacturer recommends RON 98, which is what I am intending to run the car on - any comments?
Rgds
Marky-Mark
