W210 AMG oil filter location??
thanks!!
3 inches round, front right of motor right next to you power steering resevour (sp?). Loosen that first than drain your oil. is takes 7.9 qts. Make sure you use synthetic, MB recomends Mobil 1.
http://www.mercedesshop.com/Wikka/OilFilter2
manual does say 8 quarts, but in actuallity is closer to 8.5 quarts since you'll need some oil for the filter to get soaked in.
as far as the filter socket is the special tool from MB they run under $20, and you'll need a 22mm socket for the other end of it.
3 Orings on the filter. (filters come with 5 orings, since newer cars use same filter but have more orings, don't let that throw you off ;p)
0w40 mobil 1 always ;p
