Pressure on 19 tires
Old Oct 3, 2011 | 10:29 AM
maxwerks's Avatar
06 CLS55 Renntech stage 5, 04 CL600 ( will miss ),02e55 , 11 R350
I am curious what pressure is everyone running with the size 19 tires ? I am running 40 all around .
Old Oct 3, 2011 | 12:49 PM
desired_speeds's Avatar
2007 SL55 AMG
I'm running 34 all around
Old Oct 3, 2011 | 07:25 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
I keep mine around 36.
Old Oct 3, 2011 | 08:13 PM
suicidal4life's Avatar
2001 E430
I'm running 40
Old Oct 3, 2011 | 11:10 PM
maxwerks's Avatar
Originally Posted by suicidal4life
I'm running 40
Thank you suicidal .. as I said thats also what I am running I guess I am always worried about the 35/30 sidewalls and potholes !
Old Oct 4, 2011 | 12:02 AM
MBFLO's Avatar
2001 E55 - 2008 CLS63 -2016 F-150
im running like 44-45 on my 20's .. I know not 19's but just throwin it out there
Old Oct 4, 2011 | 01:09 AM
ruBENZ's Avatar
2000 E55 AMG
Being very familiar with optimum tire performance, my gut feeling tells me 34psi Front; 36psi Rear. I understand pot hole preventative applications. But, thread wear applications takes precedence. Pot hole applications aside, 40psi will produce premature uneven (center tire section) thread wear, hydroplane issues, inferior cornering grip, and a fairly shaky ride. Just my 2 cents.
Old Oct 4, 2011 | 07:58 AM
2007 SL55 AMG
I used to have my pressure set higher closer to the 40s range. I figured if I pumped it higher, the energy from hitting potholes would transfer to my rim and my suspension even more than if I had it a bit softer to absorb the impact. That's how I see it, oh and I know the rears already tend to wear in the center.
Old Oct 5, 2011 | 10:46 AM
maxwerks's Avatar
I am no expert but I can see how a lower pressure can be easier on the suspension components , but not the the rim ( thats just me ) , running 40 all around for quite sometime my tires wear is more on the edges and sides not the center ..but then again I changes so many wheels / offsets etc. that it is hardly considered consistent .
