First w210 cheap facelift conversation? 99 E55 with 02 E230 parts
Old Apr 14, 2019 | 03:58 AM
justin goetze's Avatar
1999 Mercedes-Benz E55 AMG
Has anyone actually done this?
Old Apr 14, 2019 | 09:03 AM
dbldpr's Avatar
Veteran: Navy
Welcome nice job
Old Apr 14, 2019 | 11:52 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W210 AMG forum...
Old Apr 14, 2019 | 07:20 PM
Strigoi's Avatar
2001 E320 Wagon, 2006 LBZ Silverado, 2007 E63 (sold), 2001 E55 (sold)
W210 E55 fenders are different than the non-AMG ones.
I knew a member on here that had a non-AMG rear fender installed on his car after a crash repair and he had rubbing issues. Something to think about.
Old Apr 14, 2019 | 08:28 PM
Good to know. I might have to get fenders from a 2002 E55 then instead of the ones from the E320 I have now that are stretched on.
Old Apr 15, 2019 | 01:42 AM
Strigoi's Avatar
FWIW, I'm running W210 E55 monoblocks on my lowered E320 wagon and have no issues with rubbing.
Old Apr 15, 2019 | 08:28 AM
BlownV8's Avatar
E55, GLS450, GL63, GLE350
You could also get an aftermarket front bumper that looks like an e55's that will work with your fenders.
Old Apr 16, 2019 | 01:47 AM
Nice! Let's trade cars?
Old Apr 16, 2019 | 02:05 AM
Strigoi's Avatar
Originally Posted by justin goetze
Nice! Let's trade?
Trade what?
Old Apr 16, 2019 | 12:53 PM
NAFT1's Avatar
1999 E55 AMG, 2004 Big Turbo A4; 2005 C240 Wagon 4matic; 2003 G500; 2013 Sprinter 172
Are you trying to make it look like a '00+ post-facelift model? Headlights, quarter panels, mirrors, and even A-pillars are different from '99 and lower. The hood slopes down more on the 00+. Body panels from the '99 AMG and standard models are mostly interchangeable, but the fenders were rolled on the AMG assembly line in Affalterbach.
Old Apr 16, 2019 | 03:43 PM
No not exactly. I'm just doing a cheap repair with the body parts available. I'm just looking for helpful info like this, about the small differences between the w210 models that will help me on this custom project.
Old Apr 18, 2019 | 09:41 AM
NAFT1's Avatar
I have seen some front conversions work with trimming and massaging. There are a few out there who have even grafted W212 front bumpers on. It apparently is actually easier than finding a '98/99 E55 front, though there is one for pickup in California for only $400 right now. Even has grilles and fog lenses.https://www.ebay.com/i/173868704196?chn=ps
Old Jun 20, 2019 | 01:20 AM
wallstreet's Avatar
I do not believe a W210 1999 will accept a hood, trunk or probably front bumper cover newer from 2000 and newer. Your front bumper blade might only accept 1999 front cover. Be certain front cover MATCHES 2000 and newer fender profile or the connection point/fasteners will interchange. Head lamps might be different profile at the bumper cover
E-55 Monoblok should not be any problem w/ rubbing UNLESS the fenders do not fit from 2000 to 1999
You mention "cheap" repair(????).
1999 parts from an E320 will fit and be less expensive. Not only cheaper but the time and cost of converting might be very NOT cheap.
AMG is a trim/engine/wheel package not really body parts. The expense will be a loaded front bumper cover; $750 to $1200 plus paint
Old Jun 20, 2019 | 02:17 AM
khomer2's Avatar
02w163ML500 / 97w210E50AMG / 99w202C230k / 95w124500e-wip
1999 parts from an E320 will fit and be less expensive. No only cheaper but the time and cost of converting might be very NOT cheap.
Are you speaking from experience?
Fenders need to be rolled to allow for tire clearance.
Old Jun 21, 2019 | 08:34 AM
wallstreet's Avatar
What are you stating?
Old Jun 21, 2019 | 05:25 PM
Strigoi's Avatar
Just to be clear. You're saying that the fenders need to be rolled on a non-AMG W210 to fit W210 E55 Monoblocks?
I have zero clearance issues running Monoblocks on my lowered facelift E320 wagon.
I do realize I'm somewhat contradicting what I previously said in this thread. Dude had rubbing issues, as far as we could tell it was from the non-AMG fender on his E55.
Here's mine. No rubbing whatsoever. It's also sitting on H&R springs for an E55 that have had a couple of coils removed.
Attachment 440255
Old Jun 21, 2019 | 06:25 PM
khomer2's Avatar
Here is the chart that I've used before for reference.
To further clarify, for my tire clearance comments and lowered, as an example, those going with 245s rather than 235s or less up front are going to have rubbing issues and need the fender lipped rolled. Even with 235s (ex. on our 97 E50 lowered), it clears only because of the factory lip roll. 245s will MOST likely rub on this setup. I'm running staggered setup frt 18x8 et31s & rear 18x9 et35s. Others could be running the slightly larger monoblocks staggered 18x8.5 and 18x10.
So, no, I dont believe the statements you made are contradicting. What I have noticed is comments from others about rubbing vs. no rubbing is that they don't clarifying their specific setup on lowering, ride height, spring pad spec (#1,2, 3 etc), as well as the tyre they are using since there are small subtle but noticeable differences in tyre widths/profiles of different makes - and have seen how they do mean the difference between rub .vs. no rub clearances.
As another example, I can tell you with our 99 w202 kompressor, I've read numerous comments of other members lowering their rides with H&R, Eibach, various spring pad #s or no pads and their 17", 18" monoblocks and again, it's a wide range of what fits, rubbing, no rubbing. Im running eibachs here on the w202 (same part # a friend runs here locally on an identical w202) and I'm using #3 pads in the rear, #2s in the front and he is using #2 pads in rear and #1s in the front (both cars same tires). Both have oem shocks on them still.
What # pad have you got up front?
Attached a quick blow up and shadow enlightening of your front wheels and fender gap (hard to tell with the photo angle). It looks like have some room still for lowering (via the pad change?)
Old Jun 21, 2019 | 08:17 PM
wallstreet's Avatar
Yes I am speaking from experience. I have a stock 2001 non lowered E-320 w/ 7.5/8.5 x 18 Monobloks and Michelelin 275-35 R / 245-40 F. No rubbing no fender roll required.
You are correct others state options w/o giving specific parameters. To state "fenders need to be rolled" sounds like that genre of statement. Your chart is very enlightening; thank you.
I merely opined my experience regarding upgrading a 1999 to newer panels the original poster was requesting as a cheap repair. I spent time looking for just a fog lamp capture connector for E-55 cover to E320 harness. I searched headlamps,trunk lid, hood and front covers for my 2001. Mostly the 1999 E-55/1999 E-320 parts will not fit a 2000 and newer platform. I believe the best fix in this post is to use OEM 1999 parts.
