Big Phat Dyno W211 -- 484.1 rwhp/558.78 rwtq
Today I took the car back and held my breath. The car has so much power I could not really feel the difference before and after but racing friends cars illustrated that my car seemed to be fixed. 27K miles. 2003 model.
1st run in dyno mode. Temp 73 degrees all runs. With the CUT-OUT CLOSED:
473.44/530.00
#2 CUT OUT WIDE OPEN
480.24/545.93
Then I found out that one side of the cut out was no longer opening past 1/4 inch (must have been doing this for a while as the car seemed to be quieter than summer) to I set the other one that was fully working to 1/4 inch open to match it and.....
#3 484.10 rwhp 558.78 rwtq
I think if I get the cryo kit to get intake temps lower I may even see 500 rwhp.
Needless to say after all the disappointing dynos I think the car is running finally right. The A/F ratio was between 11.5-12.0 and the dyno plot looks VERY smooth. The run was done in 4th gear so the car was going ~177mph at the cut off.
Hopefully I will have a nice 1/4 time soon, if not early in '06...looking for 122-124 traps.
With the cutouts open the car sounds like a new Z06 with the fuse out or a Cobra. It turns heads...within the matter of 2-3 seconds with the flip of a switch in the ashtray it goes to quiet as can be. I drive 90% of the time with it off though because it is loud.
I am suprised how much of a difference it made -- 11 rwhp and 28 rwtq.
Here is the cut-out thread
https://mbworld.org/forums/showthrea...exhaust+bypass
here is one pic off a google search....
http://www.thirdgenracing.com/projects/cutout/
When I looked at the RPM based chart it basically hit max hp at 6K rpms - basically redline.
The middle graph is the Custom pulley plus ECU, plus headers. The top graph is the Hennessey pulley with the same headers and no further ECU changes.
...........as for headers, I don't completely understand how much HP they make. I understand you have to remove the stock resonators to gain any appreciable HP.
...........I have no experience with Evodport headers specifically. I am ver interested in the exhaust cut outs he did.
Ted
Hey Bro,
Whats up with these fake timeslips from M5 owners? We will just have show everyone this Friday the real deal.
Tried calling you a few times. Hope you had a good turkey day with the family
You just proved what a huge factor the cooling on these cars is with respect to power. When you are modified you have to have a good cooling system and it looks like the EVO kit does its job.
That thing will be an animal on the road and should tear up the 1/4 mile pretty good.
Don't forget though.. E55Baller has the HENNESSEY PULLEY which is 7" in diameter and will generate an extra pound or two of boost so the dyno #'s should be stronger with the Hennessey pulley compared to the Kleemann or EVO pulley.
None-the-less, the combination he has is a good one as shown by the dyno #'s.
baller's HP gain was probably a result of bleeding a small amount of pressure through the 1/4" gap in the cutouts. Most of the exhaust was flowing through the mufflers.
If you want to improve your exhaust system, do something similar to vrus. He has the right idea, although I wouldn't go bigger - just more free flowing.
